- Compilato con Linaro GCC 4.7.3-2013.11 toolchain ottimizzato per CPU Cortex-A8 supporto alla tecnologia NEON
- Interfaccia per il controllo VDD del voltaggio della CPU (voltaggio modificabile)
- Supporto all'overclock
- Added NEON compilation flag to VFP module
- Ottimizzazione SnapDragon
- dynamic read-ahead
- frandom
- Lowered display panel voltage
- Lowered wifi voltage
- Increase audio loudness
- Dynamic management of dirty page writebacks credit to Christopher83
- Dynamic Fsync
- Fixed 100% battery notification after charger unplug credits to Christopher83
- LowMemoryKiller management of not killable processes - credits to christopher
- Asynchronous I/O latency to a solid-state disk greatly increased
- CK3 tweaks (Credits to Con Kolivas) - adapted by Christopher
- Snappy Google Zram
- Added 518Mhz
- Random Tweaks
- Reduce WIFI wakelocks - credits to DerTeufel
- Implement Suspend Freeze (more battery friendly)
- Allowed IPv6 over WIFI in general, we control it in ROM, + no wakelock! (reduce battery consumption)
- exfat support
INSTALLAZIONE
1. Reboot To Recovery Mode (CWM)
2. Wipe Cache & Dalvik Cache
3. Flash the kernel
4. Fix Permissions
5. Reboot (normal boot)
6. Reboot to recovery again
7. Fix permissions again
8. Reboot (normal boot)
REV2 27/12/2013
- inject VM tweaks, frandom hack, and improve touch sensitiveness from project Lard into ramdisk
- Update zcache sources
- Implement frontswap into kernel
- Implement ZBUD : thanks Seth Jennings
- Implement ZSWAP : thanks Seth Jennings
- Add zRam for Android paging and LMK.
- mm: Improved Swap logic
- Add the Snappy-c compressor : thanks to Andi Kleen
- lib: add support for LZ4-compressed kernels : thanks to Kyungsik Lee
- arm: add support for LZ4-compressed kernels : thanks to Kyungsik Lee
- lib: Add lz4 compressor module : thanks to Chanho Min
- crypto: Add lz4 Cryptographic API : thanks to Chanho Min
- other updates
REV 1 25/12/2013
- built with Linaro GCC 4.7.3-2013.11 toolchain optimized for Cortex-A8 cpu with Neon technology support
- initial changes - look at GitHub (too much commit had been done)
- based on new kernel from sir arco
- thanks to arsradu for kernel.zip because the new CM10.1 use same concept as CM10.2
Settings of The Available Features
This feature allows to define processes and system processes white-lists filled with the preferred process names and to not be killed by lowmemorykiller, unless it is absolutely necessary.
This feature exposes four new lowmemorykiller parameters:
- donotkill_proc, is the flag to enable / disable this feature for the processes chosen by the user
- donotkill_sysproc, is the flag to enable / disable this feature for the system processes chosen by the user
- donotkill_proc_names, is the list of process names (comma separated) chosen by the user to be preserved from killing
- donotkill_sysproc_names, is the list of user system process names (comma separated) chosen by the user to be preserved from killing
When the lowmemorykiller needs to free ram, it will first kill the processes not included inside the two process name lists chosen by the user.
If there are no more standard killable processes, then it will be necessary to kill one of the processes included inside one of the two white-lists, to prevent system hangs, slowdowns, etc.
How to customize the white lists of processes to preserve from killing:
On HurtSky's Kernel the feature is enabled by default and the provided processes white lists are the following:
- donotkill_proc_names = "com.cyanogenmod.trebuchet,com,android.inputme thod .latin"
this means that Trebuchet Launcher,stock keyboard will be preserved from killing
- donotkill_sysproc_names = "android.process.acore,com.android.phone,com."
this means that the system process, the phone process will be preserved from killing
1) By using a customized init.d script (the custom value will be always restored after a reboot, if you don't format the system partition)
- Download the script named 80dnkp
- If the file has been saved with .txt extension (stock browser), rename it by removing the .txt extension
- Edit the file by setting your preferred status and processes list
- Copy the new file inside /etc/init.d
- Give the rwxr-xr-x permissions to the file (read, write, execution for owner, read and execution for group users, read and execution for others)
- Reboot
2) By directly editing the files inside /sys/module/lowmemorykiller/parameters (note that set values will be lost after a reboot/shutdown)
3) By using Terminal Emulator (note that set values will be lost after a reboot/shutdown)
- Open Terminal Emulator
- Run these commands if you want to enable the feature
Code
# To enable this feature for the processes chosen by the user
echo 1 > /sys/module/lowmemorykiller/parameters/donotkill_proc
# To enable this feature for the system processes chosen by the user
echo 1 > /sys/module/lowmemorykiller/parameters/donotkill_sysproc
- Run these commands if you want to disable the feature
Code
# To disable this feature for the processes chosen by the user
echo 0 > /sys/module/lowmemorykiller/parameters/donotkill_proc
# To disable this feature for the system processes chosen by the user
echo 0 > /sys/module/lowmemorykiller/parameters/donotkill_sysproc
- Run this command if you want to add, for example, Trebuchet Launcher (CM default launcher) and the default keyboard to the processes white list
- Our Master Arco for his kernel source ( go press thanks for any posted by arco :D without he, this kernel wont existed )
- AriesVE-DevCon-TEAM that make ION and PMEM can co-existed together.. big thanks for them :)
- educk for his tutorial and governors
- biagio7xD for extra governors and SnapDragon Optimization
- Christopher83 that helping me teach how to correct the error and advising me and thanks for his new linaro :)
- Xistance for his teaching
- CastagnaIT for his useful sources
- CyanogenMod developers that developing our CM
- Linaro GCC developers let me using this powerful compiler
- hadidjapri hadiconfig (more RAM)
- keff for governors code fixes
- FelixMG for youtube video
- arsradu for kernel.zip
- others developer on GitHub
- xda-developers.com for all the teaching and members
E I RACCOMANDO, USATE QUESTO KERNEL SOLO CON LA CYANOGENMOD 10.1 BETA 2 DI ARCO O LE ROM BASATE SU DI ESSA!!
Lista sopra
OVVIAMENTE NON MI ASSUMO NESSUNA RESPONSABILITA' RIGUARDO BRICK, BOOTLOOP, MALFUNZIONAMENTI VARI ECC.
