Pagina 1 di 4 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 33
[Kernel][CM 11][ION+PMEM] KhaN Kernel by lafactorial
    Androidiano al prosciutto L'avatar di IlPessimoFra
    Padova
    Galaxy Ace-i, Galaxy W
    Ringraziato 626 volte in 427 Posts
    [Kernel] CM 11 - 4.4.2 - [ION+PMEM] Khan Kernel v1.4 ( 01.01.2014 )
    FEATURES
    *Kernel 3.4.75
    *Build with Linaro GCC 4.8.3 2013.11 toolchain by Christopher83
    *O3 Optimization
    *Overclock up to 1.8 GHz
    *CPU voltage control VDD sys interface
    *Lowered display panel voltage
    *Lowered wifi voltage
    *Lowered vibetonz voltage
    *Fast Charge support
    *Battery Life eXtender support
    *Increase audio loudness
    *Con Kolivas' CK3 Tweaks
    *Fast Random generator (frandom) support
    *Dynamic management of dirty page writebacks
    *Dynamic management of the minimal slack
    *Dynamic file sync
    *Dynamic read-ahead
    *LowMemoryKiller management of not killable processes
    *368MB Ram
    *Governers : adaptive , conservative, lulzactive, interactive, interactiveX, ondemand, ondemandX, powersave, smartassV2, lionheart, performance
    *I/O schedulers : noop, deadline, vr, sio, row, cfq, bfq, fiops
    INSTALLAZIONE
    Riavviare in recovery mode
    Flashare il kernel
    Wipe cache
    Wipe dalvik cache
    Riavviare
    DOWNLOAD
    Khan Kernel stock RAM
    http://forum.xda-developers.com/devd...ct/dl/?id=3299
    Khan Kernel 361 MB RAM
    http://forum.xda-developers.com/devd...ct/dl/?id=3300
    Vecchie versioni
    http://forum.xda-developers.com/devd...2278#downloads
    Per cambiare le features potete usare Performance Control
    CHANGELOG
    v1.1
    -Sync with arco's latest changes (Adjust memory
    allocations again )
    v1.2
    -removed 61 Mhz and 518 Mhz
    -fixed sound lag in lulzactive
    v1.3
    -Build with Linaro GCC 4.8.3 2013.12 toolchain
    by Christopher83
    v1.4
    -USB OTG and zRAM fixes (credits
    Christopher83)
    -Revised memory allocations.Stock ram and
    361Mb of ram.
    CREDITI
    arco68
    Christopher83
    educk
    madridii
    arsradu
    and all github users for their commits
    Ultima modifica di dieguccio; 12-03-14 alle 23:15
  2. I seguenti 3 Utenti hanno ringraziato IlPessimoFra per il post:
    Fabryzio12 (05-01-14),NiloGlock (01-01-14),Redwraith (26-01-14)
    Padova
    Dieguccio, please potresti cambiare il titolo di questo post in
    Ultima modifica di IlPessimoFra; 26-01-14 alle 19:00
  5. #3
    Segnalo link di download errati
  6. #4
    Padova
    Quote Originariamente inviato da novastories Visualizza il messaggio
    Sistemato e aggiunto anche i changelog
  7. Il seguente Utente ha ringraziato IlPessimoFra per il post:
    novastories (26-01-14)
  8. #5
    Spettacolo :-D
  9. #6
    Samsung galaxy wonder
    Salve, prossimamente cercherò di installare la CM11, questo "kernel" è qualcosa di aggiuntivo ad essa? Se si, cosa migliora se non l'avessi? grazie
  10. #7
    Padova
    Quote Originariamente inviato da 06mario91 Visualizza il messaggio
    Hai più governator e scheduler, in teoria hai l'overclock fino a 1,8 GHz
    Ultima modifica di IlPessimoFra; 26-01-14 alle 15:15
  11. #8
    Quote Originariamente inviato da Fra98 Visualizza il messaggio
    Hai più governatore e scheduler, in teoria hai l'overclock fino a 1,8 GHz
    Mmm..non c'ho capito granchè =P insomma, dopo aver messo CM11 posso mettere anche il kernel, su questo credo di aver capito bene..l'overclock mi migliora le prestazioni e quindi sarà piu performante (correggimi se sbaglio), ma governatore e scheduler?
    Vorrei piu che altro capire se le differenze sono notevoli (e quindi mi consigli spassionatamente di metterla), oppure solo la CM11, per me che sono alle prime armi e che cerco semplicemente di aver un cell che non si blocca e non va lentissimo. va piu che bene =D
  12. #9
    Padova
    Allora, anche il governator e scheduler si possono settare in modo da migliorare le prestazioni o la batteria o trovare un buon compromesso tra le due cose...
    Se aumenti la frequenza del processore aumentano le prestazioni ma la batteria ti va giù prima...
    Questa ROM secondo me deve essere ancora un po migliorata... A me si blocca spesso ma molti utenti invece si ritengono più che soddisfatti... Magari prova a chiedere nel thread della CM11.0 e vedi un po cosa ti dicono!
  13. Il seguente Utente ha ringraziato IlPessimoFra per il post:
    06mario91 (26-01-14)
  14. #10
    Sassari
    LG G2, LeMax 2
    Non funzionante sulla build 9 di arco..
    Il processo com.android.phone è stato interrotto.
    P.S. Ho usato la versione con swap della RAM.
    Ultima modifica di NiloGlock; 12-03-14 alle 16:02
    Smartphone:
