Pagina 3 di 3 primaprima 123
Visualizzazione dei risultati da 21 a 22 su 22
[ROM dump international version multilanguage/gapps/rooted] z7Max
  1. #21
    Sep 2014
    Quote Originariamente inviato da MadRob Visualizza il messaggio
    Niente di fatto, è la nubia v9.5
    Ciao a tutti,
    i will speak in english because a lot of english user don"t understand anything here, and this is the most active forum actually for the Z7 MAX.
    i'm this french guy who putted on xda some screens of the multi ROM, this is not a fake, some company put this rom on the phone before sending it (l e n t e e n . it by exemple, just check...)
    so, here is another MEGA link for those of want to create your rom, or for RayGlobe if he wanbt to make his rom multilangual.
    This is a system dump, without any password or encryption. Just download, cook your own rom and flash it. if you have NO WIFI, try to use the kernel of the official z7 before the 1.38 update.
    everything is working fine there. you can mount the system partition in the TWRP recovery and replace your /system and system/framework folder on the fly if you are not affraid, but be carefull about the WiFI if you are on RAYGLOBE, (i didn't try but i suspect it).
    if you need the kernel who work properly with it, i can give it to you too. just ask.
    link : https://mega.co.nz/#!rAtASaJR!QlA7aj...hOFEfEW4WNzkbw
    buona giornata
    Sep 2014
    I just found a link for a new rom for our Z7, with a lot of mod.
    Take a look here : bbs.nubia.cn/thread-256419-1-1.html
    Download link : h t t p ://yunpan.cn/QapaIGr5Jyaut . password "54c4"
