marsapa (09-05-15)
Se ti è piaciuto il mio lavoro offrimi un caffehttps://www.paypal.com/cgi-bin/websc...=DYAE6Q6K488AE
Ultima modifica di marsapa; 09-05-15 alle 23:57
Ebola (09-05-15)
Scusate,ma io con la v9 ho questo problema :uploadfromtaptalk1431204941633.jpg
Lo fa praticamentecon tutti i device,cosa posso fare?
hello marsapa thanks for the version v10 but I'm confused , I in my case I have v9 but according to you say at the beginning of the post to be installed making wipe data , but when I 'm the last of the forum indicates that only I have to clear cache and dalvik which way ... Anyway I have to do to install the v10 ....
On the first page is indicate to make a ffull wipe as for all the New Roms' installation. Otherwise, you get problems with xposed and other apps.
Inviato dal mio ZP998 usando Androidiani App
ah gracias gianlucanocera
