Pagina 18 di 19 primaprima ... 816171819 ultimoultimo
Visualizzazione dei risultati da 171 a 180 su 181
[Tool] Resize partition Z7 Max & Mini
  1. #171
    Quote Originariamente inviato da niza2000in Visualizza il messaggio
    Hi,
    Following steps i made for repartition for Z7 max and something went wrong, Pls help me to bring back my phone.
    As per instruction on post #84, i have made partition but in the second step it stuck in boot image chinese (I didn't get any message 'encription failed') then i press Volume down and power button to enter into recovery.
    I made data wipe, cache wipe and dalvice wipe and then i restore the Nandroid backup of BB1.64 rom which i used previously.
    After that i reboot the phone and stuck in again the boot image (Phone not go inside)
    Then i installed the official 1.59, Now phone is on and partition size increased, still facing problem in wifi and Bt.
    I put phone in recovery and when i click wifi.bat got error message phone not found, but when i go for mount USB storage phone in detected in CWM recovery.
    the Post of #119 link is broken, so i am unable to download.
    Please help me to restore wifi and BT and other help need sometime phone is off automatically every 10 mins once.
    Thanks in advance.
    Link on post 119 works....here you can find the file
    You should boot into recovery (CWM not TWRP), unzip file, be sure that PC recognize the phone and run RestoreWiFi.bat
    Cortesemente se qualcuno ha lo zip per il ripristino WiFi e BT da flashare via recovery che era stato postato da mastercut lo può ri-postare visto che il link non è più attivo? GRAZIE MILLE
  2. Il seguente Utente ha ringraziato BB72 per il post:
    niza2000in (02-04-15)
    Oct 2014
    Ringraziato 16 volte in 12 Posts
    Hi,
    I am in CWM and phone detect but when i click restoreWIFI.bat following message appeared:
    Please see the attachment.
  5. #173
    Senior Droid L'avatar di francj67
    OPTWO
    Ringraziato 70 volte in 62 Posts
    [quote name="BB72" post=6736482]Link on post 119 works....here you can find the file
    Hi,
    [/QUOTE]
    Io ce l'ho ma purtroppo non sono a casa.....
    One Plus TWO
  6. Il seguente Utente ha ringraziato francj67 per il post:
    BB72 (02-04-15)
  7. #174
    Oct 2014
    Quote Originariamente inviato da francj67 Visualizza il messaggio
    Hi,
    Inviato dal mio NX505J usando Androidiani App[/QUOTE]
    Hi Friends,
    Please help, my phone is detected in CWM but wifi restore is not successful..
  8. #175
    Oct 2014
    Hi,
    Hi BB72,
    Can you please guide me, my phone is detect in cwm or not.
    I installed all adb drivers, when i click mount usb storage i am able to transfer file from PC to SD Card00.
    Please help me to recover my wifi and BT.
    Thanks in advance.
  9. #176
    [quote name="niza2000in" post=6736547]Hi,
    Hi BB72,
    Thanks in advance.[/QUOTE]
    This is strange....if you enter recovery (CWM 6.0.5.0) and connect phone to PC, do you see device into Windows control panel devices?
    Anyway just wait until francj67 share the WiFi and BT patch you can simply flash via recovery....unfortunately I don't have it....
    Inviato dal mio LG-D858HK usando Androidiani App
  10. #177
    FIX WiFi & BT
    Per ripristinare il WiFi e BT nel caso vengano persi dopo partizionamento fare il flash da recovery di questo zip
    Funziona sia per z7Max che z7Mini
  11. #178
    Oct 2014
    Ciao a tutti,
    ero fermo alla 1.48 di BB72, ho seguito la procedura al post #143 fino a quando, lanciato il resize,
    boot in recovery con errori evidenti di lettura dello storage SDCARD0
    - factory reset + clear cache + dalvik
    - mounts & storage -> format SDCARD0
    - mounts & storage -> mount usb storage -> connesso cavo al pc (dal pc vedo che è da 20 gb quindi il resize dovrebbe essere andato a buon fine)
    - copiato dal pc il backup di SDCARD0 precedentemente effettuato
    - unmount usb storage
    - restore Nandroid backup da SDCARD1
    - reboot
    dopo l'immagine di boot lo schermo si spegne e non va oltre..ripetuta l'intera procedura due volte ma nulla...
    Mi chiedevo se a questo punto posso, visto che comunque posso entrare in recovery, posso provare a installare la TWRP e poi la rom 1.64 secondo la procedura descritta nel post di BB72...oppure devo seguire la procedura per il soft brick?
  12. #179
    Quote Originariamente inviato da notoriuss Visualizza il messaggio
    Ciao a tutti,
    - reboot
    Potresti provare con la 1.64 ma secondo me meglio prima installare la rom della guida softbrick tramite fastboot
  13. Il seguente Utente ha ringraziato BB72 per il post:
    notoriuss (22-04-15)
  14. #180
    Oct 2014
    Ho voluto provare direttamente la 1.64 visto che comunque sia recovery che bootloader funzionano...al termine dell'installazione ho avuto solo un errore sui permission comunque sembra andata a buon fine. Dopo il reboot però è da 15 minuti che sono fermo alla scritta iniziale nubia (prima scritta del boot)...comincio a temere che sia passato troppo tempo ..
    Provato con la procedura per risolvere il soft brick...ma rimango fermo sempre allo stesso punto del boot...durante l'installazione della 1.29 attraverso il file batch ho visto il messaggio "partition table doesn't exist".
    Ultima modifica di notoriuss; 22-04-15 alle 23:58
