Pagina 1 di 4 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 31
The ColorOS 2.0.0 UFFICIALE per FIND- QHD e FIND7a
    Mar 2009
    The Android KK 4.4 ColorOS 2.0.0 UFFICIALE per FIND- QHD e FIND7a
    Un po' sotto tono questo forum....
    KITKAT 4.4
    CHANGE LOG
    • Refined UI Design
      has inherited the UI design of ColorOS 1.0, by removing redundant elements from the 1.x icons the new design are more minimalistic and easier to recognize.
    • Global Gaussian Blur Effect
      System wide Gaussian blur effect makes the whole system looks more beautiful and consistent in different interfaces, such as the notification center, folders, music now playing interface etc.
    • System Wide Animation
      The ColorOS 2.0 is more energetic, with system wide transition animation the whole system comes alive, each operation seems so natural and fluid.
    • Live Weather 2.0
      Added a new weather effect "Haze", given sound effects for some effects and you may found more surprises when using the live weather 2.0.
    • Global Gesture Panel 2.0
      The new gesture panel is now activated by slide up from the bottom of the screen. Each gesture you've used can be recorded and shown on top as a reminder.
    • Redesigned Task Manager
      The new task manager design shows every task running in background as a card you can simply slide it up to close it or slide it down to lock it or tap the end all button to close them all (locked apps will not be closed).
    • Easy Crop for Screenshots
      After you've taken a screenshot you can pull down the notification center to crop, share or delete it.
    • Single Layer Launcher
      The changing from dual layer to single layer launcher is not simple a win/lose situation, both design has it's own advantage and disadvantage. ColorOS decided to go with single layer design is just another step towards the purse of simplicity and perfection.
    • Super Power Saving
      By reducing animation, underclocking the CPU or shutdown all applications except for calls and messages your phone can be under deep power saving mode so as increase the battery life as much as possible.
    • Memory Cleaner
      Added "Memory Cleaner" in security center, which enables you to control and release memory more easily.
    Other Detailed Improvements
    • Redesigned the guide interface, now it's able to auto select the language according to your SIM card
    • Changed the default lockscreen to "Slide upward to unlock", added Call & Messages shortcut in the default lockscreen
    • Added the double tap to blurry the wallpaper in Settings ->Gesture & Motion -> Screen-on Gestures
    • Added the feature to show network speed in status bar, Settings -> Display -> Show network speed
    • Added resolution settings for ultra-HD photos, you can now choose between 50MP and 24MP
    • Added continuous play settings in video player, when you disabled it the player will not continue to play the next video in your phone
    • Added USB debug options in notification center, when your phone is connected with your computer
    • Added the ability to manually adjust the screen brightness when auto-brightness is enabled
    • Added file safe in the "Files" app, files added into file safe will not be shown publicly
    • Added the ability to sort contact list by Given name/Family name
    • Added a quick to top button in Files, Email and Message list interface
    • Optimized the cleanup feature in "Files", added the function to delete large files and duplicated app installation package.
    • Redesigned the calendar interface, which is now more elegant
    • Removed the "Notes" app and replaced it with Google keep as the default note app
    • Optimized the "Backup & restore" app improve the back/restore speed and added the ability to backup homescreen layout, so that your apps & folders will all be backed up
    • Integrated all security related tools into "Security Center", such as App Encryption, Data Saving etc.
    • Updated the pre-installed Kingsoft Office app
    KNOWN ISSUE
    After you flash this version you cannot flash back to 1.2.x version directly, for Find 7a users you can flash the ColorOS V2.0.3i Beta first then flash back to 1.2.x version, for Find 7 users please flash this recovery here (Find 7 Recovery.zip) then flash the 1.2 version.
    OTA
    As this stable version is not for mass production, OTA is not available for this version.
    Download (Full Package)
    Filename: X9006&X9076ColorOS_V2.0.0i_full.zip
    File size: 914MB
    MD5: 3631987E53E3F61E86F33C47AE864F2A
    Download link: CLICK HERE
    Note:
    1. This update will wipe user data, please backup your data (you can use the Backup & restore app) before updating. Data on you phone storage such as movies and photos will not be affected.
    2. If you are using unified storage beta version, to flash this version please un-unify it by running the partition tool again before you flash this version(make sure your've backed up everything before un-unify).
    Preparations:
    • Download the firmware and copy it to the root directory of you phone storage.
    • Make sure you got enough battery left ≥ 30% would be better.
    Here we begins:
    1. Turn off the phone.
    2. Hold down Power key + Volume down key at the same time, when OPPO logo appears release your fingers, after a few seconds you'll enter recovery mode.
    3. Select the Language. (OPPO recovery support touchscreen operation, if your recovery is the early version which doesn't support touchscreen operation you can use Volume up/down keys to navigate and use Power key to confirm).
    4. To make a clean install please select "Wipe data and cache", press "Yes" when it's done.
    5. Select "Install from sd"
    6. Tap the firmware you've downloaded and press "Yes", the updating will finish in a few minutes.
    7. When the update is finished tap "Reboot" to finish updating.
    how-to-flash-firmware-using-recovery-mode
    Ultima modifica di dgardel; 17-10-14 alle 23:44
    Androidiano L'avatar di Silangel
    Apr 2011
    Oppo Find 7a
    Sembra che installando però questa versione, non si avranno più gli aggiornamenti OTA, in quanto non è una versione stabile e ufficialmente distribuita via OTA appunto, ma solo messa a disposizione di utenti più smaliziati. Meglio attendere la versione definitiva di metà Novembre, cosi si vocifera e consiglia.
    Inviato dal mio X9006 usando Androidiani App
    continua.mente
    Appena messa a scaricare!
    Senior Droid L'avatar di spiritualized
    Apr 2010
    nokia lumia 820 (muletto)
    Ringraziato 73 volte in 53 Posts
    La scarichero appena mi arriva il piccolino?
    La cina è buona per le cinesi e per gli smarthphone.
    Androidiano L'avatar di ceromaxair
    Cybertron
    Oppo Find 7A
    Qualcuno l'ha giá provata?
    continua.mente
    Io l'ho installata ieri.
    Cybertron
    Oppo Find 7A
    Quote Originariamente inviato da continua.mente Visualizza il messaggio
    Impressioni? Bug? Come ti trovi?
  9. #8
    continua.mente
    Non è molto diversa dalla beta. Per ora ho riscontrato solo un bug nella lockscreen ovvero non vengono memorizzati i widget della lockscreen messi al posto di quello di default con orologio e meteo o per lo meno non viene salvato quello di chronus
  10. #9
    Apr 2010
    Oggi mi è arrivato il mio oppo find 7 qhd che faccio la installo subito secondo voi?
    Sono molto tentato
  11. #10
    continua.mente
    Quote Originariamente inviato da spiritualized Visualizza il messaggio
    Sono molto tentato
    Installa pure! Per l'utilizzo quotidiano va benissimo.
