Pagina 4 di 10 primaprima ... 23456 ... ultimoultimo
Visualizzazione dei risultati da 31 a 40 su 98
[KERNEL][3.4.x][KK] K^Kernel 3.4.x per KitKat ION+PMEM ADSP
  1. #31
    Senior Droid L'avatar di Christopher83
    Samsung Galaxy S Plus (I9001)
    Ringraziato 1,307 volte in 314 Posts
    Ciao a tutti,
    ho rilasciato le build del kernel v1.1:
    codice:
    - Kernel 3.4.94
    - Built with my latest custom Linaro 4.9.1-2014.06 toolchain optimized for Cortex-A8
    - power: ancora_battery: Remove trailing spaces (credits to Christopher83)
    - power: ancora_tmo_battery: Remove trailing spaces (credits to Christopher83)
    - power: apache_battery: Remove trailing spaces (credits to Christopher83)
    - power: ancora_tmo_battery: Add Battery Life eXtender (BLX) support (credits to Christopher83)
    - power: apache_battery: Add Battery Life eXtender (BLX) support (credits to Christopher83)
    - power: apache_battery: 100% battery notification after charger unplug (credits to Christopher83)
    - power: ancora_battery: Increase battery check interval from 5 seconds to 15 seconds (credits to Christopher83)
    - power: ancora_tmo_battery: Increase battery check interval from 5 seconds to 15 seconds (credits to Christopher83)
    - power: apache_battery: Increase battery check interval from 5 seconds to 15 seconds (credits to Christopher83)
    - ancora_tmo: High memory configurations (credits to Christopher83)
    - apache: High memory configurations (credits to Christopher83)
    - msm7x30: Better manage cpu frequencies for MSM8255 and MSM8255T (credits to Christopher83)
    - ancora_tmo: Add custom defconfigs (credits to Christopher83)
    - apache: Add custom defconfigs (credits to Christopher83)
    - arm: Add a config option to use GLibC memcpy and memmove versions (credits to Christopher83)
    - msm7x30: Update defconfigs to use GLibC versions of memcpy and memmove (credits to Christopher83)
    - mmc: msm_sdcc: Advertise erase capability for ancora_tmo and apache (credits to arco68)
    - sec_jack: updated driver (credits to CastagnaIT)
    - mm: cma: fix alignment requirements for contiguous regions (credits to Marek Szyprowski)
    - drivers: cma: represent physical addresses as phys_addr_t (credits to Vitaly Andrianov)
    - drivers: dma-contiguous: refactor dma_alloc_from_contiguous() (credits to Michal Nazarewicz)
    - mm: cma: fix condition check when setting global cma area (credits to Marek Szyprowski)
    - drivers: dma-contiguous: clean source code and prepare for device tree (credits to Marek Szyprowski)
    - drivers: dma-contiguous: add initialization from device tree (credits to Marek Szyprowski)
    - cma: Remove __init annotations from data structures (credits to Laura Abbott)
    - cma: Fix up devicetree bindings (credits to Laura Abbott)
    - cma: Add support for associating regions by name (credits to Laura Abbott)
    - cma: Remove restriction on region names (credits to Laura Abbott)
    - cma: use MEMBLOCK_ALLOC_ANYWHERE for placing CMA regions (credits to Laura Abbott)
    - cma: Add API to get the start address of a CMA region (credits to Laura Abbott)
    - cma: Remove potential deadlock situation (credits to Laura Abbott)
    - cma: Add support for memory limits (credits to Laura Abbott)
    - cma: Make locking finer grained (credits to Laura Abbott)
    - cma: Drop the right mutex (credits to Laura Abbott)
    - dma-contiguous: Return 'zero' pfn in case of error (credits to Chintan Pandya)
    - ARM: dma-mapping: fix incorrect freeing of atomic allocations (credits to Aaro Koskinen)
    - mm: vmalloc: use const void * for caller argument (credits to Marek Szyprowski)
    - ARM: dma-mapping: remove custom consistent dma region (credits to Marek Szyprowski)
    - mm: push lru index into shrink_[in]active_list() (credits to Konstantin Khlebnikov)
    - mm: vmscan: remove lumpy reclaim (credits to Mel Gorman)
    - mm: vmscan: do not stall on writeback during memory compaction (credits to Mel Gorman)
    - mm: vmscan: remove reclaim_mode_t (credits to Mel Gorman)
    - mm: remove lru type checks from __isolate_lru_page() (credits to Konstantin Khlebnikov)
    - mm/memcg: kill mem_cgroup_lru_del() (credits to Konstantin Khlebnikov)
    - mm/memcg: scanning_global_lru means mem_cgroup_disabled (credits to Hugh Dickins)
    - mm/memcg: use vm_swappiness from target memory cgroup (credits to Konstantin Khlebnikov)
    - mm: remove swap token code (credits to Rik van Riel)
    - mm/vmscan: store "priority" in struct scan_control (credits to Konstantin Khlebnikov)
    - kernel: cgroup: push rcu read locking from css_is_ancestor() to callsite (credits to Johannes Weiner)
    - mm: memcg: count pte references from every member of the reclaimed hierarchy (credits to Johannes Weiner)
    - mm/vmscan: push zone pointer into shrink_page_list() (credits to Konstantin Khlebnikov)
    - mm/vmscan: push lruvec pointer into isolate_lru_pages() (credits to Konstantin Khlebnikov)
    - mm/vmscan: remove update_isolated_counts() (credits to Konstantin Khlebnikov)
    - mm: cma: discard clean pages during contiguous allocation instead of migration (credits to Minchan Kim)
    - cma: decrease cc.nr_migratepages after reclaiming pagelist (credits to Minchan Kim)
    - mm/compaction.c: fix deferring compaction mistake (credits to Minchan Kim)
    - mm: compaction: Abort async compaction if locks are contended or taking too long (credits to Mel Gorman)
    - mm: compaction: update comment in try_to_compact_pages (credits to Mel Gorman)
    - mm: compaction: capture a suitable high-order page immediately when it is made available (credits to Mel Gorman)
    - mm: compaction: abort compaction loop if lock is contended or run too long (credits to Shaohua Li)
    - mm: compaction: move fatal signal check out of compact_checklock_irqsave (credits to Mel Gorman)
    - mm: compaction: Update try_to_compact_pages()kerneldoc comment (credits to Mel Gorman)
    - mm: compaction: acquire the zone->lru_lock as late as possible (credits to Mel Gorman)
    - mm: compaction: acquire the zone->lock as late as possible (credits to Mel Gorman)
    - mm: compaction: cache if a pageblock was scanned and no pages were isolated (credits to Mel Gorman)
    - mm: cma: WARN if freed memory is still in use (credits to Marek Szyprowski)
    - mm: do not use page_count() without a page pin (credits to Minchan Kim)
    - mm: clean up __count_immobile_pages() (credits to Minchan Kim)
    - mm: compaction: Restart compaction from near where it left off (credits to Mel Gorman)
    - mm: compaction: clear PG_migrate_skip based on compaction and reclaim activity (credits to Mel Gorman)
    - CMA: migrate mlocked pages (credits to Minchan Kim)
    - mm: compaction: correct the nr_strict va isolated check for CMA (credits to Mel Gorman)
    - mm: compaction: validate pfn range passed to isolate_freepages_block (credits to Mel Gorman)
    - mm: compaction: Move migration fail/success stats to migrate.c (credits to Mel Gorman)
    - mm: compaction: Add scanned and isolated counters for compaction (credits to Mel Gorman)
    - mm: cma: skip watermarks check for already isolated blocks in split_free_page() (credits to Marek Szyprowski)
    - mm: compaction: partially revert capture of suitable high-order page (credits to Mel Gorman)
    - compaction: fix build error in CMA && !COMPACTION (credits to Minchan Kim)
    - mm: vmscan: do not keep kswapd looping forever due to individual uncompactable zones (credits to Johannes Weiner)
    - mm: vmscan: Fix build error (credits to Christopher83)
    - msm: Allow lowmem to be non contiguous and mixed. (credits to Neeti Desai)
    - msm: Increase the kernel virtual area to include lowmem (credits to Neeti Desai)
    - mm: Remove __init annotations from free_bootmem_late (credits to Laura Abbott)
    - kernel/lib: add additional debug capabilites for data corruption (credits to Syed Rameez Mustafa)
    - mm: panic on the first bad page table entry access (credits to Pushkar Joshi)
    - mm: Update is_vmalloc_addr to account for vmalloc savings (credits to Laura Abbott)
    - slub: tid must be retrieved from the percpu area of the current processor (credits to Christoph Lameter)
    - mm: vmscan: Move pages that fail swapout to LRU active list (credits to Olav Haugan)
    - mm: swap: Rate limit swap write errors (credits to Olav Haugan)
    - mm: change freepage state correctly in __isolate_free_page (credits to Laura Abbott)
    - mm: make is_vmalloc_addr lockless (credits to Laura Abbott)
    - mm/compaction: Break out of loop on !PageBuddy in isolate_freepages_block (credits to Laura Abbott)
    - mm: compaction: fix bit ranges in {get,clear,set}_pageblock_skip() (credits to Bartlomiej Zolnierkiewicz)
    - msm: kgsl: hold a process_private refcount in process_mem_print (credits to Jeremy Gebben)
    - msm: kgsl: Look up the process struct in process_mem_open() (credits to Jordan Crouse)
    - msm: kgsl: prevent kgsl_get_pagetable from returning a destroyed pt (credits to Jeff Boody)
    - msm: kgsl: Fix spinlock recursion in destroy pagetable (credits to Prakash Kamliya)
    - gpu: ion: Don't call virt_to_page on addresses from dma_alloc (credits to Laura Abbott)
    - gpu: ion: Explictly mark DMA allocations as GFP_KERNEL (credits to Laura Abbott)
    Samsung Galaxy S Plus (GT-I9001)
  2. I seguenti 5 Utenti hanno ringraziato Christopher83 per il post:
    fra85 (24-06-14),IlPessimoFra (24-06-14),jnr88 (24-06-14),KIKO81 (24-06-14),Redwraith (24-06-14)
    Androidiano al prosciutto L'avatar di IlPessimoFra
    Padova
    Galaxy Ace-i, Galaxy W
    Ringraziato 626 volte in 427 Posts
    Yeeeeeeeeeeeeeeeeeeeeeeeeeeeeee... Anche se non posso provarlo... Il mio telefono è in coma
  5. #33
    Feb 2014
    galaxy w
    Grande christopher,appena scaricato e installato,sempre la versione da 406mb ma questa volta provo prima la exuv,vediamo come si comporta!
  6. Il seguente Utente ha ringraziato fra85 per il post:
    Christopher83 (24-06-14)
  7. #34
    Sep 2013
    Samsung Galaxy W
    Ringraziato 155 volte in 120 Posts
    Ben fatto,ma come mai i changelog dei tuoi kernel sono ogni volta così lunghi ?
  8. Il seguente Utente ha ringraziato Redwraith per il post:
  9. #35
    Quote Originariamente inviato da Redwraith Visualizza il messaggio
    Eh, tutte le commit che aggiungo al kernel vengono giustamente riportate nel changelog...
  10. I seguenti 2 Utenti hanno ringraziato Christopher83 per il post:
    giogio1 (25-06-14),Redwraith (24-06-14)
  11. #36
    ciao, flashato su cm11 di arco la 390 sia uv che exuv, sia 1.0 che 1.1 ma in tutti casi non mi funziona il wifi... rimedi?
  12. #37
    Ringraziato 28 volte in 21 Posts
    Quote Originariamente inviato da navax Visualizza il messaggio
    Hai fatto wipe cache e dalvik cache?
  13. #38
    Il problema è causato dalle Gapps. Il pacchetto è troppo grande, la partizione di sistema è quasi piena e non c'è spazio per i moduli del kernel.
    Prova a cancellare delle app di sistema inutili oppure a riflashare rom e un pacchetto di gapps più piccolo.
  14. Il seguente Utente ha ringraziato Christopher83 per il post:
    Redwraith (25-06-14)
  15. #39
    Androidiano L'avatar di giogio1
    Ringraziato 34 volte in 23 Posts
    Quote Originariamente inviato da Christopher83 Visualizza il messaggio
    Grazie mille per la condivisione del tuo lavoro
  16. Il seguente Utente ha ringraziato giogio1 per il post:
    Christopher83 (25-06-14)
  17. #40
    OK grazie, provo con le gapps più piccole, cmq ottimo lavoro.
  18. Il seguente Utente ha ringraziato navax per il post:
