Pagina 4 di 6 primaprima ... 23456 ultimoultimo
Visualizzazione dei risultati da 31 a 40 su 52
[GUIDA] Installare il concept marshmallow su z3 compact
  1. #31
    provo a spegnerlo e ripetere l'operazione di installazione della rom di questo 3d?
    flashtool me lo riconoscerà da spento?
    comunque questo è il log:
    24/010/2016 13:10:35 - INFO - Opening TA partition 1
    24/010/2016 13:10:35 - INFO - Start Dumping TA partition 1
    24/010/2016 13:10:35 - INFO - Finished Dumping TA partition 1
    24/010/2016 13:10:35 - INFO - TA partition 1 saved to C:\Users\Maiky\.flashTool\registeredDevices\YT910Z CVKG\s1ta\2016-02-24_01-10-35\1.ta
    24/010/2016 13:10:35 - INFO - Closing TA partition
    24/010/2016 13:10:35 - INFO - Opening TA partition 2
    24/010/2016 13:10:35 - INFO - Start Dumping TA partition 2
    24/010/2016 13:10:36 - INFO - Finished Dumping TA partition 2
    24/010/2016 13:10:36 - INFO - TA partition 2 saved to C:\Users\Maiky\.flashTool\registeredDevices\YT910Z CVKG\s1ta\2016-02-24_01-10-35\2.ta
    24/010/2016 13:10:36 - INFO - Closing TA partition
    24/010/2016 13:10:47 - INFO - Found a template session. Using it : C:\Users\Maiky\.flashTool\devices\D58XX\default.fs c
    24/010/2016 13:10:48 - INFO - Opening TA partition 2
    24/010/2016 13:10:48 - INFO - Writing TA unit 00002774. Value : [01]
    24/010/2016 13:10:48 - INFO - Closing TA partition
    24/010/2016 13:10:48 - INFO - Processing partition-image.sin
    24/010/2016 13:10:48 - INFO - Checking header
    24/010/2016 13:10:48 - INFO - Flashing data
    24/010/2016 13:10:48 - INFO - Writing TA unit 0000084f. Value : [1A, CE, 1D, 00, 01, 00, 04, 05, 00, 02, 02, 08, 00, 10, 03, 00, 02, 04, 02, 05, 00, 01, 03, 02, 00, 10, 05, 00, 03, 03, 05, 00, 10, 12, 00, 02, 00, A9, 09, BE, BA, A9, 09, 00, 00, B3, 08, BE, BA, B3, 08, 00, 00, 04, 00, 03, 00, 02, 00, 04, 00, 04, 00, B0, 04, 0E, 00, 06, 00, B8, 0B, 01, 4B, 00, 00, 00, 03, 96, 00, 2C, 01, 03, 00, 09, 00, 01]
    24/010/2016 13:10:48 - INFO - Writing TA unit 000008fd. Value : [00]
    24/010/2016 13:10:49 - INFO - Opening TA partition 2
    24/010/2016 13:10:49 - INFO - Processing dbi.sin
    24/010/2016 13:10:49 - INFO - Checking header
    24/010/2016 13:10:49 - INFO - Flashing data
    24/010/2016 13:10:49 - WARN - emmc_appsboot is excluded from bundle
    24/010/2016 13:10:49 - INFO - Processing rpm.sin
    24/010/2016 13:10:49 - INFO - Processing s1sbl.sin
    24/010/2016 13:10:49 - INFO - Processing sbl1.sin
    24/010/2016 13:10:49 - INFO - Processing tz.sin
    24/010/2016 13:10:49 - INFO - Closing TA partition
    24/010/2016 13:10:49 - INFO - Processing cache.sin
    24/010/2016 13:10:50 - WARN - apps_log is excluded from bundle
    24/010/2016 13:10:50 - WARN - kernel is excluded from bundle
    24/010/2016 13:10:50 - WARN - fotakernel is excluded from bundle
    24/010/2016 13:10:50 - INFO - Closing TA partition
    24/010/2016 13:10:50 - INFO - Opening TA partition 2
    24/010/2016 13:10:50 - WARN - userdata is excluded from bundle
    24/010/2016 13:10:50 - INFO - Processing system.sin
    24/010/2016 13:10:50 - INFO - Checking header
    24/010/2016 13:10:50 - INFO - Flashing data
    24/015/2016 13:15:09 - INFO - Processing amss_fs_1.sin
    24/015/2016 13:15:09 - INFO - Checking header
    24/015/2016 13:15:09 - INFO - Flashing data
    24/015/2016 13:15:09 - INFO - Processing amss_fs_2.sin
    24/015/2016 13:15:09 - INFO - Processing amss_fsg.sin
    24/015/2016 13:15:09 - INFO - Closing TA partition
    24/015/2016 13:15:09 - INFO - Opening TA partition 2
    24/015/2016 13:15:09 - WARN - Unit 2212 not found in bundle
    24/015/2016 13:15:09 - WARN - Unit 2404 not found in bundle
    24/015/2016 13:15:09 - WARN - elabel is excluded from bundle
    24/015/2016 13:15:09 - INFO - Writing TA unit 00002725. Value : [32, 30, 31, 36, 2D, 30, 32, 2D, 32, 34, 20, 31, 33, 3A, 31, 35, 3A, 30, 39, 00]
    24/015/2016 13:15:09 - INFO - Writing TA unit 00002774. Value : [00]
    24/015/2016 13:15:09 - INFO - Ending flash session
    24/015/2016 13:15:09 - INFO - Flashing finished.
    24/015/2016 13:15:09 - INFO - Please unplug and start your phone
    24/015/2016 13:15:09 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings
    Androidiano L'avatar di compuman
    Samsung Galaxy S10
    Ringraziato 18 volte in 13 Posts
    1)Innanzitutto cerca l'ftf ultimo disponibile (3027) così ti risparmi un bel po' di aggiornamenti
    2)Quando flashi l'ftf è consigliatissimo (se non necessario quasi sempre) cancellare la partizione DATI, altrimenti ti ritrovi un sistema instabile (o peggio un bootloop come è successo a te).
    3)in particolare ci sono 2 cose da selezionare (per fare pulizia) nella versione recente di flashtools (ora non ce l'ho su questo PC, altrimenti sarei stato più chiaro) e DEVI rispondere NO quando ti chiede se vuoi usare uno script durante il flash.
    fatto questo il telefono ti riaprtirà regolarmente, vai tranquillo
    Samsung S10 (SM-G973F ITV/ITV,ITV/ITV)
    Sony Z3 Compact (D5803)
    BOOTLOADER: UNlocked (DRM saved with TA partition)
  4. #33
    Quote Originariamente inviato da compuman Visualizza il messaggio
    CIao grazie per la risposta,
    ho usato questa rom perchè avevo letto che gli aggiornamenti si potevano fare via ota.
    posso anche con la 3027?
    ora come faccio a far riconoscere a flashtool il telefono?
    devo saltare la parte a telefono acceso(ovviamente)
    e partire direttamente dalla sezione flash in download mode giusto?
    p.s. già che ci sono come si cancella la partizione dati?
    non vedo la sezione su flashtool
    grazie,gentilissimo
    Ultima modifica di Maiky28; 24-02-16 alle 15:10
  5. #34
    risolto:
    prima del flash chiede:
    A FSC SCRIPT IS FOUND.DO YOU WANT TO USE IT?
    la prima volta ho risposto sì e ho brickato il telefono.
    rispondendo no ho risolto.
    ora google play service crasha ogni 2-3 secondi ma conto di risolvere
    installando manualmente l'ultima versione,senno tocca
    tornare a lollipop
    Ultima modifica di Maiky28; 24-02-16 alle 22:02
  6. #35
    Nov 2013
    Sony Xperia Z3 compact
    Ringraziato 22 volte in 22 Posts
    Per installare questo concept bisogna sbloccare il bootloader?
    Per chi sta usando il concept cortesemente qualcuno riesce a verificare se, senza root, riuscite ad avere il mirroring completo su PC tramite l'app "mobizen"?
    Grazie mille in anticipo!
    Ultima modifica di loorenz; 25-02-16 alle 10:31
  7. #36
    Androidiano VIP L'avatar di Spardantex
    Sicilia
    iPhone SE
    Ringraziato 147 volte in 136 Posts
    Quote Originariamente inviato da loorenz Visualizza il messaggio
    No
    Per il root bisogna sbloccare il BL
    Smartphone precedenti:
    HTC One Mini; One S; Nexus One; Sony Xperia XZ1c; Xc; Z3c; P; Mini; X8; Motorola Moto X; Moto G; iPhone 5s; 5; 4; Samsung Galaxy S II; Galaxy S; Galaxy Ace; LG Nexus 5x; Optimus 4X HD; Optimus Sol; Optimus L3; Nokia Lumia 925; N900; E72; BlackBerry Torch 9800.
  8. #37
    fra47
    Non per forza bisogna sbloccare il bootloader per ottenere il root
  9. #38
    Sicilia
    iPhone SE
    Quote Originariamente inviato da fra47 Visualizza il messaggio
    Per installare il concept rootato sì.
  10. #39
    fra47
    Ah ok, avevo capito male io scusa
  11. #40
    Feb 2016
    Ragazzi scusate se mi intrometto, per fare un' installazione pulita ufficiale e con l' ultima build basta scaricare l' applicativo ufficiale Sony Concept Installer per PC facilmente reperibile in rete e basterà collegare il vostro Xperia e installerà l' ultima versione concept disponibile, in più se si vuole ritornare a Lollipop sempre con lo stesso applicativo si può fare senza utilizzare flashtool
    Ultima modifica di dr4k0; 29-02-16 alle 12:10
