Kernel 3.4 per CM10
Hi guys! ;)
This is the kernel 3.4.XX for our device.
I've compiled it from erik96,merged with arco's and hadidjapri's,sources.
It's on alpha stage/not completely optimized for android,yet. It's yet Linux like.
Kernel version: 3.4.33
- Initial Release
- New x32 ABI support, this shall somehow maximize CPU perfomance
- Swap-in readahead skips over holes
- Netfilter enhancement
- Crypto - sha224 and sha384 routines
- Some minor file system changes
- Networking enhancements (networking speed is a bit better)
- Advanced Configuration and Power Interface S4 sleep state - this would result in ability of guest VMs to hibernate on Xen
- Larger physical address extension on the ARM architecture
- Some battery improvements, battery life seems to be better
- Lots of open source graphic DRM changes
- Intel Sandy Bridge performance improvements (only on PC's)
- Btrfs improvements
- Improved Power Management
- New Power Management Phases
- Governors taken from PhenomKernel
- I/O Schedulers from PhenomKernel
- 370MB User RAM
- Compiled with Linaro 4.7.3 Toolchain.
Working:
- Camera (both picture and video, 720P recording)
- USB
- 3G & Calls
- Audio
- Battery
- Touchscreen
- Touch keypad
- Bluetooth
- Accelerometer
- Light sensor
- Proximity Sensor
- Orientation Sensor
- Digital Compass
- Vibration
- GPS
- Display
- BLX
Not Working:
Download:
1st release - DOWNLOAD - 26/02/2013 - 3.4.33
Credits:
- Arco68 - Base kernel
- Erik96 - Base kernel
- Hadidjapri - Support
- Hotteabilly - Support
Hi miki =) Ho letto su xda che ora va il Wifi, è vero...???
R: Kernel 3.4 per CM10
bboyFunk
Mi sto cervellando per farlo funzionare XD
Comunque il vsync va ;)
Inviato dal mio GT-I8150 con Tapatalk 2
Oky Grazie =) mi passeresti anche il link per scaricare il kernel 3.0 di arco, quello della CM10 stock cosi dopo aver provato il tuo posso tornate a quello stock della CM10... Grazie =)
Ieri ho messo un link nella discussione della cm10 controlla ultime pagine :-)
ma questo kernel ha l'overclock e l'undervolt? se non ce l'ha potresti metterlo??
darix96
Overclock sicuro, 1602Mhz....undervolt probabilmente.
Intendevi 1804mhz ;)....sembra un kernel fantastico appena rilasci la versione con il wifi fixato lo metto! Ah l'otg sarebbe una cosa fantastica ma non credo che il wonder abbia il chip per alimentare qualcosa... bisognerebbe usare un' alimentazione esterna...vabbé ottimo lavoro!!!
darix96
No è proprio 1612Mhz....comunque aggiusterò il wifi quando si passerà da LKA a CAF così da non rifare tutto....
