[ROM][STAR N9500 MTK 6589] Most Epic Rom Ever
Hardware : MT6589
Model : N9500
Build number : MHD140501freedgt
Build date UTC : 20130720-094302
Android v : 4.2.2
Baseband v: MOLY.WR8.W1248.MD.WG.MP.V14, 2013/10/25 17:05
Kernel v : 3.4.5 (root@android) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP Fri Jul 12 16:14:04 CST 2013
Driver IC : 1-LT050ANKP019A
for your language set morelocale2
Description
Steps in Flashing:
Place in sdcard
Reboot to recovery (TWRP/CWM)
Wipe data, system, cache, dalvik-cache
Flash N9500MERE-HD.zip
Reboot
How to use Engineer Mode to increase volume levels.
Applicable to all MTK65XX devices
Go to Settings>Engineering Mode>Hardware Testing>Audio>LoudSpeaker Mode
1. Dial: *#*#3646633#*#*
2. @Level 0 set Value to 135 tap Set, Max Vol. =160 tap Set
3. @Level 1 set Value to 155 tap Set, Max Vol. =160 tap Set
4. @Level 2 set Value to 175 tap Set, Max Vol. =160 tap Set
5. @Level 3 set Value to 195 tap Set, Max Vol. =160 tap Set
6. @Level 4 set Value to 215 tap Set, Max Vol. =160 tap Set
7. @Level 5 set Value to 235 tap Set, Max Vol. =160 tap Set
8. @Level 6 set Value to 255 tap Set, Max Vol. =160 tap Set
9. Exit Engineer Mode
Caution:
Setting maximum volume may damageyour internal speaker.
The safest maximum volumevalue is default @ 144.
NOTE:
First boot may take a long time. DO NOT PANIC.
Optimizations are done on the first 30 seconds of every boot. Please be patient. (BRY Engine Users Know this)
Before benchmarking reboot your phone first before running your favorite benchmarking app and set your Governor to default (Hotplug) if ever you changed it.
DO NOT USE OTHER BOOT.IMG or KERNEL
DO NOT USE OTHER TWEAKS OR PERFORMANCE ENHANCEMENTS FOR IT MAY CAUSE CONFLICT
This ROM does not support dual 3G, if you don't like this we are not forcing you. You can always flash other ROMS.
thank's to Epic Team
http://i57.tinypic.com/oscvur.png http://www.needrom.com/wp-content/up...34-281x500.jpg
http://i59.tinypic.com/2zy90nc.png http://i58.tinypic.com/nfjoyx.png http://i59.tinypic.com/2exlx7o.png
rom download
https://mega.co.nz/#!1MoUDYCY!LdTQ3h...X7K_wVdSHdxJM8
PAtch sim signal
1 DepositFiles
2 DepositFiles
3 DepositFiles
4 DepositFiles
5 DepositFiles
6 https://mega.co.nz/#!71pkACrL!SV9JSC...YI5tGcvPD5G6zk
