[ROM] [ICS 4.0.4] [MOD] Revamed v.1 STABILE (19-09-2012) [AGGIORNATO]
    Revamed v.1 ROM
    not REVAMPED
    Based on CM9 beta 1
    were gonna make this ROM closest to a stock ICS but more features.
    my friend takes 70% to this ROM he tweak everything in the system LOL
    BTW he got SGS2 not SGW
    RESTORE VIA CLOCKWORKMOD
    Features:
    nothing special :P
    Latest TW5 lite (optimize for Wonder)
    working JB widgets (hope so)
    S3 sound effects
    Remove useless apps
    Tweaked System (more stable)]by my friend ((still dont know what he did there lol))
    tweaked Init.d
    extended power menu
    Screen off TV Animation
    Compatible w/ forfivo kernel v.1 (still using arcos kernel)
    Battery Life (untested)
    Added basic apps
    etc.
    nxt update: if we can..
    adding full TW5 feature
    S3 lock screen w/ ripple effect
    ripple effect when touching the screen
    etc.
    THANKS TO ALL DEVS that part to this project= secret >.< IDK your names lol
    especially arco woot!
    Install this software at your own risk Im not responsible for damaging your phone
    3 Parts Link:
    my internet speed is sucks..
    CM9_Revamed_ROM_v1.part1.rar
    CM9_Revamed_ROM_v1.part2.rar
    CM9_Revamed_ROM_v1.part3.rar
    Known Bugs:
    changing lock screen WP via HOME screen (auto close)
    file manager random FC (rarely)
    I THINK ALL YOU KNOW HOW TO BACK UP and RESTORE RIGHT?
    How to install
    Make a nandroid back up in case of an emergency
    Extract the file
    =NO NEED GAPPS=
    find and copy the 'CLOCKWORKMOD Folder' in your external SD card
    BOOT INTO RECOVERY MODE
    Wipe Your Device 2 times to be sure
    Restore via CWM and select backup and restore/restore from external sd
    then Wipe again your device if you want a fresh setting
    Reboot
    Done!
    tips to improve battery life:
    Reduce screen brightness
    remove some widgets
    Switch between 2G or 3G
    Disable GPS or Bluetooth
    Underclock your phone’s CPU (maybe setCPU may help)
    Dont use LWP
    Disable auto rotate OR motion sensor
    Full cycle charge
    Can someone Test this?
    if you like this just click the thanks button
    well atleast we tried to mod
    Screen shot:http://forum.xda-developers.com/atta...3&d=1348045825
  2. Il seguente Utente ha ringraziato IceBlack per il post:
    maurizio2974 (23-09-12)
    salve...
    vorrei provare questa versione stabile..ho attualmente la lm8,non devo fare nessuna modica di kernel o cose varie?
    basta fare un reovery con CLOCKWORKMOD?
    grazie in anticipo
  5. #3
    macijeep
    Dovrebbe uscire a breve la biohazard v4, prova quella
  6. #4
    Androidiano VIP L'avatar di fratoff91
    Nov 2010
    Ringraziato 677 volte in 373 Posts
    Quote Originariamente inviato da maurizio2974 Visualizza il messaggio
    salve...
    grazie in anticipo
    Devi avere root e clockworkmod e basta per installarla...
    E comunque sarebbe utile un primo post in italiano e fatto bene...
    Inviato dal mio GT-I8150 cm9 usando Tapatalk 2 Pro
  7. Il seguente Utente ha ringraziato fratoff91 per il post:
    maurizio2974 (24-09-12)
  8. #5
    Installato!! Tutto ok..unica cosa, quando va in standby sembra i vecchi televisori quando si spengevano, flash allo schermo e linea orizzontale finale..spero di essermi spiegato..
  9. #6
    è una animazione
    ps: ma che risposta è "esce la rom XXX, prova quella"?!?!? BAH
  10. Il seguente Utente ha ringraziato Geims83 per il post:
  11. #7
    Androidiano VIP L'avatar di fender90
    Venezia
    Samsung Galaxy Wonder (i8150)
    Ringraziato 597 volte in 175 Posts
    OP: copiare ed incollare un thead da XDA è facile, a sto punto bastava andare lì e leggerselo. Se posti qui almeno prenditi la briga di tradurlo
  12. #8
    Una curiosità.. mi sembra che con questa versione sia diminuito il segnale ..dove prima avevo 1/2 tacche su 4 ora ne ho 0...più il volume della suoneria e dei messaggi sembra più bassa...è una mia impressione o qualcuno ha riscontrato lo stesso problema? Più manca la radio,ma quella la ritrovo.
  13. #9
    Tolta...aveva un po' troppi problemi.. avevo installato diverse appari e s'era rallentato molto.oltre alla suoneria che alle volte rimaneva muto..ho risolto mettendo la rom scarivata direttamente da xda.ora funziona che è una meraviglia!!!
