Pagina 2 di 7 primaprima 1234 ... ultimoultimo
Visualizzazione dei risultati da 11 a 20 su 62
[ROM] MIUI6 per Zopo zp998
  1. #11
    No italian language.
    3G work fine for me.
    changelog for the new version 5.3.4
    Correctly displays the names of operators
    Equalizer available and works
    Working connection to the PC in mass storage mode
    Improved smoothness of the interface
    Ext-sd now is the ext-sd)
    Ultima modifica di Lovetz; 06-03-15 alle 09:35
    Jul 2009
    can be ported to zopo zp999?please
  4. #13
    Quote Originariamente inviato da Dudanken Visualizza il messaggio
    Hi Lovetz, i have a little problem, i'm using your porting but i can't unlock secondo SIM even if input correct pin.
    I do not have this problem, sorry. I use two SIM-cards without any problem.
    Ultima modifica di Lovetz; 06-03-15 alle 10:14
  5. #14
    Jul 2009
    but they are two different devices zopo zp999 is the new zopo with mtk6595 processor.
    Can you port this ROM for it?
  6. #15
    Quote Originariamente inviato da blackidra Visualizza il messaggio
    No, sorry.
  7. #16
    Baby Droid L'avatar di ShuradiCapricorn
    mi sa che con tanta pazienza si dovrà usare ApkTranslationWizard
    -ZenFone 2 ZE551ML-
    Android 5.0 rom stock ASUS + root
    -Zopo ZP998-
    Android 5.1.1 custom rom Degrus
    -AinolNovo7 ELF-
    Android 4.1.2 custom rom Shaun
    MAI E POI MAI FARSI PRENDERE DALL'ANSIA DEL BRICKKAGGIO PRECOCE
  8. #17
    con ApkTranslator sto avendo problemi di decodifica dei pacchetti
    qualcuno sa come risolvere?
    o qualche metodo alternativo per tradurre?
    -ZenFone 2 ZE551ML-
    -Zopo ZP998-
    -AinolNovo7 ELF-
  9. #18
    Androidiano L'avatar di gabrio79
    Oct 2014
    Ringraziato 27 volte in 23 Posts
    Hi Lovez, I installed your rom but I recevie an errore on email app (mail has stopped), also google apps... have you tried it? suggestion?
    Ultima modifica di gabrio79; 11-03-15 alle 17:33
  10. #19
    mail app ang google apps works fine. Reinstall ROM.
    New version (11/03/15) is out.
    New - Support choosing content to send when sending contacts via SMS (03-10)
    [Lockscreen, Status Bar, Notification Bar]
    Fix – Lockscreen wallpaper display error in landscape mode (03-09)
    Fix – Black screen when switching system languages (03-10)
    [Themes]
    New – There will be instant notification when a theme is gifted to a user (03-11)
    Optimization – Optimized the prompt when there is no network (03-11)
    [Music]
    New - Support playing DSF format music file (03-10)
    Optimization - Animation effects when opening and sliding song lists (03-10)
    Fix – Paused music did not continue playing after exiting ringtone selecting page (03-10)
    [Radio]
    New - Brand new Xiaomi Radio (03-10)
    [Calendar]
    New - Sync calendar to Mi Cloud (03-11)
    Ultima modifica di Lovetz; 12-03-15 alle 11:04
  11. #20
    17/03/15 - New version is out.
    - No problem with poweroff function now.
    - MTP works better.
    You can encourage developers to port version here.
    Ultima modifica di Lovetz; 18-03-15 alle 13:29
