Utente del giorno: kroko con ben 1 Thanks ricevuti nelle ultime 24 ore
Milestone Custom Update Package
    Feb 2010
    Ringraziato 14 volte in 6 Posts
    link: Milestone Custom Update Package
    Milestone users update apk or other tools through Recovery mode.
    But some tools need users to use command line by adb shell.
    Here is a custom update package for update providers to make
    menu items. Update from Recovery mode can be more easier.
    How it work:
    This tool is a modification of Android's Recovery application.
    When unrar the ball, it should have update.zip and CustomUpdate.
    All menu files should be put in the CustomUpdate/menu directory.
    Menu file uses ":" as the splitter, and there are three items in one line,
    which is "description:function:file"
    Example: init.menu (Default menu)
    Reboot system:reboot:
    Kahnmao Chinese update 3/26:shell:kahnmao.sh
    sprecovery initial:init:sprecovery_init.sh
    sprecovery backup:shell:nandroid-mobile.sh -b -q
    sprecovery restore:menu:sprecovery_restore.menu
    sprecovery delete:menu:sprecovery_delete.menu
    Root phone:shell:root.sh
    Clear system cache:clear_cache:
    Clear user data:clear_data:
    Remove custom update package and reboot:clear_custom:
    Current usable "function":
    reboot: Reboot milestone
    init: When menu loads, the init script will be executed automatically, this item will not be shown in the menu list.
    Through this function, it can generate other menu dynamically. The example are sprecovery restore and delete
    menu.
    shell: Execute item, the file in the CustomUpdate/bin.
    menu: Next menu, the file in the CustomUpdate/menu.
    clear_cache: Clear CACHE area, the same as Recovery.
    clear_data: Clear user DATA area, the same as Recovery.
    clear_custom: Delete update.zip and CustomUpdate directory.
    MEGAUPLOAD - The leading online storage and file delivery service
    be'... la possibilita' di usare nandroid senza PC... senza ADB... e' veramente una FIGATA!
  2. I seguenti 2 Utenti hanno ringraziato theslug per il post:
    micio (31-03-10),pellizzo (31-03-10)
    Dec 2009
    Localitā
    Venezia
    Ringraziato 31 volte in 18 Posts
    Ottimo direi...l'unica cosa č che non sono riuscito a ripristinare i vecchi backup fatti con nandroid, ho dovuto creare un nuovo backup con questa custom recovery e il restore funziona
  5. #3
    Dec 2009
    Ma per installarla devo installare l'update.zip solo una volta o ogni volta che voglio utilizzare questo tool?
    Questo tool si sostituisce alla recovery stock?
  6. #4
    Feb 2010
    A. Fix unable to use "Remove custom update package and reboot".
    B. Release modified Android recovery source, which is CustomUpdate/bin/custom
    2010040201:
    A. Fix sh issue.
    B. Change menu "shell" execution method.
    2010040101:
    A. Add AdbRecovery.
    B. Camera key can be used as select.
    C. LED blinking during internal process.
    D. AdbRecovery backup directory "Bb*-xxxxxxxx-xxxx" must put
    in the nandroid/adbrecovery directory.
    E. Fix menu bug.
    2010033102:
    A. Remove Chinese update directory.
    B. Fix sprecovery backup empty data.tar
    questo e' il changelog, per scaricare l'ultima versione seguite il primo link.
  7. #5
    Senior Droid L'avatar di raimondomartire
    Dec 2009
    Localitā
    Salerno
    Ringraziato 349 volte in 201 Posts
    Quote Originariamente inviato da pellizzo Visualizza il messaggio
    Nella nuova versione risulta superato il bug
    basta mettere la directory "Bb*-xxxxxxxx-xxxx" in nandroid/adbrecovery
  8. #6
    Apr 2010
    Scusate ho provato ad installare "Milestone Custom Update Package" sul mio 2.0.1 con permessi di root ma nonostante ripetuti tentativi nel menu vedo solo le quattro voci principali e mi rimanda sempre l'errore E: can't open /cache/recovery/command cosa sto sbagliando ? sono molto interessato a questa possibilitā di fare il backup direttamente dal telefono ma non capisco dove sbaglio.
    Grazie in anticipo a chi vorrā rispondermi.
    Ultima modifica di morgan68; 06-04-10 alle 18:40
