[ROM][KQI]broodROM Business Edition v1.2 [UPDATE]
    Androidiano L'avatar di zakary26
    Ringraziato 22 volte in 21 Posts
    [ROM][KQI]broodROM Business Edition v1.2 [UPDATE] - xda-developers
    Changelog for v1.2:
    - Added patches from v1.1.1
    - Fixed FM Radio problem (thnx to jarjar09!)
    - Changed min freq to 245MHz for higher overall stability
    - Updated bootanimation
    - Added broodrom_scripts dir inside /system/etc (run with script manager (su) or su -c "sh /system/etc/broodrom_scripts/...")
    -- activate_i8150_gpu (change to i8150 gpu drivers)
    -- activate_i9001_gpu (change to i9001 gpu drivers)
    -- auto_calibrate_battery (calibrates battery when 100%)
    -- clear_ram_cache (clears ram cache)
    -- defragment_databases (defrags available databases)
    -- factory_reset (wipes /data, /cache)
    -- fix_permissions (fixes a lot of permissions)
    -- hard_reset (wipes /data, /cache and /sdcard)
    -- wipe_dalvik (wipes /data/dalvik-cache)
    -- zipalign_apps (zipaligns all apps)
    ROM Features:
    - Based on XXKQI 2.3.6 (ICS Value Pack)
    - XXKPM Modem Included
    - broodKernel v1.2
    - Custom boot animation of broodROM Business Edition v1.1
    - Debloated
    - Rooted
    - Deodexed
    - Zipaligned
    - Init.d Scripts: (both are from broodKernel)
    -- 00broodkernel
    --- Configuration of several things such as readahead
    -- 01screenstatescaling
    --- Extended Screenstatescaling script / configuration / tweak script
    - Extended Power Menu (with screenshot function & quick reboot function)
    - 9 Lockscreens
    - Extended Status Bar 15 Toggles
    - Disabled ScrollingCache (smooth scroll)
    - Removed "Battery Charged Notification"
    - GPS Patch
    - Cyanogenmod APNS List
    - No Adds
    - Percent Battery (UOT)
    - Some stock replacements
    - Mail exchange security policy removed
    broodKernel v1.2 Features:
    - Added Auto Mount
    -- All partitions mounted in noatime / RW
    -- Cache / Data & Persist mounted with barrier=0 / commit=60
    - Added AOSP bootanimation library
    - Added init.d Support (runs at the end of the boot process)
    - Changed Kernel Security settings
    -- ro.secure=0
    -- ro.allow.mock.location=0
    -- ro.debuggable=1
    -- persist.service.adb.enable=1
    - Adjusted Low Memory Killer
    -- LMK 60MB Based
    - Added build.prop Tweaks
    -- Smoother GUI Tweak
    -- Less Ringtone Delay
    -- GPU Rendering
    - Added IPv4 Tweaks
    -- Changed Buffersizes
    -- Tweaks in /sys/proc/net/core
    -- Tweaks in /sys/proc/net/ipv4
    - Added Touchscreen Tweaks
    -- Sensitive touch
    - Added Kernel Tweaks
    - Added SD-Card Tweaks
    - Added VM (writeout) Tweaks
    - Added Zipalign
    - Added Vacuum (sqlite_optimize)
    - Added GT-i8150 GPU Drivers
    - Added 00broodkernel in init.d:
    -- Set I/O Scheduler
    -- Set SDCard Readahead
    -- Enable/Disable Error Reporting
    -- Enable/Disable sysctl.conf file
    - Added 01screenstatescaling in init.d:
    -- Set Awake Governor & min/max freq
    -- Set Sleep Governor & min/max freq
    -- Enable/Disable Governor tweaks
    -- Option to use 01screenstatescaling as the only cpu management source (disable init.qcom.post_boot.sh)
    - Non Rotational Readahead boost
    Androidiano VIP L'avatar di hypnos17
    Pan Daemonium
    Galaxy s plus
    Ringraziato 3,444 volte in 2,652 Posts
    Non c'era già un thread aperto?
    Inviato da S Plus con la mia Nightmare v.2
    Oisis si è iscritto su Androidiani solo per postare nel mio thread: chiediti perché!
    puo essere...
    Pan Daemonium
    Galaxy s plus
    E mi sa che era pure tuo
    Edit: trovato
    Ultima modifica di hypnos17; 10-08-12 alle 14:43
    aggiorno quello allora. ciao
    Quote Originariamente inviato da hypnos17 Visualizza il messaggio
    Edit: trovato
    Scusa se sono ot, ma ho modificato il titolo del tread precedente e invece rimane quello vecchio, idee?
    Pan Daemonium
    Galaxy s plus
    Può modificarlo solo un mod
  9. #8
    ok io pensavo che modificando il mio primo post e cambiando il titolo in automatico si cambiasse anche il titolo principale. chiudo OT
  10. #9
    Androidiano L'avatar di migliamario
    Ringraziato 37 volte in 32 Posts
    Hyp per fare qualche prova ho fatto il flash dalla tua rom a questa rom senza fare wipe tutto sembra funzionare correttamente ma puó andare bene per fare test? Oppure è meglio fare i wipe e ripristinare tutto con TB?
  11. #10
    Pan Daemonium
    Galaxy s plus
    Parlane nell'altro thread questo dovrebbe essere chiuso, comunque si se non ci sono crash è tutto ok
