[DEV][4.2.2] Cyanogenmod 10.1(cm10.1) [WIP]
    Androidiano VIP L'avatar di smartandroidtech
    Ringraziato 163 volte in 114 Posts
    [ACE PLUS][DEV][Android 4.2.2] Cyanogenmod 10.1(cm10.1) [WIP]
    CyanogenMod is a free, community built distribution of Android 4.1/4.2.x (Jelly Bean) which greatly extends the capabilities of your phone.
    Code:
    #include
    * Your warranty is now void.
    * I am not responsible for bricked devices, dead SD cards,
    * thermonuclear war, or you getting fired because the alarm app failed. Please
    * do some research if you have any concerns about features included in this ROM
    * before flashing it! YOU are choosing to make these modifications, and if
    * you point the finger at me for messing up your device, I will laugh at you.
    Code:
    CyanogenMod is based on the Android Open Source Project with extra contributions from many people within the Android community. It can be used without any need to have any Google application installed. Linked below is a package that has come from another Android project that restore the Google parts. CyanogenMod does still include various hardware-specific code, which is also slowly being open-sourced anyway.
    All the source code for CyanogenMod is available in the CyanogenMod Github repo. And if you would like to contribute to CyanogenMod, please visit out Gerrit Code Review. You can also view the Changelog for a full list of changes & features.
    Cosa funziona:
    * Accelerazione completa della GPU
    * BLUETOOTH
    * Wi-Fi
    * Touchscreen
    * Tasti Touch
    * Multi-Touch
    * Audio
    * UMS
    * Luci dei tasti
    * Controllo luminosità
    * Vibrazione
    * Risveglio(Deep Sleep)
    * GPS
    * Sensori (Tutti, Rotazione)
    * Data usage, limiter
    * Day dream
    Cosa NON funziona:
    * Camera
    * Galleria
    * telefonia
    * USB, Wi-Fi, Bluetooth tethering (usare app di terze parti)
    * TELEFONIA
    * USB NON MONTATA (Nè interna nè esterna)
    * ADB
    Video:
    ROM:
    Guida all'installazione della ROM:
    Occorrente:
    Root(Guida by Imre: https://www.androidiani.com/forum/sh...d.php?t=216878)
    Cwm(Guida by Imre: https://www.androidiani.com/forum/sh...d.php?t=184733).
    Scaricare i files(in fondo sotto la voce ROM)
    Installazione:
    Mettere il file .zip nella SD esterna.
    Riavviare lo smartphone in recovery mode.
    Entrati nella recovery(cwm)selezionate wipe data e cliccate su "yes".
    Eseguire lo stesso procedimento per wipe cache.
    Andare nel menù advanced ed eseguire wipe dalvik cache.
    Adesso tornate indietro e selezionate "install zip from sdcard".
    Adesso su "choose zip from sdcard".
    Selezionate il file della CM.zip ed installatelo.
    Download (Data release: 06/03/2013): https://www.dropbox.com/s/dlc25fmiv1...d-trebon.zip?m
    Kernel:
    Guida all'installazione del Kernel:
    Una volta scaricato il kernel rinominatelo "boot.img"(senza le ").
    Se non lo avete già fatto scaricare la versione della ROM più recente.
    Decpmprimere il file .zip della ROM(con 7zip).
    Sostituire il kernel rinominato in boot.img con il boot.img della ROM.
    Al termine dell'operazione ricomprimete in .zip.
    Installazione:
    "Nessun nuovo kernel al momento disponibile."
    Discussione su XDA: http://forum.xda-developers.com/show....php?t=2177002
    Nè io nè Androidiani.com ci assumiamo le responsabilità di eventuali malfunzionamenti !
    Ultima modifica di smartandroidtech; 06-03-13 alle 18:13
    PC:
    *CPU: Intel Core I5 3470 3.2GHz.
    *RAM: 8GB.
    *GPU: ZOTAC GeForce GTX 970 AMP! Extreme Core Edition
    *HDD: 1TB WD.
    *MotherBoard: Asus P8H77.
    Google Nexus 5:
    *Versione Android: 6.0.0
    *Rom: Stock
    *Kernel: Elemental X 6.00
  2. I seguenti 2 Utenti hanno ringraziato smartandroidtech per il post:
    imre (06-03-13),Mogno313 (06-03-13)
    Venezia
    Ace Plus, ace 2, gnex
    Ringraziato 17 volte in 9 Posts
    Grazie per i tuoi aggiornamenti ma credo che dovrebbero lavorare più sulla 10 che sulla 10.1 oppure concentrarsi del tutto sulla 10.1
  5. Il seguente Utente ha ringraziato Mogno313 per il post:
    smartandroidtech (07-03-13)
  6. #3
    Io direi tutto su questa perché se si toglie il bug della telefonia la ROM e apposto camera apparte
    EDIT: Poi quando funzionerà la camera avremo photosphere i widget nella lockscreen...
    Inviato dal mio GT-S7500 con Tapatalk 2
    Ultima modifica di smartandroidtech; 06-03-13 alle 20:59
    PC:
    *RAM: 8GB.
    *HDD: 1TB WD.
    Google Nexus 5:
    *Rom: Stock
  7. #4
    Androidiani Power User L'avatar di imre
    Bologna
    Nexus 5
    Ringraziato 1,000 volte in 466 Posts
    bella guida!
    Alchemy ROM per Samsung Galaxy Ace Plus
    se vuoi ringraziarmi usa il tasto thanks
  8. Il seguente Utente ha ringraziato imre per il post:
    smartandroidtech (06-03-13)
  9. #5
    Behind you
    SGAP + Nexus 7
    Ringraziato 73 volte in 62 Posts
    Non ne sono tanto felice, visto che ho provato la 4.2.2 sul mio nexus e devo dire ché è molto meglio la 4.1.2 (il secondo JB porta solo feature per lo più inutili, tranne la tastiera), ma forse sullo SGAP andrà meglio... Io comunque non la provo ancora finché non risolvono più bug..
    Inviato dal mio Nexus 7 usando Androidiani App
    GT-S7500 - CM10.2 DirtyDev
    Nexus 7 2012
    CyanFox 2.0.1
    WHAT DOES THE FOX SAY?
    LOL
  10. #6
    Un mio amico ha il nexus e non si è lamentato del 4.2.2 anzi 0.0
    PC:
    *RAM: 8GB.
    *HDD: 1TB WD.
    Google Nexus 5:
    *Rom: Stock
  11. #7
    Behind you
    SGAP + Nexus 7
    Quote Originariamente inviato da smartandroidtech
    Sicuramente la 4.2.2 è migliore della 4.2.1 e su questo sono d'accordo, ma non con il fatto che il primo JB sia uguale o inferiore per prestazioni al secondo JB..
    Inviato dal mio GT-S7500 usando Androidiani App
    Nexus 7 2012
    CyanFox 2.0.1
    LOL
  12. Il seguente Utente ha ringraziato troll4 per il post:
    newhalo (18-05-13)
  13. #8
    Ragazzi scusatemi ma questa rom a mio parere è inutilizzabile,x il semplice fatto ke sminuisce alcune funzioni fondamentali del nostro dispositivo,come la fotocamera e le chiamate,faccio il mio appello a chiunque scovi x primo una nuova versione di jb di postarla x noi tutti,il thank's è assicurato.... Ciao a tutti miei cari androidiani..e un saluto a imre nostro pilastro portante,tutti noi contiamo su di te! Forza imre!!!!!!!!!!!!!!!
  14. #9
    Io di bug fondamentale vedo solo la parte telefonica...appena aggiornano il kernel con il fix della parte telefonica io la installo subito
    PC:
    *RAM: 8GB.
    *HDD: 1TB WD.
    Google Nexus 5:
    *Rom: Stock
  15. #10
    Progetto abbandonato.
    PC:
    *RAM: 8GB.
    *HDD: 1TB WD.
    Google Nexus 5:
    *Rom: Stock
