Utente del giorno: Q.dino con ben 3 Thanks ricevuti nelle ultime 24 ore
Pagina 2 di 4 primaprima 1234 ultimoultimo
Visualizzazione dei risultati da 11 a 20 su 37
Honeycomb SGT - Alpha 2 [CDMA][GSM]
  1. #11
    Senior Droid L'avatar di marianomariano
    Apr 2011
    Napoli
    Samsung GALAXY i9003 SCL
    Ringraziato 133 volte in 100 Posts
    Una notizia positiva.
    (6/7/11) #2 : GSM owners: Ok... I think I've got it. No crashes now for about 20 minutes. But I can't release yet for two reasons... number one, I had to revert to an SDK image with only my hacks to enable a simple boot, so it may take me a day or two to re-patch to current and get it out (I have to patch everything in small bits until I find the culprit--and that's about 99999999999 patches.). So, if you're running the repo build, kiss it goodbye for a couple of days--or less.
    The second reason is... my next release is only a day or two away. Lots of fixes and fun stuff in it. But there isn't much point in uploading Alpha 2 for GSM when the next day I'll be putting out the next one. I hope that I can push it to both devices, but you CDMA folks will at least get it on day one.
    More tomorrow.
    Aspettiamo un 2/3 giorni e vediamo cosa succede.
    Samsung Galaxy S SCL i9003
    Rom CyanogenMod 10.1 - Alpha 9 by Dhiru1602
    Apr 2011
    Napoli
    Ragazzi entro questa sera o domani l'honeycomb girerà sui nostri TAB!!!
    Messaggio originale:
    (6/10/11) : Just a heads up: If everything goes well in testing, the new release for BOTH devices should be out tonight.
  4. #13
    Androidiano VIP L'avatar di golD
    Apr 2011
    Nexus 4
    Ringraziato 79 volte in 61 Posts
    Quote Originariamente inviato da marianomariano
    Non vedo l'ora.....ma di dov'è il cuoco? Ossia, "tonight" a quale periodo del giorno italiano corrisponde?
    Inviato dal mio LG dual rom vanilla 1.21.4 ghz usando Androidiani App
  5. Il seguente Utente ha ringraziato golD per il post:
    Namaless (10-06-11)
  6. #14
    Apr 2011
    Napoli
    Quote Originariamente inviato da golD Visualizza il messaggio
    Meglio pensare a domani come rilascio.
    Nella mattinata si spera...(nostra)
    Lawrence, Stati Uniti.
    Ultima modifica di marianomariano; 11-06-11 alle 00:36
  7. #15
    Apr 2011
    Napoli
    Ragzzi l'HONEYCOMB sul nostro TAB GSM E' ARRIVATO!!! Scaricate i files dal link postato in prima pagina!!!
  8. #16
    Apr 2011
    Nexus 4
    Woohoooo! Lo provo subitissimo
    Inviato dal mio LG dual rom cyanogenmod nightly 44 usando Androidiani App
  9. #17
    Senior Droid L'avatar di alessandroprato
    Mar 2011
    Prato
    LG G3 & more
    Ringraziato 83 volte in 78 Posts
    Quote Originariamente inviato da marianomariano Visualizza il messaggio
    L'bai? provata? Dai video promette bene mi sembra!
    Per l'inverno secondo me sarà tutto pronto al 100% :-D
    Inviato dal mio GT-P1000 usando Tapatalk
    Galaxy Tab
    LG Optimus One
    Galaxy S Plus
    Huawei G600
    Galaxy Note 2
    Galaxy Tab 4
    LG G3
    Per chi è a dieta .... GraficoDukan
  10. #18
    Apr 2011
    Nexus 4
    intanto hanno separato i due thread (CDMA/GSM) questo è il nostro:
    [06.13.11] Honeycomb SGT - Alpha 2.5 [GSM] - xda-developers
  11. Il seguente Utente ha ringraziato golD per il post:
    marianomariano (14-06-11)
  12. #19
    Apr 2011
    Napoli
    Si! Cmq bisogna ritornare a FROYO e poi installare HC!!!
    ATTENZIONE AL BOOTLOADER!!!
  13. #20
    Apr 2011
    Napoli
    Ok installato e tutto è andato bene.
    l'installazione è semplicissima, il sistema presenta ancora dei lag ( visto che è una versione prova )
    Per il resto sembra ben fatta.
    Presto lascerò una guida ben fatta.
    PS. è un'esperienza unica!
