Pagina 1 di 73 1231151 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 725
[ROM] CyanogenMod 7 Gingerbread (unofficial porting)
    Senior Droid L'avatar di divicos
    Jan 2010
    AGGIORNAMENTO LINK!!
    Il link per il download punta direttamente la pagina di nadlabak su github.com, che contiene tutte le relase della CyanogenMod 7 e anche la vecchia CyanogenMod 6.
    Ogni nuova relase sara' postata li' dall'autore, quindi basterà scaricare l'ultima inserita, seguendo sempre lo stesso link.
    CyanogenMod 7 for milestone
    by kabaldan / nadlabak
    ----> Thread su XDA <----
    Project on code.google.com
    Home Page
    DOWNLOAD CM7 LATEST
    Google Apps (for CM7.1.X): version for 2.3.4 - http://goo-inside.me/gapps/gapps-gb-20110613-signed.zip - mirror FileServe
    not yet updated for 2.3.4:Latest Version - CyanogenMod Wiki
    Theme: Xeno CyanoGen By Travis90
    The hero responsible for the gkisystem (radio) finally running under 2.3 is f_pasha, many thanks to him!
    Please note that Milestone is not officially supported by CyanogenMod.
    Home page: CyanogenMod 7 for Milestone A853 | android.doshaska.net
    Issue tracker: cyanogenmod4milestone - Project Hosting on Google Code
    FAQ(wiki): https://www.droid-developers.org/wik..._Milestone_FAQ
    Build from source: CM7 for Milestone - build from source | android.doshaska.net
    github: https://github.com/nadlabak
    my recent commits to official CM: Gerrit Code Review
    Remember, this is still currently powered by a kernel & beta proprietary binaries from 2.2 official release by Motorola.
    Please, if you are experiencing random reboots (that involve the M logo) or prolonged screen freezes, you should revert to an older beta kernel that is free of the DSI errors. To do so, replace the boot.img in the update-cm-7...zip package with this one (from 0.04 version): http://code.google.com/p/cyanogenmod...ootimg0.04.zip
    Ultima modifica di divicos; 23-06-11 alle 11:32
    ______________-\\|//
    _____________-( o O )
    ___________ooO_( )_ooO_______
    __|___|_free my_|___|___|___|___|
    |___|___|___|_Atrix___|___|___|___|
    __|___|___from import duties_^^_|
    12 e 13 giugno. L'ItaliaSI è desta!!
    VENDO Motorola Atrix 4g At&t
  2. I seguenti 2 Utenti hanno ringraziato divicos per il post:
    dpiazza (29-06-11),skippy (29-03-11)
    Jan 2010
    changelog
    Complete changelog can be read on xda-developers - View Single Post - [ROM] CyanogenMod 7.1.0 RC2.1 11.05.11 (Android 2.3.4).
    Notes:
    - the main init scripts are located in /system/etc/rootfs
    - clocking options (frequency table, vsel table and governors) can be set in /system/etc/init.d/10overclock
    - Adobe Flash can be downloaded and installed directly from Adobe web or Android Market
    - USB tethering: use Solutor's USB Tether app - Working USB tethering for Froyo and Eclair Stones [update 16-12-2010] - xda-developers
    Installation:
    - use OpenRecovery Apply Update menu to install the zip copied to /sdcard/OpenRecovery/updates
    - data wipe/factory reset is highly recommended when you are upgrading from another rom/firmware (or having any issues )
    - the included RIL files are for the European frequencies, if you are in Canada, US, Lat Am or Thailand, you will need to replace them to get 3g working
    - if you are in France, you should replace ro.product.brand=MOTO_RTEU with ro.product.brand=MOTO_RTFR in /system/build.prop (the ap_gain_france.bin will be used then)
    OpenRecovery Mod (with CyanogenMod for Milestone specific customizations):
    androidiani-openrecovery - Project Hosting on Google Code
    YouTube Sample
    Ultima modifica di divicos; 23-06-11 alle 12:14
  5. I seguenti 2 Utenti hanno ringraziato divicos per il post:
    skippy (29-03-11),Travis90 (24-04-11)
  6. #3
    Androidiano L'avatar di Koto82
    Mar 2010
    Torino
    Nexus 4
    Bellissima Rom veloce e stabile, purtroppo l'ho dovuta lascia a causa di Ginger che un pò di programmi non sono ancor compatibili
  7. #4
    Senior Droid L'avatar di maggots
    Jul 2009
    è uscita la rc1???
    prendo e ringrazio......
    Motorola Milestone
  8. #5
    Senior Droid L'avatar di Travis90
    Sep 2010
    Galaxy S4 Black Edition
    Ringraziato 81 volte in 65 Posts
    Sapete perchè nella CM7 RC1 hanno disabilitato il JIT?
    Dal changelog
    I use ADW option described a previous post, JIT disabled, VM size 24M, surface dithering off.
    Dai commenti
    I have been testing some other tweaks and now I'm not sure what exactly bring my phone faster.
    1. JIT Off, I read in a tread for CM6 to try out this.
    2. Reduce VM size to 24.
    3. CM menu to lock home screen to memory (your tip)
    4. And last update to 11.02.10
    So far is working just fine, but again, not sure was what the exactly tweak or if it was a combination.
    I think last one was crucial, cause nadlabak confirm some fix regarding memory. Excellent ROM dude!!
    Anche nella CM6 vi era scritto
    Multitasking
    Useful advice for those who have problems with multitasking. Switch off JIT in Cyanogen menu and you will get an excellent multi-tasking, programs will no closes and will normally hide again, as before.
    Cioè alcuni notano una velocità maggiore senza il JIT, ma non dovrebbe essere al contrario (ovviamente solo per quelle app che lo sfruttano... ma non dovrebbe rallentare il resto o sbaglio?)
    >My Android BlueBot<
    >>Galaxy S4 Black Edition ROM BluMak2000 + Xeno Cobalt Theme<<
    Theme Maker for:
    >>Galaxy Nexus i9250 ROM AOKP+CM Snap(Black) + Trinity Kernel<<
    >>Nexus S i9020 EU Super Amoled<<
    >>Motorola Milestone
    - Theme Xeno CyanoGen <<
    >>Sony Xperia X10 mini Pro<<
  9. #6
    Androidiano VIP L'avatar di Guildamx
    Nov 2009
    OnePlus One
    Ringraziato 532 volte in 466 Posts
    Quote Originariamente inviato da Travis90 Visualizza il messaggio
    A quanto ho letto, la poca ram del pietrone non permette al JIT di essere performante. In effetti l'esperienza d'uso quotidiana non consente di apprezzare miglioramenti.
    OnePlus One
    crDroid 5.5 (Android 4.4)
    Samsung Note 8.0
    CivZ-FLEXNOTE-8.0-REV2.1 (Android 4.4)
    "In un periodo di tempo sufficientemente ampio, tutti i PC monteranno Linux e tutti gli smartphone Android"
    (Benedict Neuhaus, futurologo)
  10. #7
    Cagliari
    Milestone,Galaxy S2/S4
    l'ultima relase del 18 è un mattone, mi andava molto meglio quella del 15, al posto di migliorare peggiora XD
  11. #8
    Jan 2010
    Dici??
    io la trovo parecchio migliorata..
    come ho scritto anche nel vecchi thread, apprezzo soprattutto la scelta di forzare la home in memoria, che evita di ricaricare la stessa ogni volta che ci si torna, difetto principe delle Alpha..la cosa, purtroppo, si bilancia con una maggiore lentezza nell'aprire app. pesanti.. ma data la poca ram che ci ritroviamo, come si dice dalle mie parti, "da 'na parte pende l'asino"..
    in piu' la risposta e la precisione del touch, altra nota dolente, è migliorato di parecchio..
    sul jit, aveva gia' fatto notare Luca come il Milestone rispondesse meglio senza, tant'e' che anche lui nelle sue ultime FroyoMod lo ha disabilitato
  12. #9
    Mar 2010
    HTC Wildfire S - Galaxy Note 2
    perchè mi segna la batteria carica massimo fino al 80%?!
  13. #10
    Jul 2009
    posto qui, per chi ha il problema della batteria ,la soluzione per resettarla e far riconoscere al telefono il reale 100% di ricarica:
    Fase 1:
    Avviare il telefono normalmente e ricaricare il telefono cellulare come come si farebbe normalmente fino a quando si dice "carica".
    Fase 2:
    Una volta che il telefono cellulare lo stato di carica, dice "carica", scollegare il cavo dalla presa a muro del telefono. Spegnere il telefono cellulare.
    Fase 3:
    Mentre il telefono è ancora spento, ricollegare il cavo del caricatore da muro. Accendere il potere del caricatore da muro.
    Fase 4:
    Si dovrebbe quindi vedere il logo M per un po 'e poi si vede l'icona della batteria al 100% di verde nel centro dello schermo.
    Fase 5:
    Aprire il coperchio della batteria ed estrarre la batteria e attendere per un po 'fino a vedere il "?" icona al centro dello schermo LCD.
    Punto 6:
    Reinserire la batteria in
    Passo 7: Se la batteria è OK (opportunamente calibrato), poi avrebbe indicato al 100%. Se non è adeguatamente calibrata, poi avrebbe indicato il 60% e continuerà a caricare la batteria fino al 100%
    Motorola Milestone
