Pagina 47 di 265 primaprima ... 3745464748495797147 ... ultimoultimo
Visualizzazione dei risultati da 461 a 470 su 2644
[ KERNEL ][✔JB] CastagnaIT v12.5 (OC/UV, Governors, I/O, ...) [27/10/2013]
  1. #461
    Androidiano VIP L'avatar di Roydroid
    padova
    motorola moto g
    Ringraziato 793 volte in 642 Posts
    Quote Originariamente inviato da davidteri Visualizza il messaggio
    Io posso aiutare con questi tweaks usate l'app bruild.prop editor by Nathan campos https://play.google.com/store/apps/d...cC5lZGl0b3IiXQ..
    TWEAKS: build.prop
    path: /system/build.prop
    # Fast Reboot
    persist.sys.purgeable_assets=1
    # Increasing The Video Recording Quality
    ro.media.enc.hprof.vid.bps=8000000
    # Screen Rotate To 270 degree
    windowsmgr.support_rotation_270=true;
    # Increase VM Heap Size(resolve some fc's)
    dalvik.vm.heapsize=64m
    # Render UI With GPU
    debug.sf.hw=1
    # Increasing It Will Make Mobile Smoother
    windowsmgr.max_events_per_sec=150
    # Video Acceleration Enabled
    video.accelerate.hw=1
    # Increase Performance
    debug.performance.tuning=1
    # Disable Sending Usage Data
    ro.config.nocheckin=1
    # Deeper Sleep/Better battery life
    ro.ril.disable.power.collapse=1
    pm.sleep_mode=1
    # Ringing Will Start Immediately
    ro.telephony.call_ring.delay=0
    # Disable Error Checking
    ro.kernel.android.checkjni=0
    # Increase Quality Of MediaStreaming
    media.stagefright.enable-meta=true
    media.stagefright.enable-scan=true
    media.stagefright.enable-http=true
    media.stagefright.enable-record=false
    # Disable BootAnimation
    debug.sf.nobootanimation=1
    #Force To Remain Launcher In Memory
    ro.HOME_APP_ADJ=1
    # Disable Waking Up Of Phone By Volume Buttons
    ro.config.hwfeature_wakeupkey=0
    # Off The Proximity Quiclky After Call
    mot.proximity.delay=25
    ro.lge.proximity.delay=25
    # Signal Tweaks
    ro.ril.hsxpa=2
    ro.ril.gprsclass=10
    ro.ril.hep=1
    ro.ril.enable.dtm=1
    ro.ril.hsdpa.category=10
    ro.ril.enable.a53=1
    ro.ril.enable.3g.prefix=1
    ro.ril.htcmaskw1.bitmask=4294967295
    ro.ril.htcmaskw1=14449
    ro.ril.hsupa.category=5
    # NetSpeed Tweaks
    net.tcp.buffersize.default=4096,87380,256960,4096, 16384,256960
    net.tcp.buffersize.wifi=4096,87380,256960,4096,163 84,256960
    net.tcp.buffersize.umts=4096,87380,256960,4096,163 84,256960
    net.tcp.buffersize.gprs=4096,87380,256960,4096,163 84,256960
    net.tcp.buffersize.edge=4096,87380,256960,4096,163 84,256960
    # Google DNS Tweak
    net.rmnet0.dns1=8.8.8.8
    net.rmnet0.dns2=8.8.4.4
    net.dns1=8.8.8.8
    net.dns2=8.8.4.4
    # Photo And Video Quality
    ro.media.dec.jpeg.memcap=8000000
    ro.media.enc.jpeg.quality=100
    # Touch Responsiveness
    # Scrolling Responsiveness
    windowsmgr.max_events_per_sec=500
    # Power Save Tweaks
    pm.sleep_mode=1
    # Disables Debug Icon On Status Bar
    persist.adb.notify=0
    #Faster Scrolling
    ro.max.fling_velocity=12000
    ro.min.fling_velocity=8000
    #wifi to scan less frequently
    wifi.supplicant_scan_interval=180
    #improve battery under no signal
    ro.mot.eri.losalert.delay=1000
    #makes apps load faster and frees more ram. (Edit exsisting line)
    dalvik.vm.dexopt-flags=m=v,o=y
    Wipe both Caches in Recovery after adding or changing the above lines
    Scusatemi se sono OT Grazie
    questi te li rubo
    smeroni da oggi sono su jb quindi potrò testare di meno questo kernel ics
    Terminale : Motorola Moto G
    Rom : Stock 4.4.4 ottimizzata da morire
    Kernel : Stock 4.4.4 in work in progress
    Recovery : TWRP 2.7.1.0
    Un saluto al mio Galaxy S+ il miglior Galaxy di sempre che montava Android 4.4.4 perfettamente funzionante
  2. Il seguente Utente ha ringraziato Roydroid per il post:
    davidteri (20-09-12)
    Androidiano L'avatar di xeGox
    Jan 2011
    Bari - Italia
    Xiaomi Mi-2 , Samsung GalaxyS+
    Ok...ho appena parlato con Crybert...la sua rom ha un bug sull'esecuzione dell'i it.d
    non eravamo noi incapaci!
    mi ha ringraziato della segnalazione e la fixerà nella beta 4
    Inviato dal mio GT-I9001 usando Androidiani App
    Xiaomi Mi-2
  5. Il seguente Utente ha ringraziato xeGox per il post:
    smeroni68 (20-09-12)
  6. #463
    Senior Droid L'avatar di Skar3
    Ringraziato 148 volte in 89 Posts
    Ragazzi riporto la mia esperienza dopo un uso abbastanza intensivo durante le ore di lezione xD
  7. Il seguente Utente ha ringraziato Skar3 per il post:
  8. #464
    Androidiano VIP L'avatar di smeroni68
    dintorni di Milano
    SGS+ (GT-I9001) + TF300TG
    Ringraziato 1,576 volte in 695 Posts
    Quote Originariamente inviato da Skar3 Visualizza il messaggio
    Però... hai studiato per 26 ore!! Secchione!!
    Xiaomi MI5 Pro 4/128GB Ceramic Black
    Phone 1: AOSP 6.0.1 (JDC Team)
    Samsung SGS4 (2x GT-I9505 LTE)
    Phone 2: OptimizedCM 13 (JDC Team)
    Phone 3: AOSP v7.0.0 (JDC Team)
  9. #465
    Quote Originariamente inviato da smeroni68 Visualizza il messaggio
    Nono xD non sono proprio quel genere di persona , ma durante le ore noiose di storia il telefono aiuta
  10. #466
    ragazzi, ma il link all in one non funziona, si blocca al 10-15%
    poi come si fa a modificare gli attributti dei file?
  11. #467
    f96p
    Ci sarebbe il modo di aumentare ritoccando il kernel di aumentare la ram tipo a 370 380 mb?
    Sent from a phone surely better than iphone...
  12. #468
    padova
    motorola moto g
    Quote Originariamente inviato da f96p Visualizza il messaggio
    La ram è quella che è.. Non può essere propriamente aumentata
    tapatalkeggiando allegramente
  13. #469
    f96p
    Beh...gia con jelly bean aumenta di 6 mb...
  14. #470
    Q: Perchè riscontro un battery-drain eccessivo?
    A: Il mio kernel viene sempre testato prima del rilascio, e questo problema non è legato al kernel.
    Comunque, abbiamo riscontrato un problema causato da un bug della rom, quando il powerwidget 2G/3G viene usato; quando è selezionato come 2G-3G (mix mode) questo cambio blocca la rete, con il risultato che il telefono rimane in "Solo emergenze" e qualche volta causa un drain della batteria perchè la frequenza della cpu rimane al massimo impostato. Ad oggi l'unica soluzione è di impostare 2G oppure 3G (non 2G-3G) e riavviare il telefono.
    Sarebbe opportuno modificare il post e specificare che nella RC1 di ivendor il problema è stato risolto...
    Rom: CyanogenMod 9 Final Release (EOL)
    Kernel: K^Kernel v2.4
    Recovery: Team Win Recovery Project TWRP v2.5.0.0
    Baseband: XXKPM
    Governor & I/O Scheduler: Lulzactive - ROW
    Frequenze: 245 - 1401MHz
