DISCLAIMER: Non sono responsabile di tutto cio che possa capitare al vostro tab dopo questa operazione<br>
CHANGELOG (direttamente dal sito)
ROM FEATURES
XXJQ1 Base Rom - ANDROID 2.3.3
Overcome kernel v3.1.0 included
No Modem is included - due to a variety of personal preference I decided to leave that a la carte
Fully Deodexed
Fully Zipaligned
Rooted with busybox installed
Reboot/Recovery/Download options added to the power menu
Accurate battery mod with gingerbread styling
Blur removed across system (i.e. behind power option menu) - significantly improves performance
Power Off confirmation disabled
Screen off animation enabled
Overscroll Glow effect enabled
Added AppWidgetPicker
CSC set to XEU
Ads Blocked
Updated Market to 2.3.6
Updated Maps to 5.5.0
Flash Player removed due to compatibility issue - install from market and you'll be all set.
Updated GMail to 2.3.4
Updated YouTube to 2.1.6
Updated SamsungApps to 2.5.039
Updated StreetView to 1.6.0.6
Updated Thinkfree Office Suite
Removed Startup/Shutdown sounds
Cool boot animation
A2DP Bluetooth Connection Fix Integrated
SIP calling enabled over 3g AND WiFi
Fugutweaks integrated
GPU Drivers from Nexus S 2.3.4 integrated (fixes visual issues)
Browser mods (enabled "Default Zoom" in settings, added "User Agent" in settings, set plugins to "on demand" by default)
KERNEL FEATURES
Support RFS/EXT2/EXT3/EXT4
OC/UV with these steps: 1.4ghz, 1.2ghz, 1ghz, 800mhz, 600mhz, 400mhz, 200mhz, 100mhz
Replaced kernel jhash2 with jhash3
Adjusted kernel HZ value to improve smoothness
Optimized lowmemorykiller values
Optimized compiler flags
Voodoo Sound v9 (courtesy of supercurio)
Voodoo Lagfix (courtesy of supercurio)
Overcome CwM Recovery v4.0.0.2 (Custom built Clockworkmod v4.0.0.2)
Full support of internal/external SD cards in Recovery
Simple I/O Scheduler added and set as Default
Kernel tweaks to VM and Scheduler for better performance
Built in CIFS/TUN/SlowWork support
Touchscreen Undervolting (courtesy Koxudaxi)
RAM Undervolting
Stochastic Fair Blue (SFB) Network Scheduler
Autogroup Scheduler
Asynchronous I/O Enabled (AIO)
Backlight Notifications (Thanks to Neldar for the mod and Koxudaxi for the patch)
INSTALLAZIONE
per chi dovesse solo fare un upgrade,ad esempio da overcome gold,basta installare la versione no wipe da cwm e il gioco e' fatto.si preoccupera l'installer di fare i dovuti wipe.unico requisito:almeno 3gb liberi nella memoria interna per la conversione in ext4..altrimenti il processo non funzionera'.attendere un bel po di tempo al primo avvio...
LINK----------->NO WIPE
per chi invece dovesse arrivare da una rom froyo o qualunque altra rom GB scaricare la rom (wipe overcome hermes) e il gb stock versione 3
WIPE
GB-STOCK
Estrarre il pacchetto gb stock safe v3.zip
Accendere il TAB in DOWNLOAD MODE (volume giu + power)
Avviare ODIN
Selezionare il file .PIT (gt-p1000_mr.pit)
Selezionare il file PDA (GB_Stock_Safe_v3.tar)
Selezionare il file PHONE (JPZ Modem) (modem.bin)
Selezionare RE-PARTITION
Cliccare su START e attendere la fine dell'installazione
Avviare il TAB e copiare nella memoria il file overcome hermes.zip
Spegnere il TAB e riaccenderlo in RECOVERY (volume su + power)
Effettuare i WIPE ( wipe data/factory reset, wipe cache partition e l'ultimo Wipe Dalvik Cache che si trova nel menu ADVANCED)
Ritornare alla home della recovery e selezionare install zip from sdcard, choose zip from sdcard e infine scegliere lo zip della rom hermes
Alla fine dell'installazione scegliere Riavvia
rom installata
qualche screens
ADDONS (flashare da recovery)
per chi volesse solo il kernel-------->QUI per CWM QUI per odin
patch stock theme--------->QUI
patch navigazione google maps-------------->QUI
gmail autoscarica immagini patch-------------->QUI
darkpal frameworks (indicatori batteria e segnale cambiati)--------->QUI
MODEM
JPZ
JK3
JMF
TMO
 LinkBack URL
 About LinkBacks
  Rispondi quotando
						Ultima modifica di sert00;  15-06-11 alle
