Pagina 137 di 184 primaprima ... 3787127135136137138139147 ... ultimoultimo
Visualizzazione dei risultati da 1,361 a 1,370 su 1839
[DEV/WIP][JB] CyanogenMod 10 and 10.1 for GT-S7500
  1. #1361
    NAPOLI
    Galaxy ace plus + smartpad 711
    Verissimo poi scusate forse l'avete già scritta questa cosa: come si fanno i video che si vedono??
    Inviato dal mio GT-S7500 usando Androidiani App
    Pubbliche vi amee!
    Possessore di un galaxy ace plus
    Rom: cyanogenmod 10.1.2 con camera funzionante temata touchwiz 5
    Quote Originariamente inviato da falconek
    Videocam illusion, però a me va scatti...
    My Work
    • Samsung Galaxy Wonder
    • Samsung Galaxy Mini (Next): [DISCONTINUED][GPL][ROM][CM 10.1][V 5] TouchWiz 5, [RECOVERY] CWM-5.2.0.8 Touch2;
    My Devices
    • Samsung Galaxy Ace Plus: [ROM] Alchemy, [KERNEL] Nuovo Custom Kernel Per GT-S7500 by Lox, [RECOVERY] CWM_V6.0.1.2_GT-S7500;
    Enjoy!
  4. #1363
    NAPOLI
    Quote Originariamente inviato da Zanna18
    Ciao grazie mille, a me non va a scatti
    Pubbliche vi amee!
  5. #1364
    Napoli
    galaxy gio, galaxy ace plus
    Ringraziato 87 volte in 27 Posts
    AGGIORNATE IL POST.
    SUL SITO XDA E' USCITO UN'AGGIORNAMENTO DELLA CYANO 10.1 IL 13/07/13
    13/07/2013 - 6PM GMT+3 - CyanogenMod 10.1
    * CyanogenMod 10.1.2 ( includes "master key" fix )
    * Fix VoIP in Hangouts
    * Add stock Email app that was missing
    * Add zRam and SWAP support
    * Fix taking pictures in all camera apps
    * Fix video recording (currently broken on stock camera app, works on rest of the apps)
    * Added option to enable/disable waking phone with home and volume keys
    * Update USB Gadget from CAF ics_chocolate branch
    * Update MSM MDP & FB from CAF ics_chocolate branch
    * Improved HW V-sync
    * Switched to MDP composition type
    * Update Adreno libs
    * Fix Wi-Fi AP (tethering)
    * Fix A2DP HAL loading
    * Cleaned up to reduce build size ( ~155MB > ~132MB )
    * Other minor fixes/improvements
    NOTE 1: Performance is highly improved
    NOTE 2: It's recommended to wipe data/factory reset
  6. #1365
    Androidiani Power User L'avatar di imre
    Bologna
    Nexus 5
    Ringraziato 1,000 volte in 466 Posts
    se non funziona l'autofocus è ovvio che non vengano benissimo le foto
    Alchemy ROM per Samsung Galaxy Ace Plus
    se vuoi ringraziarmi usa il tasto thanks
  7. #1366
    Behind you
    SGAP + Nexus 7
    Ringraziato 73 volte in 62 Posts
    Quote Originariamente inviato da aquila989
    AGGIORNATE IL POST.
    cosa continuo a dire?! sono in vacanza, deduzione logica:
    è già tanto se vi rispondo sui thread.
    seconda deduzione:
    non c'è Wi-Fi, quindi non posso editare il post da un computer.
    poi, perché hai usato il block maiuscola?!
    infine, in conclusione se non la smettete di spammare il changelog, allora incominciò anche io a spammare come un cr***** ahahhsnsjdm nr
    nxnkznjf
    xbdnddllrldosodpdlfldnmf
    nnxkdixlfxp
    cnfjfkkfppfofpclff
    fmfmffklfof
    trolololololololol ohohoh... ttatata trololollkoll ohohoh ohohoh
    Janice ckcjfodkdkdkff
    xjjfkfkfkkfckgkfkflfkfkg
    fjjfkfkfkkckfkfllclalsls
    amhwiwoldkdlcldkdjciqpzoe
    xjskkdDof
    GT-S7500 - CM10.2 DirtyDev
    Nexus 7 2012
    CyanFox 2.0.1
    WHAT DOES THE FOX SAY?
    LOL
  8. #1367
    Androidiano VIP L'avatar di smartandroidtech
    Ringraziato 163 volte in 114 Posts
    The Whisp(riguarda al mini II):
    progress update on 3.0 kernel:
    3.0.64
    Bugs:
    Wi-Fi doesn't work
    Bluetooth doesn't work (should be an easy fix, needs some regulator changes)
    NFC doesn't work (maybe it does, I can't test)
    Camera cannot take pictures (should also be an easy fix)
    Device turns off when not connected to power source (when it goes into deep sleep, I suppose)
    Everything else seems to be working.
    PC:
    *CPU: Intel Core I5 3470 3.2GHz.
    *RAM: 8GB.
    *GPU: ZOTAC GeForce GTX 970 AMP! Extreme Core Edition
    *HDD: 1TB WD.
    *MotherBoard: Asus P8H77.
    Google Nexus 5:
    *Versione Android: 6.0.0
    *Rom: Stock
    *Kernel: Elemental X 6.00
  9. #1368
    Quote Originariamente inviato da smartandroidtech
    3.0.64
    Bugs:
    Wi-Fi doesn't work
    Saranno bug di build vecchie, xk ha fixato tutto. Ora solo l offline charge non funziona nell ultima build!
    My Work
    My Devices
    Enjoy!
  10. #1369
    Napoli
    Ace Plus, Moto G e Nexus 5 Bia
    Noo questi sono bug sul kernel 3.0.64 !!!
    inviato dal mio ace plus jelly bean *___* e galaxy tab 2
    LG Nexus 5 by Google
  11. #1370
    Quote Originariamente inviato da Zanna18 Visualizza il messaggio
    Leggi bene e ti accorgerai che ha scritto(più o meno) "aggiornamento sullo sviluppo del kernel 3.0.64"
    EDIT: The Whisp va come un treno, arriva un nuovo comunicato riguardante il kernel 3.0.64 sul mini II:
    Camera and Bluetooth is now working.
    Wi-Fi is work-in-progress.
    edit: NFC is also probably working.
    So only bugs are Wi-Fi and that sleep issue (which, I think, is caused by vibrator regulator problem)
    Anche se del mini II credo che lo sviluppo sarà più o meno lo stesso anche su ace plus, quindi quando quello per mini II sarà pronto, dopo qualche giorno/settimana uscirà anche per ace plus.
    Ultima modifica di smartandroidtech; 26-07-13 alle 14:15
    PC:
    *RAM: 8GB.
    *HDD: 1TB WD.
    Google Nexus 5:
    *Rom: Stock
