[ROM][ION][4.4.2][KOT49H] UnOfficial CyanFox by Madridii
    Androidiano al prosciutto L'avatar di IlPessimoFra
    Padova
    Galaxy Ace-i, Galaxy W
    Ringraziato 626 volte in 427 Posts
    [CENTER]
    CyanFox is a brand new custom aftermarket Android firmware (ROM) which is based on CyanogenMod 11.0 and Android 4.4.x source bases with some new essential features added in.
    The team target is to keep smoothness, usability and stability while developing this ROM. So, you can be sure that CyanFox will be your best Android daily driver.
    ATTENZIONE:
    * Your warranty is now void.
    * I am not responsible for bricked devices, dead SD cards,
    * thermonuclear war, or you getting fired because the alarm app failed. Please
    * do some research if you have any concerns about features included in this ROM
    * before flashing it! YOU are choosing to make these modifications, and if
    * you point the finger at me for messing up your device, I will laugh at you.
    TRADUZIONE:
    La tua garanzia adesso è invalidata.
    Non sono responsabile per telefoni briccati, schede SD morte, guerre termonucleari, o di licenziamenti a causa della app della sveglia che non ha suonato. Perfavore, fai qualche ricerca se hai qualche dubbio sulle funzionalità di questa ROM prima di flasharla! TU stai scegliendo di fare queste modifiche, e se tu dai la colpa me per aver rovinato il tuo telefono, ti riderò in faccia.
    FEATURES
    1- Status bar : Signal Status Style , Battery Status Style , Battery Percent , Double-tap to sleep ( tap on status bar ) , Brightness control
    2- Halo
    3- Navigation Bar
    4- Dark UI
    5- Screen Recorder
    BUG
    - Camera stopped ( install the attach camera app to make it works )
    -->> fix: Camera2.apk thanks to @educk
    - No SD swap ! ( maybe I will upload a kernel for it )
    -->> Workaround : download this kernel zip (just for Beta 1)then install it and wipe cache and dalvik
    INSTALLAZIONE
    PRIMA DI TUTTO FAI UN BACKUP DI TUTTO QUELLO CHE E' CONTENUTO NELLA MEMORIA INTERNA DEL TELEFONO, POI POSIZIONA I FILE DELLA ROM E DELLE GAPPS NELLA MEMORIA ESTERNA
    Installazione della rom
    Prima : installa la CWM 6.0.4.5 by arco, poi :
    1- Wipe data/factory reset
    2- Wipe cache e dalvik cache
    3- Format system (si trova in monts and storage)
    4- Format sdcard0 (la memoria interna)
    5- Install the ROM
    6- Install any gapps for 4.4.2 ( I installed PAGAPPS )
    Procedura per futuri aggiornamenti della rom
    1- install the ROM
    2- Wipe Cache and Dalvik Cache
    DOWNLOAD
    CyanFox-2.0.1-20131228-UNOFFICIAL-ancora.zip : DOWNLOAD DIRETTO o DOWNLOAD TORRENT (non consigliato)
    Gapps: le trovate qui, ma se volete, vi semplifico la vita:
    GOOGLE STOCK PACKAGE: This package is recommended for most users. It includes all the Google Apps that come standard on Nexus devices.
    In this package you will find the Core Base¹, Google Experience Launcher (replaces stock launcher), Google PhotoSphere Camera/Gallery², Sun Beam Live Wallpaper, and the following Play Store applications: Chrome Browser (replaces AOSP Browser) | Cloud Print | Gmail | Google+ | Google Calendar (replaces AOSP Calendar) | Google Drive | Google Earth | Google Keep | Google Keyboard (replaces AOSP Keyboard) | Google Play Books | Google Play Games | Google Play Newsstand | Google Play Music | Google Play Movies | Google Play services | Google Text-to-Speech | Google Search | Google Wallet | Hangouts (replaces AOSP SMS App) | Maps | Quickoffice | Sound Search for Google Play | Street View on Google Maps | TalkBack | YouTube
    Download (275 MB) :
    FULL MODULAR PACKAGE: This package is identical to the Google Stock package above except that it does NOT include the Google PhotoSphere Camera/Gallery and will not remove your stock/AOSP Keyboard, Browser, or SMS App. If you don't have a Nexus device and prefer to use the AOSP apps, this package would be perfect for you.
    Download (218 MB) :
    MINI MODULAR PACKAGE (consigliato dall'autore della Rom): This package is designed for those who use limited Google apps or prefer to install apps on their own.
    In this package you will find the Core Base¹, Google Experience Launcher (replaces stock launcher), and the following Play Store applications: Gmail | Google+ | Google Calendar (replaces AOSP Calendar) | Google Play services | Google Search | Google Text-to-Speech | Hangouts | Maps | Street View on Google Maps | YouTube
    Download (120 MB):
    ADD-ON
    Addon modules can be installed on top of most any GApps package, including the Mini or Full packages above.
    All addon modules also include addon.d backup support, meaning their functionality will be restored after flashing a ROM update.
    -Keyboard Addon Module (~13MB)
    This addon module will install Google Keyboard along with the iWnn Emoji keyboard that comes standard on Nexus devices.
    This package does not replace the stock (AOSP) keyboard installed on your device.
    -Photosphere Camera Addon Module: (~66MB)
    This addon module will install the Photosphere Camera/Gallery on all supported Nexus devices, including the 2012 Nexus 7.
    Although the package includes the Camera/Gallery for all Nexus devices, only the specific files for your device will be installed.
    -Chrome Browser Addon Module: (~27MB)
    This addon module will install Google Chrome Browser on your device.
    -Google Bookmark Sync Addon Module: (~0.3MB)
    This addon module will install the stock/AOSP Browser Google Bookmark Sync. Since this app has been known to cause problems with ART, it is now only offered as a separate addon.
    -Google Dialer Addon Module: (~3.4MB)
    This addon module will install the Google Dialer on your phone and replace the stock/AOSP phone app.
    Install it ONLY after you have set up your device and then rebooted into Recovery.
    Download:
    CHANGELOG
    Beta 2
    - Camera Fixed (Used branch old of camera2 app, arco's fix not implemented yet)
    - Swap SD cards feature Added (Dont change the Value in build.prop, Settings>storage>press on menu>advanced menu> check it)
    - Based on arco's sources ( Device and Kernel )
    Beta 1
    - Initial build
    - CyanFox 2.0.12
    - Based on device tree in my github
    SCREENSHOTS
    CREDITI E GRAZIE A:
    - Madridii (autore della rom)
    - arco68
    - educk
    - AriesVE-DevCon-TEAM
    - Cyanfox team
    - CM team
    - hadidjapri
    and all dev I followed
    Come già detto prima, nè io nè Androidiani.com ci assumiamo nessuna responsabilità riguardo brick, bootloop e problemi vari al telefono. Segui questa guida a tuo rischio e pericolo
    Ultima modifica di IlPessimoFra; 02-01-14 alle 19:03
  2. I seguenti 2 Utenti hanno ringraziato IlPessimoFra per il post:
    Fabryzio12 (31-12-13),NiloGlock (30-12-13)
    Androidiano L'avatar di Fabryzio12
    Xiaomi Mi5
    Ringraziato 39 volte in 33 Posts
    Raga è solo un problema mio oppure è un bug che non riconosce la scheda SD?
  5. #3
    Padova
    Quote Originariamente inviato da Fabryzio12 Visualizza il messaggio
    A me, se non ricordo male, la riconosceva, prova riflasharla...
  6. #4
    Samsung Galaxy Wonder GT-i8150
    Ma sei io vengo su questa CyanFox dalla CM11, devo fare un wipe completo o basta solo un Wipe Cache?
  7. #5
    Sassari
    LG G2, LeMax 2
    Quote Originariamente inviato da MarkoNaks Visualizza il messaggio
    Wipe data, wipe cache, dalvik cache e format /system.
    Smartphone:
