Utente della settimana: 9mm con ben 5 Thanks ricevuti negli ultimi sette giorni
aiuto super1click!!!!!!!!!!!!!!!!!!!Rooting device... - Step #4 ./psneuter: not found
    allora ho seguito tutto il procedimento ma arrivati allo step 3 si blocca e appare la scritta FAILED! riporto tutto:SuperOneClick v2.1.1.0
    Checking drivers...
    Killing ADB Server...
    OK 0,07s
    Starting ADB Server...
    * daemon not running. starting it now on port 5037 *
    * daemon started successfully *
    OK 4,12s
    Waiting for device...
    OK 0,02s
    2.1.1
    Getting manufacturer...
    Sony Ericsson
    OK 0,02s
    Getting model...
    E15i
    OK 0,02s
    Getting version...
    -X_d
    OK 0,02s
    Checking if rooted...
    False
    OK 0,03s
    Installing BusyBox (temporary)... - Step #1
    1575 KB/s (1062992 bytes in 0.659s)
    OK 0,71s
    Installing BusyBox (temporary)... - Step #2
    OK 0,02s
    Rooting device... - Step #1
    cannot stat 'C:\Users\Guest\Downloads\SuperOneClickv2.1.1-ShortFuse\Exploits\psneuter': No such file or directory
    OK 0,06s
    Rooting device... - Step #2
    Unable to chmod /data/local/tmp/psneuter: No such file or directory
    OK 0,02s
    Rooting device... - Step #3
    OK 0,00s
    FAILED
    aiuto,sono disperato!
