Utente del mese: megthebest con ben 22 Thanks ricevuti nell'ultimo mese
[APP][4.0+] ★ SelfieMap - the new way to check-in ★
    Baby Droid L'avatar di zlio
    Jan 2014
    Thumbs up
    Selfie + Map = SelfieMap
    ★ The new way to check-in ★
    Are you getting tired from the Facebook check-in options ??
    Did you ever leave the location and forget to do your check-in ??
    SelfieMap is a free app that finally allows you to do your check-in like you want to…
    SelfieMap App is here to break all the old check-in rules!!!
    SelfieMap is the only app that let you design and create your own style check-in:
    • Place your selfie picture, or any other picture on your location map!
    • Select the map type!
    • Select your desired location, even if you are not there anymore!
    • Design your picture using DreamBit's image processing special effects and filters!
    • You can add more than one picture to your designed check-in!
    • Add special designed objects – symbols (like emoji), text, drawing…
    • Design your check-in frame!
    In just 2 steps and your SelfieMap check-in is ready to share with Facebook, Instagram, WhatsApp or any other app you want to share your new SelfieMap:
    Step 1: Make a selfie for your SelfieMap check-in.
    Step 2: Open the SeflieMap app and select your selfie picture or any other picture.
    That's it, your SelfieMap check-in is ready !!!
    The SelfieMap app integrates your picture and your location map automatically!!!
    Google Play link:
    GOOGLE PLAY
    Androidiano VIP L'avatar di royy7
    Samsung Galaxy S4 - GT-I9505
    Ringraziato 1,139 volte in 1,019 Posts
    In italian.......
    Please
    Closed
    In italiano.......
    Chiudo....
    Ultima modifica di royy7; 23-07-15 alle 21:05
    Device: Samsung Note Edge 32 GB Black ITV - No Brand - 4.4.4 (tutto stock)
    Device: Samsung Galaxy S4 16GB Black Mist ITV - No Brand - 4.3 (tutto stock)
    Operatore: Tim
    Ext SD: SanDisk MicroSDHC 32gb Classe 10 UHS-I
    Accessori: Samsung S-View Cover Black ; Galaxy Gear JetBlack
