Utente del giorno: hobin con ben 3 Thanks ricevuti nelle ultime 24 ore
Visualizzazione dei risultati da 1 a 10 su 24
[ROM] XPERIA Z3 V3.0 Kitkat 4.4.2 Xiaomi Hongmi WCDMA (MTK6589)
    Ringraziato 193 volte in 169 Posts
    [ROM] XPERIA Z3 V4.0 Kitkat 4.4.2 Xiaomi Hongmi WCDMA (MTK6589)
    Porting Xperia Z3 V4 for Xiaomi Hongmi WCDMA
    V 4.0 UPDATES:
    -Xperia recent apps a shake and brush was added. Now if you are able to use at any time, both the xperia small apps.
    -Rom material interface
    -Audio for improvements were made.
    -Improvement works are made for gaming performance.
    -Walkman is fixed.
    -Sony recently changed versions of the applications.
    -Dialer has changed.
    -Rom is no theme support.
    -No Art support cause incompatibilities with some sony applications
    Details and original thread here http://forum.turkdevs.com/konu-4-4-2...4-0-final.html
    Update 30/04/2015
    - Incrementato volume
    - Viper4andoid come nuovo equalizzzatore
    http://www.needrom.com/download/rom-...wcdma-mtk6589/
    Precedente Release
    download:
    https://mega.co.nz/#!mt4QVBTZ!VMy6fL...9IqYHtTzxQ-5Dw
    Xperia V3:
    Porting della z3 kitkat su Redmi 1
    Progetto originale screenshot e maggiori dettagli XPERIA Z3 V3.0 Kitkat 4.4.2 for MicroMaX Canvas 2+ A110Q (MTK6589) | Custom Android Roms
    Caratteristiche Android 4.4 KitKat su Redmi 1 WCDMA (MTK6589)
    -Multilanguage
    -Android 4.4.2
    -Android 4.4.2 Stock Camera con galleria
    -Giochi fluidi
    -Nuovo Status Bar
    -3G su entrambe SIM
    -Sim Toolkit
    -Init.d Scripts
    - Small Apps Xperia (attivabili tenendo premuto per qualche secondo il tasto Home)
    E altro.........
    Installazione :
    Utilizzare recovery custom TWRP o CWM
    1) Download della ROM (link sotto)
    2) Copiare nella Esterna/Interna SD Card
    3) Andare in recovery custom
    4) Wipe Data/Factory Reset
    5) Wipe Cache
    6) Da Advance Menu Delvik Cache Clear
    7) Installare da SD
    8) Reboot
    (Sono necessari circa 5 Min. al primo boot)
    Download:
    https://mega.co.nz/#!vpgkTSCY!2DELFY...Nxj7QiMoyUztR8
    Correzione Bug torcia:
    Integrato nella ROM per aggiornare soltanto flashare questo zip http://goo.gl/T3H5BR
    NOTA BENE: Il porting è basato sulle librerie della miui 6 ancora in fase beta e alcuni bug si risolveranno con la versione stabile
    Sviluppatore Originale della ROM :- [4.4.2] *** Xperia? Z3 v3.0 Dr.Razor? *** - TurkDevs.Com Türkiye Android Geli?tiricileri Toplulu?u
    (credit : arraki, NeedRom, xda developers, 4pda.net e Swapnil Bunjkar )
    Ultima modifica di edyros2003; 30-04-15 alle 14:35 - Motivo: Update V4
    Rosario
  2. I seguenti 3 Utenti hanno ringraziato edyros2003 per il post:
    osholee (09-03-15),siba01 (09-03-15),xCats (16-04-15)
    Quote Originariamente inviato da edyros2003 Visualizza il messaggio
    Porting della z3 kitikat su Redmi 1
    -Multilanguage
    -Android 4.4.2
    -Giochi fluidi
    -Nuovo Status Bar
    -3G su entrambe SIM
    -Sim Toolkit
    -Init.d Scripts
    E altro.........
    Bugs :
    Led flash in modalità Torcia si accende solo per tre secondi (Bug della miui 6 beta)
    Installazione :
    5) Wipe Cache
    7) Installare da SD
    8) Reboot
    Download:
    https://mega.co.nz/#!qkB1CIrT!PjfM_b...jWwl-3T0d5vIiw
    NOTA BENE: Il porting è basato sulle librerie della miui 6 ancora in fase beta e alcuni bug (vedi torcia) si risolveranno con la versione stabile
    I bug riscontrati oltre la torcia quali sono? Vorrei provarla a meno che non ci siano problemi con le connessioni sia Wi-Fi che 3g
  5. #3
    Quote Originariamente inviato da osholee Visualizza il messaggio
    Altri bug non ne ho notati.
    Rosario
  6. Il seguente Utente ha ringraziato edyros2003 per il post:
    osholee (09-03-15)
  7. #4
    Corretto bug Torcia, vedi primo post
    Rosario
  8. Il seguente Utente ha ringraziato edyros2003 per il post:
    siba01 (14-03-15)
  9. #5
    Feb 2011
    Quindi va bene per uso giornaliero
  10. #6
    Quote Originariamente inviato da pueblito Visualizza il messaggio
    No ho riscontrato controindicazioni in tal senso.
    Bye
    Rosario
  11. #7
    Feb 2011
    Ok adesso la provo
  12. #8
    Sep 2010
    Scusa Ros ma questa Rom non mi riesce proprio a farla partire. Dopo aver fatto tutti i wipe e installato la rom al boot rimane il logo MI e ogni tanto si spegne lo schermo per poi ritornare al logo.
    Dove sbaglio?
    Inviato da Xiaomi Mi4 LTE
  13. #9
    Da quale ROM parti prima di installare questa? Che Recovery usi?
    Prima dell'installazione della z3 prova a flashare questo zip che installa il boot kitkat della miui6 https://mega.co.nz/#!PtJhDJiB!Jzqs5U...V0b2On8gQXLgiQ
    Installa anche la recovery twrp 2.8.4.0 http://soft.miui.su/recovery/redmi/T..._bucefal82.zip
    che è pienamente compatibile con kitkat.
    Nella impostazioni della TWRP in "settings" ti consiglio di flaggare "Use rm -rf insted of formatting" altrimenti il wipe è molto più lungo rispetto alla versione 2.5.
    Rosario
  14. #10
    Sep 2010
    Ok provo queste soluzioni. Parto dalla tua stable 25 e Twrp 2.5
    Edit:
    sono riuscito a farla partire con i tuoi accorgimenti ma dopo averci smanettato un pò al successivo riavvio è rimasta in loop con il logo Sony Experia.
    Per oggi basta così ci ho provato
    Ultima modifica di Stigliz; 26-03-15 alle 21:40
