Utente della settimana: bluemask con ben 18 Thanks ricevuti negli ultimi sette giorni
Utente del mese: bluemask con ben 36 Thanks ricevuti nell'ultimo mese
[ROM][KANG] Unofficial CM9 (WiFi-Only) (Updated 1/22/12)
    Senior Droid L'avatar di barabba
    Jan 2010
    Xoom / Galaxy Note / Htc one s
    Ringraziato 77 volte in 45 Posts
    Vi segnalo l uscita della cyano 9 per xoom..
    Per installare la rom bisogna avere una recovery modificata (rogue 1.3.0)
    Includes:
    +Source from CyanogenMod 9 (1/9/12)
    +Full support for Camera, HDMI and Video acceleration (from the leaked 4.0.3 ROM)
    +Rogue XM Kernel 2.0.2
    +Disabled lockscreen rotation
    +Allow apps to write to SD card (thanks kcrudup)
    +Tweaked ICS boot animation (thanks Sardo Numspa)
    Install Instructions-
    -Make a backup in your current recovery
    -Download zip's from link's below
    -Place zip's on external sdcard (change file extension's to .zip if listed as .php)
    -Boot into recovery and wipe: data, cache, and dalvik cache
    *Upgrading between builds should only require wiping caches unless otherwise noted
    -Install Rom
    -Install Gapps(recommended Gapps linked below)
    -Reboot
    -Enjoy the glory!
    In parole poche:
    Mettere lo zip della rom nella sd esterna,fare un backup da recovery (non si sa mai ),fare tutti i wipe ( data, cache, and dalvik cache ),installare la rom e poi le gapps
    Download-
    Rom-
    http://api.viglink.com/api/click?for...13273174962791
    Gapps-
    goo-inside.me - Gapps downloads
    -Partial Changelog-
    1/22/12 (Rom)
    Rom-
    *Fixed lag when toggle switches in quick settings (wifi, bluetooth)
    1/19/12 (Rom)
    Rom-
    +New Quick Settings switches (WIP)(replaces Notification Power Widget)
    *Tapping Wi-Fi/Bluetooth/GPS will open the appropriate Settings screen
    +Updates to prebuilt ROM Manager, Terminal Emulator
    1/18/12 (Gapps)
    Gapps-
    *Fixed installer script leaving duplicate Search apps
    Rom-1/16/12 (Rom)
    +Enabled Notification Power Widget (thanks bazar6)
    **Known issue, GPS icon does not highlight unless you close and re-open window
    Rom-1/15/12 (Rom)
    *Trebuchet: Fixed app drawer icon disappearing when removing search bar
    *Rogue: Fixed broken cifs.ko
    1/13/12 (Rom, Gapps)
    ***Full wipe is not required for Rom and Gapps update (unless your coming from another Rom), but it is recommended***
    Rom-
    *Rebased binaries on IML77 OTA (libs, apks, bootanimation)
    +Enabled reboot menu (thanks NPerry)
    Gapps (v5.1)-
    +Rebased on GApps from the IML77 OTA
    +Removed portrait only setup in FaceLock.apk
    *Updated versions of Market and Maps
    1/12/12 (Rom, Gapps)
    ***If you are on a prior CM build, only a cache and dalvik cache wipe is needed***
    Rom-
    +Added face unlock support (thanks solarnz and LPHS) *Requres latest GApps
    +Auto-rotate switch now controls lockscreen rotation
    Gapps (v4)-
    +Replaced YoutubeTablet.apk with the regular 4.0.3 Youtube.apk
    *Renamed Gallery (fix duplicate gallery appearing)
    +Added face unlock files
    +Added Superuser.apk from market
    1/11/12 (Rom)
    Rom-
    *Trebuchet: Removing the Search bar no longer force closes Trebuchet (known issue: removing the search bar also removes the app drawer icon)
    *Trebuchet: More suitable defaults on first boot (centered clock, auto rotation)
    Kernel-
    +Rogue XM Kernel 2.0.2: BogoMIPS now scales with frequency, both cores
    1/10/12 (Gapps)
    Gapps (v3)-
    +Fixed issue with G-Talk video
    +Fixed issue with sillyfaces
    *If you are on a prior CM9 build we recommend a full wipe due to the updated Gapps.
    1/9/12 (Rom, Gapps)
    Rom differences from upstream-
    Kernel-
    +Rogue XM Kernel 2.0.1 (CPU and GPU OC, voltage control, init.d, USB OTG, CIFS, TUN)
    +Based on Google/Motorola's 2.6.39.4 kernel for Android 4.0
    +Storage controller tweaks (thanks kcrudup)
    +Cache controller tweaks
    +filesystem tweaks
    Thank You-
    CyanogenMod Team
    Kejar
    NPerry
    Kcrudup
    Team Eos
    Ultima modifica di barabba; 23-01-12 alle 13:19
    powered by Google Ricordate che esiste il tasto THANKS
    Senior Droid L'avatar di tabaccaio
    Xoom MZ601 - Galaxy S3 I9003
    Ringraziato 205 volte in 182 Posts
    Che tu sappia ha qualche bug questa rom? Vorrei installare una rom ma sono indeciso su quale, quale mi consiglieresti per stabilità?
    Jan 2010
    se hai la versione solo wifi ti consigno di provare l ultima night dell eos team
    Ho la versione italiana wifi - 3g, è scritto anche sotto nella firma. L'ho comprato grazie alla promozione mediaworld il 22 Dicembre a 250 €. E' uno spettacolo . Qual'è la migliore per il mio modello?
    Jan 2010
    Ancora nulla per la versione 3g..ne sto provando io una in versione alpha..ma non funziona tutto...ti consiglio di aspettare qualche giorno..appena esce una rom stabile ics per xoom 3g la posto sul forum...ti consiglio di tenere la stock 3.2 honeycomb e installare solo un kernels..
    Sono poco pratico sul motorola xoom, quali vantaggi ne trarrei installando un kernels diverso? quale dovrei installare? per installarlo devo rootare lo xoom e installare anche la recovery? Scusami, ho visto l'altro thread che hai postato, se serve ti chiedo qualcosa di là......
    Ultima modifica di tabaccaio; 15-01-12 alle 10:38
    Jan 2010
    Quote Originariamente inviato da tabaccaio Visualizza il messaggio
    devi fare root e avere recovery modificata..il vantaggio è che abiliti l usb on the go..cioe puoi vedere le periferiche usb dall xoom come ad es. chiavette usb
