[GUIDA] Codici Segreti Galaxy W
    Androidiano L'avatar di Riky Ray
    Samsung Galaxy W
    Ringraziato 52 volte in 22 Posts
    Post
    The following special numbers can be "dialed" to read out internal data and get access to various debugging functionality:
    • *#1234# - print the PDA, PHONE and CSC versions of the current firmware (alternatively: *#*#44336#*#*)
    • *#06# - print the IMEI
    • *2767*4387264636# - print the product code
    • *#*#4636#*#* - Phone information, Battery information, Usage statistics, Wifi information (very useful for debugging, has ping test etc.)
    • *#0*# - testing mode, has tests for LCD, speaker, vibration, front and back camera, touchscreen and all other internal sensors like accelerometer, magnetic sensor etc.
    • *#*#7594#*#* - switch the action performed when you hold the "Power" button: default is to display a menu (with options like silent mode, flight mode, power off), the other setting is to directly switch phone off
    • *#*#8255#*#* - GTalk service monitor, for GTalk debugging
    • *#*#526#*#* - WiFi driver test, use Menu button to select start transmission and receiving tests (alternatively: *#*#232339#*#*)
    • *#*#232338#*#* - print WiFi MAC address
    • *#*#1575#*#* - service mode: GPS test
    • *#0011# - service mode: signal status
    • *#1111#* - service mode: print FTA SW Version
    • *#2222#* - service mode: print FTA HW Version
    • *#*#0283#*#* - service mode: audio packet loopback
    • *#*#0673#*#* - speaker test (alternatively *#*#0289#*#*)
    • *#*#0842#*#* - vibration test
    • *#*#2664#*#* - Touch screen test
    • *#*#0588#*#* - Proximity sensor test
    • *#*#232331#*#* - Bluetooth test
    • *#*#232337#*# - print Bluetooth device address
    • *#*#3264#*#* - print RAM version
    • *#3214789650# - enter AngryGPS configuration
    • *2767*3855# - Factory format. WARNING! ALL DATA WILL BE DELETED AS SOON AS YOU TYPE IN THE FINAL #! IT DOES NOT ASK FOR CONFIRMATION!
    • *#*#34971539#*#* - Camera firmware info and update. WARNING! Trying to flash camera firmware will brick your camera!
    • *#*#2663#*#* - Touch screen firmware version and update
    Samsung Galaxy W GT-I8150
    - Versione Android 2.3.6
    - Versione banda base I8150XXKL3
    - Versione build GINGERBREAD.XXLA2
  2. Il seguente Utente ha ringraziato Riky Ray per il post:
    diglo (04-07-12)
    Baby Droid L'avatar di technolightsound
    Mi Permetto Di Tradurre
    • * # 1234 # - stampare le versioni PDA, telefono e CSC del firmware attuale (in alternativa: * # * # 44336 # * # *)
    • * # 06 # - stampare l'IMEI
    • * 2767 * 4387264636 # - stampare il codice del prodotto
    • * # * # 4636 # * # * - informazioni Telefono, batteria informazioni, statistiche di utilizzo, informazioni Wifi (molto utile per il debugging, ha test ping, ecc)
    • * # 0 * # - Modalità di prova, ha test per LCD, speaker, vibrazione, fotocamera anteriore e posteriore, touchscreen e tutti gli altri sensori interni come l'accelerometro, sensore magnetico, ecc
    • * # * # 7594 # * # * - attivare l'azione eseguita quando si tiene premuto il tasto "Power": di default è di visualizzare un menu (con opzioni come la modalità silenziosa, modalità di volo, l 'alimentazione), l'altra impostazione è direttamente spegnere il telefono
    • * # * # 8255 # * # * - GTalk servizio di monitoraggio, per GTalk debugging
    • * # * # 526 # * # * - test driver WiFi, utilizzare il tasto Menu per selezionare avviare la trasmissione e le prove che ricevono (in alternativa: * # * # 232339 # * # *)
    • * # * # 232338 # * # * - stampa WiFi indirizzo MAC
    • * # * # 1575 # * # * - modalità di servizio: GPS prova
    • * # 0011 # - modalità di servizio: lo stato del segnale
    • * # 1111 # * - modalità di servizio: Versione di stampa FTA SW
    • * # 2222 # * - modalità di servizio: Versione di stampa FTA HW
    • * # * # 0283 # * # * - modalità di servizio: loopback dei pacchetti audio
    • * # * # 0673 # * # * - test speaker (in alternativa * # * # 0289 # * # *)
    • * # * # 0842 # * # * - vibrazioni di prova
    • * # * # 2664 # * # * - Touch screen test
    • * # * # 0588 # * # * - test del sensore di prossimità
    • * # * # 232331 # * # * - Bluetooth Test
    • * # * # 232337 # * # - Indirizzo Bluetooth del dispositivo di stampa
    • * # * # 3264 # * # * - versione per la stampa RAM
    • * 3214789650 # # - inserire la configurazione AngryGPS
    • * 2767 * 3855 # - Format Factory. ATTENZIONE! TUTTI I DATI SARANNO cancellati non appena si digita nella FINALE #! NON CHIEDERE PER CONFERMA!
    • * # * # 34971539 # * # * - Camera firmware informazioni e aggiornamento. ATTENZIONE! Cercando di firmware della fotocamera flash mattoni la macchina fotografica!
    • * # * # 2663 # * # * - Touch versione del firmware e l'aggiornamento dello schermo
  5. Il seguente Utente ha ringraziato technolightsound per il post:
    cancer78 (11-03-12)
