Pagina 2 di 2 primaprima 12
Visualizzazione dei risultati da 11 a 19 su 19
[KERNEL 10.1 ] Hurtsky v1.0
  1. #11
    cmq sarebbe meglio specificare se funziona solo per stock rom oppure per cyano o altre rom
    Baby Droid L'avatar di drewct
    galaxy W
    Ho un Galaxy W con la CM9! Posso buttarglielo su sto kernel o faccio danni?
    Poi per quanto riguarda Governor e Scheduler come mi consigliate di metterli?
    Grazie =)
  4. #13
    Sassari
    LG G2, LeMax 2
    Quote Originariamente inviato da Wuolgresh Visualizza il messaggio
    basato su quello di arco 3.4. 43
    List of Governors Available :-
    - Lulzactive
    - Powersave
    - SmartAssV2
    - interactive
    - interactiveX
    - conservative
    - ondemand
    - performance
    - Hyper Governor
    IO Scheduler
    - noop
    - deadline
    - row
    - cfq
    - bfq
    - sio
    - vr
    Additional Features
    - Compiled with Linaro GCC 4.7.3-2013.03 toolchain optimized for Cortex-A8 cpu with Neon technology support
    - 378mb Ram
    - CPU voltage control VDD sys interface (voltage adjustable)
    - Overclock support
    - Added NEON compilation flag to VFP module
    - O3 optimization for Module
    - SnapDragon Optimization
    - dynamic read-ahead
    - frandom
    - Lowered display panel voltage
    - Lowered wifi voltage
    - Increase audio loudness
    - Dynamic management of dirty page writebacks credit to Christopher83
    - Dynamic Fsync
    - Fixed 100% battery notification after charger unplug credits to Christopher83
    Installation Guide:
    1. Reboot To Recovery Mode
    2. Wipe Cache & Dalvik Cache
    3. Flash the kernel
    4. Fix Permissions
    5. Reboot (normal boot)
    6. Reboot to recovery again
    7. Fix permissions again
    8. Reboot (normal boot)
    Credit to :-
    - Our Master Arco for his kernel source ( go press thanks for any posted by arco without he, this kernel wont existed )
    - educk for his tutorial and governors
    - biagio7xD for extra governors and SnapDragon Optimization
    - Christopher83 that helping me teach how to correct the error and advising me and thanks for his new linaro
    - Xistance for his teaching
    - CastagnaIT for his useful sources
    - CyanogenMod developers that developing our CM
    - Linaro GCC developers let me using this powerful compiler
    - hadidjapri hadiconfig (more RAM)
    - keff for governors code fixes
    - xda-developers.com for all the teaching and member
    V2.4
    V2.4 25/6/2013
    - sync with arco latest repo 3.4.50
    - frandom fix - credits to keff
    Link Download :V2.4 25/6/2013 - sync with arco late...redits to keff
    Thank you so much.
    • REGOLAMENTO • CONSIGLI SULL'UTILIZZO DEL FORUM • F.A.Q. DEL FORUM • MANUALE BBCODES •
    Smartphone:
  5. #14
    ciao a tutti.. mi appresto a mettere cyanogenmod9 final sul mio w. mi consigliate di mettere questo kernel? e dove posso trovare info sui doversi tipo di governator e a ke servono?? grazie
  6. #15
    Nov 2013
    Per la CM9 l'ultima versione del kernel di KurtSky (REV10) la trovi qua:
    [Kernel][CM9] HurtSky's Kernel REV10 + BFS 8/12/2013 GREAT Performance + BETTER BATTERY LIFE! - xda-developers
  7. #16
    Androidiano L'avatar di Yayo15
    Ciao a tutti!
    Usando CWM 6.0.4.5 non c'è l'opzione "Fix Permission"...
    E' un problema per l'installazione di questo kernel?
  8. #17
    Nov 2013
    Mi sono imbattutto nello stesso problema: non ricordo se non ho fatto il fix o l'ho fatto dopo il riavvio utilizzando ROM manager, in ogni caso non ho avuto problemi e tutto sembra funzionare. Aspetta comumque la risposta di qualcuno più esperto sei vuoi, non so bene quali possano essere gli eventuali problemi.
  9. #18
    Sassari
    LG G2, LeMax 2
    Quote Originariamente inviato da novastories Visualizza il messaggio
    Su cyano10.1 giusto?!
    Ovvio. Leggi il titolo della discussione.
    Smartphone:
  10. #19
    Jan 2014
    Ma non ho capito come installarla
    EDIT: risolto
    Ultima modifica di Nicolo01; 15-01-14 alle 16:43
