Qui la procedura spiegata passo passo
https://www.androidiani.com/notizie-...-leaked-216658
Ota
22/08 ---http://d-h.st/ihl
Questi i bug fino ad ora
1) Storage setting show double Inetrnal memory tabsSystem apps and sytem ustilized memory (1st )
User installed apps and utilized memory (2nd) [Fixed 4.8.20]
2) Force close in Deep scan with the cleaner in security app (when trying to unistall an app)
3) Manual white balance, exposure, iso, focus, resolution settings and Advance settings on camera have gone missing in miui v6
4) Everytime open a contact details and press back button, the list moves to the top (It should be at the location where it was left)
5) No music controls on lockscreen for default theme
6) Alignment issue in white color fill and background in ringer volume adjustment after plugging in the headphones
7) Typo and many grammar error, music -> account setting -> high quality music [FIXED 4.8.21]
Credot -> Credit
8) No more "Menu" button, but still there is description for button light in display settings [FIXED 4.8.22]
9) Dots menu (on-screen menu button) is missing. Since the menu capacitive button is now Recent, this button is needed instead of going all the way to Settings -> System apps/ Installed apps [FIXED 4.8.22]
10) Ad blocker toggle is doubled in browser settings [FIXED 4.8.21]
11) The root access is always denied when you open any app that requires root, have to go all the way to permission manager to accept the root and it takes around 25 seconds to give the root permission cause every time it asks to wait 5 seconds on each popup before clicking on accept, it's a bit uncomfortable to wait for that much time just to grant SU access
12) it seems that the normal font is too large for the options like "Cut, Copy, Paste" and in whatsapp text entry field the texts are bigger than normal font size
13) Notifications for message and other stuff are not available on statusbar
14) Dynamic icon for clock it not aligned with the system clock, don't know if it's made this way or not (only with GMT+5:30 and GMT+6;30)
15) Bad quality of sound in video recording, and in some apps that records videos eg. https://www.dropbox.com/s/0emwiituwz...816_160945.mp4
16) There is no option to change the toggles displayed in the notification bar
17) The MI Assistant is all Chinese, Theme store is all Chinese (have to clear data everytime we reboot to have that in English), There are a lot of Text Alignment Issues
18) High-quality image processing in Instagram still don't work, the image will still turns black. [FIXED 4.8.16]
19) Graphical bug in stock Mail app, when you select a text in a mail. "Share" had a problem
20) Random reboots to many testers on their devices [FIXED 4.8.20]
21) Too much RAM utilization even though there are no extra apps not even play store installed. [FIXED 4.8.21]
22) 12 hr time doesnt show AM or PM
23) Network type doesn't change from "2g to 3g or 3g to 2g" if there's any weak network on the prefered network [FIXED 4.8.21]
24) Phone gets heated easily with few usage on 3g or playing games
25) Autostart app is not working the way it should do, app doesn't get started when the device reboots have to manually start the app to recieve push notifications
26) Mi Cloud apps shows different usage statistics than i.mi.com
27) Xunlei download engine breaks downloads for mail attachments for European regions (turning it off solves the issue)
28) Weather icon shows a degree less than the weather app [FIXED 4.8.16]
29) Have to select continues autofocus everytime i record video otherwise focus is not accurate [FIXED 4.8.20]
30) Default Downloader keeps downloading some images png files docs file on random and keeps on saying wifi not available [FIXED 4.8.20]
31) While calling, the screen sometimes get lighted on its own and sometimes doesn't light up when removed aways from the ears
32) Pages in the browser doesn't fit properly
33) Graphic Glitch on the address bar when switching to night mode on and off. Scrolling up and down fixes the problem
34) Music app has Chinese icon next to the repeat button should be in English when user uses English as default language
35) Browser is laggy sometimes it doesn't load the webpage completly and stops, also there's some issue while clicking on some clickable buttons on the page, having troub;e while selecting texts as the selecting arrows are not working properly and not able to import things eg can't attach files to a mail
36) Having SODs, device doesn't wake when power button is pressed it just vibrates and nothing happens [FIXED 4.8.21]
37) System force closes when tapping on unsuccessful download from dropdown notification screen, while tapping the failed download should put me in the list of downloads. Instead, the phone goes blank and FC
38) After changing the wallpaper to a light one the clock turns black and it stays black even after changing to a dark wallapaper
39) Uncentered/misaligned "setting as wallpaper" can be seen on other tool tips too
40) Some ringtones are showed twice when selecting notification tones for whatsapp from Media Storage
41) Change date display format is not working! try choosing dd/mm/yy but it still display as mm/dd
42) Font size is big in some settings. eg. battery setting
43) Statusbar gets overlaped while opening apps, encountered this bug while opening CPU-z and whatsapp [FIXED 4.8.22]
44) Voice search crashes all the time [FIXED 4.8.19]
45) Not all themes are shown in theme app, even some purchased themes are not available
46) There are white texts on white backgroud in many apps not comfortable to see or read them
47) FM works even without using headphones (it gives white noise)
48) Weather app is not displaying the correct weather condition always show sunny even if it's night (should show clear at night)
49) Contacts saved with long name are not showed properly while recieving a call
50) Pop-up menu for "Select all, select, cut, copy, paste" is not aligned properly
51) Amap is not working! It said "No internet connection" but I had connected to Wifi and internet is working well in browser.
52) No fullscreen picture (No picture at all actually) in call screen
53) When making a call the additional menu shows by itself
54) Volume fluctuation during call persist in V6. Had it in almost all the roms tried, but developer rom 4.8.8 had it less
55) In the Phone app, Directory tab is in Chinese
56) The auto fill form drop down list is buggy, it is unaligned and ovelaps the webpages text
57) The options icons and text in when an image is selected are too transparent, and are not easy to see if on a white backgroung
58) In contact app, unable to search localize contact, although localize contact was choose to show up (Depends on the region)
59) The default video and audio goes to online straight way when started rather than showing the local media stored
60) There is no option to adjust notification and ringtone volume separately
61) Launcher reloads after few hours of heavy usage, RAM allocation is not good. Sometimes have to reboot to free RAM [FIXED 4.8.21]
62) Access mode doesn't work properly. when you lock some apps with pattern, then unlock them once, they will always be unlocked even after you remove them from recent apps. Needs to be fixed!
63) WiFi wps entry force close everytime [FIXED 4.8.21]
64) There is no notification (count number) in stock Mail App
65) Notification running apps at launcher suddenly close. Need to reopen again eventhough had lock the apps [FIXED 4.8.21]
66) Photo get zoomed when using Camera in Facebook Meseenger
67) Bluetooth font run out of alignment "AVAILABLE DEVICES" in choosing bluetooth device page
68) YouTube app unable to play 1080p, whereas on v5 was able to play 1080p videos [Issue with the app]
69) No space between two option "Scan station and Add Station" in Station List option in Radio App
70) Set up portable hotshot" page doesn't show "show password" button [FIXED 4.8.21]
71) Battery draining very fast after 4.8.19
72) Caller's photo is blurred during out going call
74) There is no space between two words in contact options (Contact Info)
75) Have FC on transfer app
76) Sometimes the controls to pickup the call are not present, have to wait till the call ends itself to go use the device
77) Clicking on message to send a private message on Facebook app does nothing. (It should open the FB messaging app.)
78) Browser now force closes when trying to access Settings->Privacy and Security. Once you hit the back capacitive button the browser FCs
79) Can't change Notes layout (Grid, List) Only list (Feature request)
80) RTL text are NOT supported. Texts starts from left to right even when writing in Right to left language such as Arabic
81) In the Setting-> system apps, the option should be Mail app is wrongly named as Settings instead of Mail
82) When selecting Feedback it FCs
83) After set a custom ringtone for an individual contact, not able to reset back to "Default ringtone
84) After setting a custom ringtone for an individual contact, when that contact Whatsapp me, that particular custom ringtone will ring and not Whatsapp notifcation tone
85) Mikey app is not auto starting although set to auto start and allow all permission, have to manually open the app
86) There is no space between words "Hanging Up" and "duration" when hanging up a call
87) Taking photo in Mosaic or any other mode will force close [FIXED 4.8.21]
88) FM turns off after playing back recording and there are some chinese text is present in station list
89) Do not disturb is not blocking notification at the scheduled hours
90) Wikipedia logo (logo_wiki.png) on english quickling is in GERMAN
91) Music widget is acting weird, it shows music play button even if the music is playing instead of pause button have to switch homescreens to have it fixed
92) Keyboard stays on screen when searching and opening calculator app ( app searching swiping up the screen) When pressing back button, keyboard and calculator app close at the same time
93) Share page to Facebook via Browser should be the page link but now it posted as photo
94) Device rebooting when Hotspot is enabled and disabled
95) Layout glitch in accessibility setting-> Accessibility app (Settings button is misplaced)
LinkBack URL
About LinkBacks
Ultima modifica di raimondomartire; 23-08-14 alle
Rispondi quotando
