Pagina 1 di 11 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 102
[ROM][DOWNLOAD][REDMI 1S] CyanogenMod 12.1 by Armani_Dev
    Androidiano VIP L'avatar di fratoff91
    Nov 2010
    Ringraziato 677 volte in 373 Posts
    NON MI RITENGO RESPONSABILE DI DANNI AL CELL O ALTRO DERIVANTI DALL'INSTALLAZIONE DI QUESTA ROM. LO FATE A VOSTRO RISCHIO E PERICOLO. SE SEGUITE LE GUIDE PASSO PASSO NON DOVRESTE AVERE PROBLEMI!
    Sempre con l'intento di mettere un po' d'ordine nella sezione per Xiaomi RedMi, creo il thread apposta solo per la
    CyanogenMod 12.1 R19 (by armani_dev)!
    REQUISITI PER L'INSTALLAZIONE:
    INSTALLAZIONE:
    • se provenite da un'altra rom:
    • per aggiornare la cm12.1:
    DOWNLOAD:
    TUTTI I CREDITI VANNO A jsevi83 E Kra1o5 E CHIUNQUE CONTRIBUISCA A QUESTA ROM.
    Ultima modifica di fratoff91; 27-09-15 alle 13:12 - Motivo: Aggiunta R19
  2. I seguenti 2 Utenti hanno ringraziato fratoff91 per il post:
    Brapple (17-07-15),Fattodinote (10-06-15)
    Nov 2010
    BUG CONOSCIUTI:
    REDMI 1S BUG:
    • Camera HDR mode doesn't seem to be working.
    • Some other minor bugs.
    CHANGELOG:
    R19(19/09/2015):
    • Address selinux denials
    • CPU and thermal tweaks
    • New fingerprint from V6.7.1.0
    • Update blobs from V6.7.1.0
    • Add an API to log wakeup reasons
    R18(11/09/2015):
    • Enable dex-preoptimization to speed up first boot sequence
    • Enable BFQ IO scheduler by default
    • F2FS updates (official 3.4 support)
    R17(04/09/2015):
    • Upstream fixes and updates
    R16(28/08/2015):
    R15(21/08/2015):
    R14(05/08/2015):
    • Enable option to set app installation location
    • Update fingerprint from latest official release
    • Use prebuilt hevc codec
    • Switch to lower-end codecs
    R13(26/07/2015):
    • Enable proximity check on screen wake
    R12(14/07/2015):
    • New I/O scheduler FIOPS
    R11(25/06/2015):
    • Add fingerprint and other missing props
    • Enable DRM prop
    • Fix sepolicy denials
    • Remove unneeded firmware symlinks
    R10(14/06/2015):
    R9(03/06/2015):
    • Choose storage for camera app (external sd available now)
    • Changes in msim and telephony settings
    • Enable SMS center (someone was dying for it...)
    • Address sepolicy denials
    R8(26/05/2015):
    R7(16/05/2015):
    • Ambient display enabled
    • "Choose SIM for data" dialog is finally gone
    • Changes in encryption (new TWRP build needed to be tested)
    • Other fixes and updates
    R6(11/05/2015):
    • Fix delay in pin request
    • Other upstream fixes and updates
    R5(05/05/2015):
    • Dualsim and ril changes
    R4(25/04/2015):
    • Android 5.1.1
    • Lots of kernel updates
    • Support F2FS on data and cache
    R3(21/04/2015):
    • Fix moving apps to external sdcard
    R2(14/04/2015):
    • Fix alarm during off mode charging
    • Improve plug detection of headsets
    • Disable KSM by default (fixes camera for some users)
    • Less agressive thermal control for battery temp
    • Update wifi files to fix suspend issue
    • Update media codecs and profiles
    R1(07/04/2015):
    • First Public Release
    THREAD ORIGINALE:http://forum.xda-developers.com/redm...-12-1-t3075376
    Ultima modifica di fratoff91; 27-09-15 alle 13:17 - Motivo: Aggiunta R19
  5. #3
    Nov 2010
    modificati i primi due post con guida, link è una grafica più user friendly
    Penso anche di fare delle faq se vedo che servono!
  6. #4
    Nov 2010
    aggiornato a R6! mi scuso per il link alla R5 ma a quanto pare non funziona e l'ho tolto. se riesco a recuperarlo, lo riaggiungo...
  7. #5
    May 2015
    Ciao fratoff91 , sul mio redmi la v6 non ha voluto saperne forse perché uso la mirecovery , e a questo punto visto che sono in ballo stavo pensando se installare la cm 12.1 , tu che le conosci entrambi quale consigli con pregi e difetti e durata batteria quale è la migliore? Grazie
  8. #6
    Nov 2010
    Quote Originariamente inviato da tonillo Visualizza il messaggio
    Ciao! Allora, io ho un debole per la miui e devo dire che con la miui 6 abbiamo raggiunto l'eccellenza. Premesso questo, dipende da quello che fai e ti piace: la miui 6 è perfetta dal punto di vista estetico e funzionale con molte funzioni interne che con la cm12.1 fai solo con app esterne. Dico cosa mi ha fatto provare la cm12.1 provenendo da miui 6: la RAM! Miui 6 ha un pessimo uso di RAM. App come facebook e altre succhia ram sono sconsigliate altrimenti si impianta finché non esci da queste app (la cosa è migliorata di molto con la versione 5.5.17). Ora dico cosa mi ha fatto tornare alla miui 6, piallando tutto via fastboot: bug e incertezze per quanto riguarda la gestione della rete. Switch della rete tra le 2 SIM lentissimo e a volte nemmeno lo fa, metto 2g su entrambe le SIM, ma passano molti minuti a quando fa effettivamente lo switch della SIM 1. E poi piccoli bug qui e lì e mancanza di funzioni..
  9. Il seguente Utente ha ringraziato fratoff91 per il post:
    tonillo (18-05-15)
  10. #7
    May 2015
    Io uso una sola sim ed è 3g , avrò anch'io problemi ? visto che lo uso per lavoro sarebbe un problema sopratutto per la connessione dati.
    Non uso facebook o altri social ho solo whatsapp, quindi non dovrei risentirne tanto , il mio problema alla v6 è che non sono riuscito ad installarla , vado nell'altra discussione e seguo consigli per riprovare.
    ciao
  11. #8
    Nov 2010
    ciao
    No, con una SIM non ci son problemi, in teoria... Prova con il procedimento come ho detto, con il wipe all data...
  12. #9
    Nov 2010
    Aggiornato il Thread alla R7!!
  13. #10
    Nov 2010
    aggiornato il thread alla r8!
