Oggi vi presento la liquidsmooth 4.4.2,questa rom si basa sul progetto dell AOSP con l'aggiunta di qualche caratteristica,quindi una rom molto leggera e veloce.
Features
Linaro 4.7 GCC Toolchain
3.0.101 Kernel
O3 Strict-Aliasing & ISO C++11 Mode
ARM Optimized String Handling Routines
Linaro and Code Aurora Optimaztions
Slims DPI on the fly
Custom animation controls
TRDS 3.0 (Liquid Blackout in settings)
Active Display
Slims QuickSettings
Halo (Renamed to bubble in settings)
Ram Bar
T-Mobile Theme Engine
Privacy Guard
Built in SuperUser
Working wifi Tethering
Cell Broadcasts
Slims Configurable Power Menu
Slims Configurable Nav Bar
Gamma Configuration support
Custom animation controls (Listview)
LockScreen Notifications
And way more than this...
INSTALLAZIONE
Download ROM and GApps from the links below
Put the files on SDCard
Reboot in Recovery
Wipe Data/Factory Reset
Format /System
Select "Install Zip from External Storage"
Choose ROM zip file
Choose GApps zip file
Reboot System
DOWNLOAD ROM http://www.drdevs.com/devs/teamliqui.../Galaxy_Ace_2/
GAPPS http://forum.xda-developers.com/show....php?t=2397942
Oppure le aroma gapps https://www.androidiani.com/forum/sa...p-remover.html
Credits
LiquidSmooth Team
TeamNova
TeamCanjica
Contributors
iiD4x, Rox, Tesla-MADAL93, TeamCanjica
ROM OS Version: 4.4.x KitKat
ROM Kernel: Linux 3.0.x
ROM Firmware Required: Any Ace II JB firmware
Based On: AOSP Based
Version Information
Status: Beta
Beta Release Date: 2014-04-21
Tips :
First boot takes a while. Wait at least 5 mins for it to boot.
To activate Developer settings : Settings -> About phone -> press Build number 5 times
To activate 3-way reboot go to Developer settings and select "Advanced reboot"
First Wi-Fi connecting can take a while
ART booting can take about 10 minutes so be patient
You can switch internal and external storage in Ace 2 settings
Swap storages ( Old method ) :
-1. Download http://forum.xda-developers.com/devd...ct/dl/?id=2647 from Download section and move it to /data
2. Download https://play.google.com/store/apps/d....scriptmanager
3. Open StoragesSwap.sh with Script manager and set SU and Boot icon
4. Reboot!
Link discussione xda http://forum.xda-developers.com/show....php?t=2653156
NE IO NE ANDROIDIANI CI ASSUMIAMO ALCUNA RESPONSABILITĄ PER PROBLEMI VARI CON QUESTA ROM
Screenshots e foto della rom vedere allegati (se qualcuno prova questa rom ne faccia un paio che io le pubblico)
