[Kernel][ION+PMEM][CM11] Just Another... Stage 5 (03/06/2014)
    Sep 2013
    Samsung Galaxy W
    Ringraziato 155 volte in 120 Posts
    JUST ANOTHER KERNEL for Cyanogenmod 11.0 (unofficial)
    GitHub
    Credits goes to:
    arco68, christopher83, AriesVE-DevCon-TEAM, hurtsky, madridii, lafactorial, arsradu, leroviten, sir mordred, all other authors you can see in the commits in my kernel branch, all friendly guys in the community who continuously delivering a lot of useful tools and tutorials for kernel development, and last but not least all participating users who keep this forum for the GALAXY Wonder alive!
    Caratteristiche principali e comuni,già viste in altri kernel:
    - compiled with Linaro GCC 4.9-2014.05 optimized for Cortex-A8 - by Christopher83
    - O3 Optimization & NEON VFP compilation flag
    - Governors: interactive default, conservative, lulzactive, interactiveX, ondemand, ondemandX, powersave, smartassV2, performance
    - I/O schedulers: cfq default, noop, vr, sio, row, bfq, fiops, deadline
    - Lowered display panel voltage
    - Lowered wifi voltage
    - Lowered vibetonz voltage
    - Increased audio loudness
    - Battery Life eXtender support
    - Fast Charge support
    - CPU voltage control VDD sys interface / Overclockable up to 1.8 GHz
    - Increased cpu freq. on boot
    - Fast Random generator (frandom)
    - Dynamic management of the minimal timer slack value
    - Dynamic management of dirty page writebacks
    - Dynamic FSync v1.2
    - msm: memutils: memcpy, memove optimization
    - Disabled Gentle Fair Sleepers for better UI performance
    - Optimized AES and SHA1 routines for ARM cpu architecture
    - exFAT support
    - LowMemoryKiller management of not killable processes
    Nuove caratteristiche per la gestione della memoria:
    - KSM check and skip page if it s already scanned' + optimized defaults
    - MM patch bomb, regarding vmscan, compaction, page_writeback, oom_kill, slub,...
    - new small and naive hashtable implementation
    - red-black tree implementation & changed lowmemorykiller behaviour
    - zsmalloc page table method enabled
    - updated ZRAM to the last linux sources from april 2014 with lz4 compression enabled
    - some miscellaneous updates
    Alcuni consigli:
    - installate l'ultima versione di Performance Control
    - abilitate ilDynamic Fsync per performance migliori di i/o in antutu benchmark
    - mettete zram al massimo e alzate vm swappiness fino a 85
    Disclaimer: You're installing this at your own risk. Please, make nandroid backups before installing any of these kernels. I take no responsibility for damaging your phone.
    Kernels:
    -JAKStage 6.2-396Mb - 3.4.96 per le rom basate sulla Cyanogenmod 11.0 (20140616-UNOFFICIAL)
    -JAKStage 6.2-407Mb-3.4.96 per le rom basate sulla Cyanogenmod 11.0 (20140616-UNOFFICIAL)
    -JAKStage 6.2-416Mb-3.4.96 per le rom basate sulla Cyanogenmod 11.0 (20140616-UNOFFICIAL)
    Installazione:
    -Installare il kernel
    -wipe cache partition
    -wipe dalvik cache
    -riavviate il sistema
    [/COLOR][/FONT]
    Have fun
    XDA: DevDB Information
    Just Another Kernel , Kernel for the Samsung Galaxy W I8150
    Contributors
    tycoo
    Kernel Special Features:
    Informazione sulla versione
    Stato: Stable
    Creato il 2014-06-03
    Ultimo aggiornamento 2014-06-30
    Ultima modifica di Redwraith; 09-07-14 alle 16:08 - Motivo: AGGIORNATO Just Another... Stage 6.2 (08/07/2014)
  2. I seguenti 3 Utenti hanno ringraziato Redwraith per il post:
    gaeco392 (04-06-14),IlPessimoFra (04-06-14),NiloGlock (04-06-14)
    Androidiano al prosciutto L'avatar di IlPessimoFra
    Padova
    Galaxy Ace-i, Galaxy W
    Ringraziato 626 volte in 427 Posts
    Mi sembra un ottimo kernel, anche se non lo posso provare perche non ho l'ultima build.
    Finita la scuola spero di poter aggiornare i miei thread, compreso il cafe point. Aggiungerò anche questo kernel, ma per favore, quando hai tempo sistema un po il thread traducendo almeno le parti più importanti in italiano
  5. #3
    Ringraziato 28 volte in 21 Posts
    Quote Originariamente inviato da Fra98 Visualizza il messaggio
    Io l'ho provato, e devo dire che, a parte un consumo della batteria aumentato, come prestazioni ho notato ben poche differenze
  6. Il seguente Utente ha ringraziato ayesse per il post:
  7. #4
    Sep 2013
    Samsung Galaxy W
    Si anche io quando finirò la scuola cercherò di mettere a posto questo thread con le traduzioni e comunque l'inglese con cui è scritto è quello base,chiunque potrebbe capirlo.
    Quote Originariamente inviato da ayesse Visualizza il messaggio
    Grazie per questa osservazione,per modificare le partizioni del trim (se stai usando la vesione trim support)prova ad usare lagtrim fix che trovi sul playstore, se settato correttamente potrebbe aumentare le prestazioni.
    PS:io devo ancora provarlo quindi sulla durata della batteria non so che dirti ma dubito che sia dovuto al trim support...
    Ultima modifica di Redwraith; 04-06-14 alle 22:44
  8. #5
    Sep 2013
    Samsung Galaxy W
    Aggiornato il thread con l'ultimo kernel di tycoo,qui sotto la descrizione dei cambiamenti:
    codice:
    - Revert "audit: kiss goodbye you stupid piece of crap logging messages." (Credits to tycoo)
    - sched: convert WARN_ON() to printk_sched() in try_to_wake_up_local() (Credits to Syed Rameez Mustafa)
    - tracing/sched: add load balancer tracepoint (Credits to Steve Muckle)
    - sched: change WARN_ON_ONCE to WARN_ON in try_to_wake_up_local() (Credits to Steve Muckle)
    - sched: remove migration notification from RT class (Credits to Steve Muckle)
    - sched: fix reference to wrong cfs_rq (Credits to Srivatsa Vaddagiri)
    - sched: Fix SCHED_HRTICK bug leading to late preemption of tasks (Credits to Srivatsa Vaddagiri)
    - sched: Mark schedule_io_timeout() with EXPORT_SYMBOL (Credits to Jordan Crouse)
    - sched: provide per cpu-cgroup option to notify on migrations (Credits to Steve Muckle)
    - sched: fix rq->lock recursion (Credits to Srivatsa Vaddagiri)
    - Squashed update of kernel from 3.4.94 to 3.4.95 (Credits to Cristoforo Cataldo)
    - Add default configuration for JAKStage6 (Credits to tycoo)
  9. I seguenti 2 Utenti hanno ringraziato Redwraith per il post:
    IlPessimoFra (01-07-14),NiloGlock (01-07-14)
  10. #6
    Sep 2013
    Samsung Galaxy W
    Aggiornato il thread!!Per informazioni sui cambiamenti leggete qui sotto:
    codice:
    - block: row: Fix crash when adding a new field in bio struct (Credits to Tanya Brokhman)
    - mmc: core: invoke low power mode if card is not present (Credits to Asutosh Das)
    - mmc: core: enhance card removal judgement for slow removal (Credits to Kevin Liu)
    - zram: revalidate disk after capacity change (Credits to Minchan Kim)
    - lz4: add overrun checks to lz4_uncompress_unknownoutputsize() (Credits to Greg Kroah-Hartman)
    - lz4: fix another possible overrun (Credits to Greg Kroah-Hartman)
    - lz4: ensure length does not wrap (Credits to Greg Kroah-Hartman)
    - msm7x30: Use a higher memory allocation if CMA is used for ION MM heap (Credits to Cristoforo Cataldo)
    - Added Christophers HighMemConfigurations again (Credits to tycoo)
    - msm7x30: Update defconfigs (Credits to Cristoforo Cataldo)
    - msm7x30: Use CMA for PMEM ADSP (Credits to Cristoforo Cataldo)
    - msm7x30: Allow to optionally enable the use of CMA for ION MM and PMEM ADSP heaps (Credits to Cristoforo Cataldo)
    - msm7x30: Simplify the code for hybrid memory allocations on board side (Credits to Cristoforo Cataldo)
    - misc: pmem: Support for dynamic allocation through CMA (Credits to Cristoforo Cataldo)
    - block: bfq: Squashed update from BFQ-v7r4 to BFQ-v7r5 (Credits to Arne Coucheron)
    - Squashed update of kernel from 3.4.95 to 3.4.96 (Credits to Arne Coucheron)
    - epoll: fix use-after-free in eventpoll_release_file (Credits to Konstantin Khlebnikov)
    - staging: binder: add vm_fault handler (Credits to Vinayak Menon)
    - binder: don't allow mmap() by process other than proc->tsk (Credits to Al Viro)
    Da ora il kernel non è più undervolted perchè tycoo (lo sviluppatore) crede che non sia stabile.
  11. Il seguente Utente ha ringraziato Redwraith per il post:
    IlPessimoFra (12-07-14)
