Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 11
[KERNEL] [TC] [STABILE] TC Custom Kernel
    Androidiano L'avatar di niicko96
    Nov 2013
    Ringraziato 63 volte in 62 Posts
    Vi riporto qui il nuovo custom kernel creato da zwliew e presentato su xda.
    Questo kernel si basa sul kernel del TC,flashando questo kernel si può avere una miglior durata della batteria e un aumento delle prestazioni.
    Questa è la lista delle rom compatibili:
    Android 4.4 Kitkat
    CyanogenMod 11.0
    OmniROM
    Carbon
    Beanstalk
    C-ROM
    Mahdi-ROM
    Ressurection Remix
    SlimKat
    LiquidSmooth
    AOSPA 4+
    Download TC Custom Kernel by zwliew - xda-developers DevDB
    Link discussione Xda [KERNEL][TC][STABLE][20140423] TC Custom Kernel - xda-developers
    Contributi e Ringraziamenti
    zwliew
    Kernel Special Features: Performance, Battery, Regular updates
    Version Information
    Status: Stable
    Current Stable Version: 20140423
    Stable Release Date: 2014-04-23
    Created 2014-04-20
    Last Updated 2014-04-23
    NE IO NE ANDROIDIANI CI ASSUMIAMO ALCUNA RESPONSABILITÀ PER PROBLEMI VARI CON QUESTO KERNEL
    Ultima modifica di niicko96; 01-05-14 alle 19:07
    Se vuoi ringraziarmi clicca il tasto thanks
    Nov 2013
    Changelog:
    20140501
    [ADDITION]
    add sweep2wake timeout toggle and duration setting [TEST]
    [IMPROVEMENT]
    sioplus: update from boy peterson
    abb-fg: fix laziness on low capacity
    abbamp: abbamp 2.5.0
    bfq: update to v7r3
    ext4: performance improvement
    interactive: performance improvement
    20140430
    Reverted Interactive to stock from android-3.4 branch + commits from CAF (going to redo this)
    Changed to LZ4 instead of LZO (faster decompression, albeit a little larger file size)
    Faster compression/decompression
    Faster boot-up
    Update cubic to LK 3.0.101
    random entropy tweaks
    Reduce wifi wakelocks in suspend
    Re-added Interactive touchboost and tuned Interactive
    Some misc patches
    20140427
    Improvements to touchboost in Interactive
    Performance and battery tweaks in Interactive
    Set sched_mc to 0 for better performance (especially in hotplug governors)
    fs improvements
    20140426
    Re-enable performance governor
    Remove intelliactive governor
    Add Interactive touchboost and screen-off hotplugging
    Interactive updates from CAF(more sysfs entries and code improvements)
    ARM decompressor code optimization
    LZO Upstream Update
    Updates from previous release
    mm performance improvement
    TCP throughput improvement
    20140425 BOTCHED UPDATE
    Remove zzMoove and Lagfree governors
    General I/O speed improvements
    Made ROW default scheduler
    ROW updates and improvements
    Deadline scheduler latency and read speed improvement
    Remove sio scheduler
    20140424
    Actually enable zzMoove governor
    Tweak Intelliactive for more performance
    Add screen-off hotplugging for Intelliactive (better battery)
    Disabled useless governors (Performance, Powersave, Userspace)
    20140423
    Enable governors and schedulers added previously
    Added Intelliactive (default)
    20140422
    Backport android-3.4 interactive governor
    Add lagfree and zzMove governors
    Add row and bfq schedulers
    Some readahead patches to improve IO
    Compiler -O3 and other optimizations
    20140421
    Cortex-A9 compiler optimizations
    Better power management for CPU scheduling
    KSM performance improvements
    Square root function performance improvements
    20140420
    Based off TeamCanjica CM kernel
    Build with Linaro GCC 4.7.4
    Enable and set Interactive CPU governor as default
    Ultima modifica di niicko96; 01-05-14 alle 19:10
    Androidiano L'avatar di Pietrotti
    Aug 2013
    Rovigo
    Galaxy Ace 2, Nexus 5
    Overclock??
    Inviato dal mio GT-I8160 usando Androidiani App
    Nov 2013
    Quote Originariamente inviato da Pietrotti Visualizza il messaggio
    Overclock??
    Si è possibile
    Raga,scusatemi ma qual'è la procedura per fare il flash del kernel ?
    Androidiano VIP L'avatar di pedroleon99
    A casa mia
    Galaxy S4;Ace 2;Pocket Plus
    Ringraziato 621 volte in 516 Posts
    Quote Originariamente inviato da gribo Visualizza il messaggio
    Entri in recovery poi vai su apply update selezioni lo zip e lo installi
    In un forum il tasto thanks è un diritto ma usarlo è un dovere
    Samsung Galaxy Ace 2 ROM: Cyanogenmod 13.0
    Kernel: Chrono kernel
    Samsung Galaxy Pocket Plus ROM:Stock 4.0.4 prerooted
    Kernel:Stock
    Samsung Galaxy S4 ROM: Astra Note 5 Port
    Kernel: Stock kernel patched
    Quote Originariamente inviato da pedroleon99 Visualizza il messaggio
    Quindi non bisogna usare alcuno script di pulizia come si fa ad esempio per il Galaxy S3 ??
  9. #8
    A casa mia
    Nono non c'entra niente
    Kernel:Stock
  10. #9
    Ho flashato il kernel con successo ma da quando l'ho fatto ho visto che su whattsapp non riesce più ad inviare foto ed al posto della foto apare un riquadro biancastro con la scritta Riprova......che fare???
  11. #10
    Piemonte, IT
    Su Ace2nutzen ci son quelli aggiornati al 2015... io ne ho installato uno di febbraio, vi metto il link:
    [Kernel] [3.0.101] [4.4.x] [TeamCanjica] Ace… | Samsung Galaxy Ace S5830, S5830i, Ace II | XDA Forums
    Il dispositivo mi va abbastanza bene... provatelo!
    Ultima modifica di ChrisPDN; 04-03-15 alle 16:14
