Pagina 7 di 23 primaprima ... 5678917 ... ultimoultimo
Visualizzazione dei risultati da 61 a 70 su 226
[ROM][5.1.1][ZP998] CyanogenMod 12.1 [UNOFFICIAL]
  1. #61
    Androidiano L'avatar di Lumingft18
    Sep 2014
    Ho provato a flashare ma non cambia nulla
    So riavvia prima di iniziare a squillare
    Inviato dal mio ZP998 usando Androidiani App
    Ultima modifica di Lumingft18; 21-09-15 alle 14:33
    Oct 2014
    Ringraziato 25 volte in 16 Posts
    per me fonziona bene no ho questa problema dopo flashaere il fix
    ecco el fix:: fix telephony-calendar sync
    Ultima modifica di degrus; 21-09-15 alle 16:05
  4. #63
    Sep 2014
    Ma l eco è stato fixato?
    Inviato dal mio Nexus 9 usando Androidiani App
  5. #64
    Oct 2014
  6. #65
    Sep 2014
    Non mi va ancora penso che forse è un probblema di wipe?
  7. #66
    Oct 2014
    ROM OctOS-20150921-UNOFFICIAL-ZP998 Including GAPPS | [Custom]-[Updated] add the 09/22/2015 on Needrom
    Rom link::: http://sh.st/v95wg
    This is the first stable version OctOS lollipop 5.1.1 for ZOPO ZP998
    Working
    Dual SIM (Maybe working. Not tested.)
    RIL (First and Second SIM)
    Wifi
    Bluetooth
    Audio
    Camera (photo recording)
    NFC
    OTG
    MTP (ADB is working)
    Sensors
    Video recording
    Video en/decoding
    Gps
    Before:
    Rom: Komu 1.03 Stock KitKat
    Recovery: TWRP_ZP998_2.8.4.0_rublix
    1. Go into recovery
    2. Wipe Data, System, Cache, Davlik cache
    3. Flash OctOS rom
    4. Reboot
    If you loose imei and dont have phone access: use MTK Droid Tools – > click IMEI/NVRAM -> Write your imei to both input (you can check it under your battery) and restart your phone
    If anything goes wrong just go back to stock Rom: Komu 1.03 Stock KitKat anytime with MTK Flash tools
  8. #67
    Oct 2014
    ROM CM-12.1-20150922-UNOFFICIAL-ZP998 Including GAPPS | [Custom]-[Updated] add the 09/20/2015 on Needrom
    22/09/2015 Change log::
    - Sensors fixed
    - sdcard mound enhanced
    - fix telephony(com.android.phone error)
    - fix calendar sync error
    - Advanced mode settings working fine now
    - Fixed N/W loss after call
    - SIM Switching Mechanism
    - Updated CM source.
    - Fixed settings fc
    - new ui
    - more Sdcard stability
    - More and more stable
    - Enhencement of camera (look screenshot)
    - Vulnerability fixed (look screenshot)
    - First issue FM radio (look screenshot)
    - Internal and external sdcard could be monted as usb storage (look screenshot)
    - Fixed 3g dual sim switch
    - No more battery drain
    - No more heating phone
    - led notification fixed
    - new repos sync
    Working
    Wifi
    Bluetooth
    Audio
    NFC
    OTG
    Sensors
    Video recording
    Video en/decoding
    Gps
  9. Il seguente Utente ha ringraziato degrus per il post:
    stefano91av (23-09-15)
  10. #68
    Senior Droid L'avatar di stefano91av
    ZOPO 998
    Ringraziato 72 volte in 47 Posts
    Aggiornata prima pagina con update 22/09/2015
  11. #69
    Senior Droid L'avatar di francj67
    OPTWO
    Ringraziato 70 volte in 62 Posts
    un saluto a tutti, ritorno con questo terminale dopo mooolto tempo e installata attualmente ho la rom v9 marsapa, se non ho capito male per installare questa dovrei installare la stock oppure mi sbaglio?? grazie
    Quote Originariamente inviato da stefano91av Visualizza il messaggio
    One Plus TWO
  12. #70
    ZOPO 998
    Quote Originariamente inviato da francj67 Visualizza il messaggio
    Se hai la marsapa v9 basta fare i classici 3 wipe ed installare la rom Cm 12.1 infine
  13. Il seguente Utente ha ringraziato stefano91av per il post:
    francj67 (23-09-15)
