Utente del mese: megthebest con ben 44 Thanks ricevuti nell'ultimo mese
Pagina 1 di 6 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 54
[ROM] [4.2.2] AOKP by Krislibaeer
    Androidiano VIP L'avatar di Pilone92
    Venezia
    SAMSUNG S+ - LG G2 - ONEPLUS 5
    Ringraziato 514 volte in 421 Posts
    Ecco a voi la ROM che aspettavate!
    AOKP 4.2.2 aggiornata da KRISLIBAEER[/B]
    FUNZIONA TUTTO!
    Parzialmente
    glitches in Modalità Panorama
    link xda--> [ROM][JB][4.2.2][unofficial]AOKP-jb-mr1 [BETA]~12-04-13~ - xda-developers
    FARE UN NANDROID BACKUP
    wipe data/factory reset in recovery
    wipe cache/dalvik
    flash ROM
    flash Gapps
    wipe cache/dalvik
    io faccio anche un fix permission!
    reboot
    ULTIMA VERSIONE BY KRISLIBAEER:
    Buid 7
    http://www.mediafire.com/?u8y1f2yypdydl7a
    VECCHIE VERSIONI
    GAPPS: Goo.im Downloads - Downloading gapps-jb-20130301-signed.zip
    GAPPS by Davidteri http://www60.zippyshare.com/v/70978744/file.html
    play store inverted e normale https://www.androidiani.com/forum/sa...-3-10-9-a.html
    ADDONS
    Novità
    V6:
    update cameraHAL credit castagnait this change is for the rotation of the front cam and some other stuff
    add 3G less power consumtion when display is off flag credit castagnait
    kernel from christopher83 v2.0
    use normal (old) 3D driver due to not really compatible
    sync with repo
    V5:
    fixed soft reboot of gmaps and other apps --> it was due to the photosphere changes in frameworks_native
    fixed wifi hotspot --> a flag was missing
    Fix bluetooth MAC when bluetooth is enabled on reboot from arco credits
    kernel from christopher83 v1.9
    sync with repo
    keep up with the latest changes on our gerrit instance (click the merged link!)
    Donate to AOKP https://www.paypal.com/us/cgi-bin/we...62835dd81d5d52
    Donate to CyanogenMOD Donation Tracker - CyanogenMod Forum
    Doomsday source :
    www.github.com/doomsday94
    Krislibaeer source:
    http://github.com/AOKP
    Ringraziamenti:
    Doomsday
    krislibaeer
    AOKP team
    arco68 img.tapatalk.com
    camcory
    xistance
    ivendor
    Ultima modifica di Pilone92; 14-08-13 alle 00:15
  2. I seguenti 6 Utenti hanno ringraziato Pilone92 per il post:
    Ahasvero (17-03-13),alone13 (16-03-13),Cippoz89 (03-05-13),mene82 (16-03-13),TheCancer85 (17-03-13)
    Venezia
    Ultima modifica di Pilone92; 17-05-13 alle 18:15
  5. Il seguente Utente ha ringraziato Pilone92 per il post:
    mene82 (16-03-13)
  6. #3
    Senior Droid L'avatar di IZ1PSJ
    Casale Corte Cerro VB
    Sony Xperia Z1C
    Ringraziato 62 volte in 57 Posts
    Qualcuno l'ha provata??
    Sony Xperia Z1C D5503
    Rom: Resurrection Remix V 5.5.9
    TWRP 3.2.1
    Motorola Droid Bionic XT875 (only for Nav)
    Rom: SlimKat 4.4.4 Build 9.0
    Safestrap 3.75
  7. #4
    Venezia
    Quote Originariamente inviato da IZ1PSJ Visualizza il messaggio
    su xda ne parlano bene per adesso non ho avuto modo di provarla sorry!
    Sony Xperia Z1C
    M'incuriosisce molto...ma per ora tengo la beta 3..
    Aspetto qualche feedback
    TWRP 3.2.1
    Safestrap 3.75
  9. #6
    Androidiani Power User L'avatar di dell
    Piuro
    D5803, E960 & (il fu) i9001
    Ringraziato 2,977 volte in 2,180 Posts
    ho rimosso uno screen.
    Don't be a n00b, be a newbie.
  10. Il seguente Utente ha ringraziato dell per il post:
    Pilone92 (17-03-13)
  11. #7
    Ringraziato 49 volte in 47 Posts
    Io la sto testando e fino ad adesso tutto bene!anche come batteria siamo agli stessi livelli di Cm10 e Cm10.1!Per ora la tengo..
    Inviato dal mio Nexus 7 con Tapatalk 2
  12. I seguenti 2 Utenti hanno ringraziato mene82 per il post:
    IZ1PSJ (17-03-13),Pilone92 (17-03-13)
  13. #8
    Venezia
    Quote Originariamente inviato da mene82 Visualizza il messaggio
    usi il kernel stock? si nota la differenza con la cm10 in fluidità del sistema?
    Uso Phenom kernel...ora ho il 61% di batteria con uso normale dei giorni feriali...
    Premetto che i dati mi si attivano quando accendo lo schermo e si spengono quando va in lock-screen,niente WiFi...
    La batteria si scarica molto velocemente quando sono attivati i dati...
    Direi che sono soddisfatto e come personalizzazione siamo a livelli della cyano...
    L'unico neo è l'impossibilità di attivare un hotspot WiFi!
    Ultima modifica di mene82; 21-03-13 alle 22:28
  15. Il seguente Utente ha ringraziato mene82 per il post:
    Pilone92 (21-03-13)
  16. #10
    Venezia
    Premetto che i dati mi attivano quando spengo lo schermo e si spengono quando va in lock-screen,niente WiFi...
    Grazie ma aspetto che vengano fixati bluethoot e wifi hotspot poi proverò questa
  17. Il seguente Utente ha ringraziato Pilone92 per il post:
    mene82 (21-03-13)
