Utente del mese: megthebest con ben 44 Thanks ricevuti nell'ultimo mese
Pagina 1 di 8 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 74
[ROM] Inspiration ROM by kk9999gada
    Samsung Galaxy Next S5570
    Ringraziato 224 volte in 195 Posts
    Inspiration_Rom_V13
    Inspiration_Rom_V13
    Features of V13 :
    • Based on Stock Rom(Gingerbread 2.3.6)
    • Pre-Rooted with BusyBox, Chainfire's Superuser & Chainfire's SU Binary for Better Rooting Experience
    • Blackburner's Non-OC Kernel for Stability & Performance
    • Deodexed so that you can get ICS / JB Experience
    • Removed Bloated Apps Shipped with Phone
    • Sound Enhancement with Beats Audio, XLOUD & MegaBassBeats for Ultimate Music Experience
    • Bravia Engine 2 for Improving Photo Quality [Experimental]
    • Init.d Support, Init.d Tweaks, Build.prop Tweaks for Improving Performance of Phone
    • CronMod A2SD++
    • Adobe Flash Player 11.1 for Improved Flash Experience
    • Improved Audio Quality for Crisp Sound Quality
    • ZRam Compression (64MB), Adrenaline Boost Script to Freeup More RAM
    • Kernel Tweaks for Better Kernel Performance
    • Custom Boot Animation for Increasing Awesomeness of Rom
    • DroidWall Firewall for Saving Your Data Plan by Blocking Apps from Accessing Internet
    • CRT-OFF Animation for making Lock Screen Fancy
    • JB Style Date & Time, 14-Toggle Mod Status Bar, Carrier Logo at StatusBar Bottom to Keep You in touch with ICS/JB
    • Transparent Notification & Pulldown Background, Transparent HomeScreen Status Bar
    • Blue Colored - Toggle Icons, Status Bar Icons, LockScreen Clock, Status Bar Clock for Even more ICS/JB Experience
    • New Black & Blue Themed User Interface
    • Swipe to Remove Notifications
    • Signal Tweaks for Better Signal Strength
    • Google DNS for Faster Internet
    • Added New HD Wallpapers, New Toast Notification Background
    • Circle Battery Percentage to Keep You Updated with Battery Status
    • Settings & RecentApps Shortcut on Status Bar for Reducing Your Efforts
    • Holo launcher & Holo Locker for More ICS/JB Experience
    • ICS/JB Themed Dialer, Alike Recent Apps, Icons, ProgressBar, Transitions, Sliders, Keyboard
    • ICS Style Settings so that the Settings Look more Organised
    • SuperCharger Script - So that you never go Out Of Memory and Low Memory
    • Zipaligned Apks', Defragged System, Improved Multi-Tasking for Snappier Performance & Faster Startup
    • Increased SDcard R/W Speed, Network Stability & Speed Tweaks, Scrolling Tweaks, to Save your Time
    • Camera Quality Tweaks & Increased JPG quality to 100% using Build.prop
    • Sqlite Tweaks for Improved Database I/O Performance
    • Improved Touch Responsiveness for more Snappier Performance
    • Battery Saving Tweaks for Extended Battery Life
    • GPS Configuration Tweaks (India) so that you can Search Yourself Faster
    • Google Services Updated to latest version to improve battery life
    • All the System Apps Updated to Latest Version so that the Rom can stay Healthy
    • AdAway AdBlocker (V2.1) so that Annoying Ads can be Kept Away
    • Thinkfree Office Pre-Installed to bring Office at your Palm
    • Play Store Updated to V4.1.6
    • Maps Updated to V6.14.4
    • Voice Search Updated to V2.1.4
    • Youtube App with Multiple Download Option
    • Some More Theming Stuff & Performance Tweaks
    __________________________________________________ ________________________________________________
    Download
    Inspiration ROM v13
    __________________________________________________ _________________________________________________
    Ciao a tutti (eh si...sono tornato..) volevo segnalarvi questa nuova rom scovata su XDA.
    Purtroppo io non possiedo più Ace Plus, ma da quello che leggo....è una raccolta di tweaks e script per far volare letteralmente il vostro GT-S7500.
    Dovrebbe essere più originale della Custom o della Atomblast (status bar modificata, insieme con bootanimation e menu a tendina delle notifiche oltre al CRT-OFF) come modifiche grafiche. Sul piano delle prestazioni abbiamo (avete....) tutti i tweaks possibili per gingerbread per migliorare le prestazioni (connettività generale, GPS, durata batteria, reattività del touchscreen.......)
    Istruzioni per l'installazione:
    COME SEMPRE, PRIMA DI EFFETTUARE OGNI TIPO DI MODIFICA AL DEVICE, EFFETTUATE UN SANTISSIMO NANDROID.
    1. Scaricate Inspiration_Rom_V13.zip
    2. Copiate lo zip sulla sd esterna
    3. Avviate in recovery mode
    4. Wipe Data / Factory Reset, Clear Cache & Dalvik Cache
    5. Selezionate install zip from sdcard > scegliete lo zip dalla sdcard
    6. Dopo aver selezionato Inspiration_Rom_V13.zip selezionate Yes per installare
    7. Attendete la fine del processo
    8. Riavviate
    Godetevi la ROM.
    Non mi assumo nessuna responsabilità in caso di danni irreparabili al vostro device, di esplosioni improvvise, fuoriuscite di gas, terremoti, inondazioni, litigi con la fidanzata, multe per divieto di sosta........
    Aggiornato da imre su richiesta di Raffbulgaro
    Ultima modifica di imre; 29-06-13 alle 11:21
  2. I seguenti 3 Utenti hanno ringraziato RaffBulgaro per il post:
    Ghost_01 (24-12-13),Strato92 (05-05-14),ticio (06-05-13)
    Senior Droid L'avatar di Alexaceplus
    Napoli
    Nexus 5
    Ringraziato 42 volte in 31 Posts
    carina..però se installi la mod atomods fai prima cioè la grafica è uguale la differenza è che questa è una rom
  5. #3
    Si, la grafica è quella....anche perchè è comunque GB, ma c'è qualcosa in più.
    Inoltre è cosi piena di tweaks............
  6. #4
    Non si può togliere la percentuale dei Kb usata per la ram che è perennemente presente sulla parte superiore a sinistra dello schermo? è un po' fastidiosa.. per il resto la ROM è bella.. attendo una risposta..
  7. #5
    Androidiano L'avatar di kingdoka
    Lg P990 white
    ciao volevo sapere quante differenze ci sono fra questa rom e la custom v4
    grazie in anticipo...
  8. #6
    ciao a tutti io ho scaricato il file dal FORUM XDA l'ho scompattato e dentro ci sono varie cartelle (data, Meta-inf,system etc. ) le ho copiate nella cartella dove ci sono i backup fatti con CWM ma qnd vado con la recovery non mi fa vedere il file "2012-11-18.07.42.02" ma solo il backup che ho appena effettuato ...... AIUTOOOOOOOOOOOOO
  9. #7
    Samsung Galaxy Ace Plus
    Ringraziato 271 volte in 209 Posts
    Quote Originariamente inviato da ticio Visualizza il messaggio
    Devi mettere l'intero archivio nella SDcard e fare "Install .zip from SDcard" --> "Choose .zip from SDcard"
    ROM: CyanogenMod 11 by DirtyDev
    KERNEL: 3.0.101 Dirty Kernel
    E se ti sono stato d'aiuto non dimenticare il tasto thanks
  10. Il seguente Utente ha ringraziato loxdegio per il post:
    ticio (07-05-13)
  11. #8
    Su xda c'è la versione aggiornata:
    Inspiration V12
    Ultima modifica di samsungniano; 20-05-13 alle 17:29
  12. #9
    Androidiano VIP L'avatar di Giugiu19
    Porto Torres
    Galaxy S5mini (SM-G800F)
    Ringraziato 698 volte in 354 Posts
    Quote Originariamente inviato da samsungniano Visualizza il messaggio
    Inspiration V11
    veramente ce la versione v12
    Seguimi su Twitter per informazioni su nuove uscite e aggiornamenti!@Giugiu19
    per chi vuole donare per sostenere lo sviluppo
  13. #10
    Quote Originariamente inviato da Giugiu19 Visualizza il messaggio
    Mi sono corretto, infatti.
