Pagina 5 di 6 primaprima ... 3456 ultimoultimo
Visualizzazione dei risultati da 41 a 50 su 55
Drakaz fix per sistemare il bug del consumo della batteria nei firmware 1.6
  1. #41
    Senior Droid L'avatar di LudoB
    Jul 2009
    Nexus S, Nexus 7, Nexus 4
    Ringraziato 119 volte in 95 Posts
    Uppato ora su megaupload, l'ho recuperato nella cartella tools del mio sdk e l'ho zippato
    MEGAUPLOAD - The leading online storage and file delivery service
    Apr 2010
    Ornavasso(vb)
    NEXUS S-LG G3
    grazie mille!!
  4. #43
    Senior Droid L'avatar di ChIP83
    Jul 2009
    S7 edge
    Per comodità vi copio quello che c'era scritto sul sito di drakaz:
    All Galaxy’s users are aware of the no-sleep bug, fixing the device in a bad sleep status, after using Android’s geolocalisation feature,such as google map.
    jakax found the patch on offical Android git and build the first patch, (No sleep has nothing to do with anything - Page 2 - Android Forums), many thanks to him.
    However, the first patch was really difficult to apply, and we could loose some specific features from our galaxy, by replacing Samsung’s apk and odex by aosp one.
    I rebuilded the patch from scratch, then extract (deodex) the class from the AOSP patched version, and merge it into the official Samsung’s odex.
    And voila, an easy to use-and-install geolocalisation patch for Galaxo.
    How-to :
    adb remount
    adb push services.odex /system/framework/
    adb shell reboot
    enjoy
    Io l'ho appena installato, vediamo domani come va...
    HTC Desire (ex. Samsung Galaxy i7500)
    • Device: HTC Desire AMOLED PVT1 Rooted by Unrevoked 3
    • Rom: Mildwild CM A2SD+ 4.3 (Android 2.3.7) con kernel ManU-Version 2.1 HAVS-AXI-CFS
    • Recovery: Alpharev Recovery S-OFF - Radio: 32.56.00.32U_5.17.05.08
    • SD: Samsung 16GB classe 6 - 1GB ext3 / 15GB Fat32
  5. #44
    Jun 2009
    ALLORA SE HO CAPITO BENE PER INSTALLARE da neofita che sono:
    1. copio i file nella cartella tool della sdk
    2. entro nella finestra command
    3. poi collego il cell in fastboot
    4. e do le linee di comando una alla volta
    5. adb remount (invio)
    6. adb push services.odex /system/framework/ (invio)
    7. adb shell reboot (invio)
    cosi?
  6. #45
    Jul 2009
    Quote Originariamente inviato da hood Visualizza il messaggio
    cosi?
    Non serve mettere il telefono nè in fastboot nè in recovery nè altro, va benissimo acceso normalmente.
    Attacchi il cavo usb, metti il telefono in debug mode(necessario per far funzionare adb) e dal prompt dei comandi del tuo pc dai le linee che hai scritto sopra.
  7. #46
    Dec 2009
    46 ore dall'avvio, 68% di batteria, geolocalizzazione attiva e processore che va in sleep regolarmente.
  8. #47
    Jul 2009
    S7 edge
    Da quello che ho visto in questi giorni, anche con il fix la batteria fa sempre abbastanza schifo. Molto probabilmente perché io non usavo la geo localizzazione e quindi non ho tratto alcun beneficio dalla patch.
    Galaxo 1.6.2 + fix drakaz + overclock widget (128/256 stand-by e 256/528 on)
    2G sempre attiva con sincronizzazione, poche chiamate, consultazione di mail e qualche paginetta abbastanza frequente, partendo dalle 8.30 del mattino, arrivo verso le 9/9.30 con il 45/50% di carica residua.
  9. #48
    Senior Droid L'avatar di pablhobbit
    Mar 2010
    Ringraziato 36 volte in 26 Posts
    non so che dire ragazzi... per me funziona alla grande!
    geolocalizzazione attiva, poche chiamate, "buon" utilizzo di internet (browser, tapatalk, gmail, gtalk ecc.), molti messaggi e una carica mi dura 2 giorni...
  10. #49
    Dec 2009
    Thumbs up
    Idem come sopra, 65 ore e ancora 58% di carica, processore attivo al 5% e schermo a 4,3% il che vuol dire che il telefono gira solo quando lo uso. In ogni caso un giorno pieno con uso intenso è più che adeguato alla media degli altri prodotti in commercio. In attesa del nexus ho finalmente un telefono che fa il suo dovere.
  11. #50
    Dec 2009
    Ultimo aggiornamento, 74ore, 5% di uso attivo, batteria al 36% e nessuna traccia del bug. Se sistemasse anche il problema col registro chiamate sarebbe la rom perfetta
