AOSB Builds - Galaxy W (i8150)
https://www.lucidchart.com/publicSeg...8cac/image.png
ASOB Features:
* Hover
* New Port of MultiWindow and Exclusive Customization and Fixes and Improvement
* OTA Support
* Android-4.4.4
* AOSB Feature: Custom SmoothProgressBar with v0.4 API
* AOSB Feature: Control and customize "Toast Animation"
* AOSB Recent App with HTC Style
* AOSB Power Saver Manager
* Battery Saver mode included what user do to saving the battery life
* PA PEEK Notification with wake timeout && configurable timeout
* Launch as Floating notification from anywhere
* New CM Theme Engine
* DSP Manager with built-in Boeffla Sound Control
* GPS Optimizer , modify gps conf your country
* Advanced Kernel tweaker and device performance control
* Slim Recent App Bar
* Pinned (lock) app in recent app list
* On-The-Go Mode
* Battery level around unlock ring
* Time-context headers in the notification header
* Wakelock Blocker
* MSIM Network/Devices Support
* Dialer: WhitePages/YellowPages reverse lookup provider
* Dialer: lookup/nearby places, Google and OpenStreetMap
* AOKP Navigation bar menu in settings support hardware keys devices
* AOKP Animation Control
* ListView Animation
* Keyboard Animation
* Scrolling Animation
* AOKP Custom Navigation Ring
* AOKP Custom Navigation Bar
* ChameleonOS Gesture Anywhere
* ChameleonOS Screen Recording
* ChameleonOS Screen Recorder: add ability to record audio from mic
* TeloRadio (Connection Manager)
* Omni Audio Themes Settings
* OmniSwitch App
* Omni allow disabling call end sound
* Omni Audio : Stereo widening and Center frequency for Bass Boost
* AOSPAL LockScreen Notifications
* AOSPAL Lockscreen Blur
* Slim CRT animation: add scale down
* Slim IME options
* Slim DarkUI (system wide in black)
* Music Tile
* Flip to Mute/Reject Call
* Advanced BatteryBar
* Chainfire SU App
* User selectable camera click sound (disable camera sound)
* Quicktile row option:set 3,4,5 tiles per row
* LTE toggle support and Configurable up to user (LTE or 4G)
* Add Wifi name to notification drawer and option to enable/disable
* Frameworks: notification drawer background
* wide support for chinese language
* wide support for dutch language
* MediaScanner behavior on boot
* HALO
* HALO MODS
* HALO: make windows move able and scale able
* Mobile Network Battery Saver Mode
* Configurable up to user (LTE or 4G)
* Advanced Battery Bar
* FB sync abbility to connect facebook contacts into contacts app
* App sidebar
* IME switcher notification
* Navigation bar with custom dimensions
* Screen video recording
* Configurable init.d
* Build PropModder
* Incoming calls dialog
* RAM bar with custom colors
* Builtin Xposed Framework
* Xposed : Per-App Layout
* Network usage stats
* ChameleonOS Active display (s-view alternative)
* AD: Display Time out
* AD: Turn Off Display
* AD: Threshold to proximity
* AD: Sort notifications by newest to oldest
* AD: douple tab to sleep
* AD: limit notifications
* AD: display bypass, pocket and sunlight mods
* mms: iOS features
* mms: Emoji and Smiley support
* samsung kernel super charged
* Advanced low battery indicator options
* Custom Carrier Label
>> CHANGELOG <<
Versione del firmware: 4.4.4 KitKat
Versione del Kernel: Linux 3.4
Requisiti: Root e ClockworkMod Recovery
Basata su: CyanogenMod 11 by arco68
INFORMAZIONI
Stadio dello sviluppo: STABILE
Ultima relase: v.1.3.7
Data del rilascio: 28/10/2014
LINK DISCUSSIONE UFFICIALE SU XDA
