Pagina 17 di 31 primaprima ... 7151617181927 ... ultimoultimo
Visualizzazione dei risultati da 161 a 170 su 306
[ZP998] RECOVERY CWM e ROOT
  1. #161
    Sviluppatore Android L'avatar di marsapa
    Verona
    diversi
    Ringraziato 3,013 volte in 1,746 Posts
    Quote Originariamente inviato da carcass Visualizza il messaggio
    Hai testato magari il mic con hangout video chiamata o un video rec?
    Funziona bene, ho provato la registrazione audio e mi sembra ok
    Se ti è piaciuto il mio lavoro offrimi un caffe https://www.paypal.com/cgi-bin/websc...=DYAE6Q6K488AE
  2. Il seguente Utente ha ringraziato marsapa per il post:
    carcass (19-02-14)
    Sep 2013
    Ringraziato 24 volte in 18 Posts
    Speriamo con Skype le chiamate che a me serve molto funzioni. Vedremo appena arriva.....
  5. #163
    Da forum .cn
    quick review :
    the sound issue in videos seams corrected (when you choose the audio mode meeting in recording)
    they added a new theme named starttreks (but they obiously didn't test it in the filemanager app... as the result is .... unusable black text over black bakcground ....
    the phones seams to be more reactive
    still no black screen actions
    the picture quality is the same as before (now there is no more full screen preview menu... only the resolution, but you can choose wide resolution to have fullscreen preview)
    the super su menu is no more in the advanced menu, it is in the security menu but it still not works ... will need to roon the device again but i'm not sure that the patched boot.img from first release is the optimal choice... maybe zopo made some changes in the bootimage too
    ps: for people who can't download it, i uploaded the OTA file here www . d-h.st / 89D (rimuovete gli spazi)
    with a bit luck it will work if you place the file in the right directory (there was a folder in the sdcard but i forget to rembemer the name... something with ota )
    DOVREBBE ESSERE ADUPSFOTA, credo.
  6. #164
    Senior Droid L'avatar di manovelio
    Feb 2014
    Gragnano Trebbiense
    ZP998 - Huawei Honor 3X pro
    Ringraziato 39 volte in 31 Posts
    Buongiorno a tutti.
    Vorrei una piccola precisazione, essendo alquanto ignorante in merito: fra poco sarò in possesso del 998 e vorrei sapere come muovermi.
    Dovendo fare tutto dal principio (root, ROM di Marsapa, aggiornamento ZOPO) com'è meglio muoversi? Ovvero, c'è un modo per avere sul telefono sia le modifiche di marsapa che quelle originali? O si deve scegliere cosa tenere.
    Questo perchè a quanto pare sul nuovo firmware ZOPO sembra non esserci ancora il miglioramento del GPS che a me serve, mentre su quella ufficiale hanno sistemato sia il microfono che il funzionamento della batteria.
    Essendo completamente a digiuno sembra veramente una selva intricata
    Ciao e grazie a tutti
  7. #165
    Verona
    diversi
    Quote Originariamente inviato da manovelio Visualizza il messaggio
    Buongiorno a tutti.
    Scusa il firmware zopo e' quello Ufficiale, comunque per il GPS ci penso io, la ZOPO non configura il GPS.config per l'Europa quindi tenendo l'originale si fara' sempre fatica a trovare i satelliti
  8. #166
    Verona
    diversi
    Quote Originariamente inviato da fmotta Visualizza il messaggio
    Da forum .cn
    quick review :
    Si e' vero c'e' un nuovo tema, che e' peggio dei precedenti
  9. #167
    Jan 2014
    grande marsapa. poi, se puoi, inserisci anche una guida su come aggiornare, partendo dalla tua v2, per noi poveri niubbi
  10. #168
    Verona
    diversi
    Quote Originariamente inviato da dreamwarrior Visualizza il messaggio
    Guarda l'ho gia' fatta, si installa con Aroma cosi' dovete seguire le istruzioni
  11. #169
    Androidiano VIP L'avatar di che78
    Salerno
    zp980 zp998 Lg g2, op3t, op5
    Ringraziato 150 volte in 139 Posts
    Vabbé il problema dei temi penso che sia relativo, ognuno ha i suoi gusti, si può tranquillamente installare nova? O nn va?
  12. #170
    Salerno
    Anche se ho visto dei video con launcher stock emi sembrava fluido, é così o mi sbaglio!!!!!!!
