Corti88
carissimo bugge ti ringrazio per il supporto fin ora, ti posto qui la mia conversazione con lo sviluppatore di ROM Toolbox Pro... premetto anche che il mio inglese non e al top... quindi magari dimmi un tuo parere cosi vedo se cio che mi ha risposto l ho capito o no...
IO:
Hello, I make you my compliments for the development of the app, I'm Italian and I state my knowledge of English is very limited. In my device I have GINGERBREAD 2.3.6 stock + cfroot ... However, if I wanted to install icon themes status bar I can do? Or should I have a custom ROM? Because once I pop a notification that tells me goes "deodexed" I do not know what it means, but why I am asking you if I can install the icons or if I need to install something else first. However, still many compliments for development. Thanks in advance, cordial greetings.
SVILUPPATORE:
Hey Mattia,
No worries on the little English. You can try to install the icons
without being Deoexed but odds are you will run into errors. Your best
bet is to find a custom ROM and flash that and then all the features
should work without any issues.
Hope this helps,
Grady
Mi dici tu cos hai capito, cosi vedo se ho capito bene anch io...
