Utente della settimana: carotix con ben 8 Thanks ricevuti negli ultimi sette giorni
[Cerco] Stock Rom Star N3+ [ oppure Backup ]
    Mar 2014
    ciao a tutti non riesco mai a trovare una stock rom per Star N3+.
    il mio problema nasce che il mio touch screen non mi funziona piu.
    non ce nessun modo da provare altrimenti solo stock rom o backup.
    il chinese di ( merda 2 volte) dove lo comprato non risponde mai alle mail.
    forse nemeno i venditori li hanno
    perfavore per chi ha questo telefonino ci passi un backup o alto.
    info tel
    codice:
    Specifications:
    Basic Information
    Model	 N3+
    Band	 2G: GSM 850/900/1800/1900MHz
    3G: WCDMA 850/2100MHz
    Sim Card	 Dual SIM Card Dual Standby(one Micro SIM card)
    Service Provide	 Unlocked
    Style	 Bar
    Color	 Pink, Black, White
    Shell Material	 Plastic
    System
    OS	 Android 4.2.2
    CPU	 MTK6592, Cortex A7 octa core, 1.7GHz;
    GPU: Mali-450 MP4
    ROM	 16GB
    RAM	 2GB
    Screen
    Display Size	 5.7 Inch
    Type	 IPS, capacitive touch screen
    Resolution	 1280 x 720 pixels HD screen
    Screen Color	 1600K Colors
    Support Format
    Ringtones Type	 Polyphonic/MP3
    Audio File Format	 MP3/WAV/AMR/AWB
    Video File Format	 3GP/MPEG4
    Image File Format	 JPEG/BMP/GIF/PNG/GIF
    E-book Format	 TXT/CHM/DOC/HTML
    FM Radio	 Yes, earphone needed
    Earphone Port	 3.5mm
    Card Extend	 Support TF card up to 32GB extended
    Data Transfer & Connectivity
    Data transfer	 micro USB/Bluetooth
    Mobile internet	 WAP/WiFi
    General
    Camera/Picture Resolution	 Dual Cameras, 5.0MP front camera, 13.0MP back camera with flashlight
    and auto focus, up to 4096 X 3072 pixels resolution
    Language	 English, Afrikaans, Bahasa Indonesia, Bahasa Melayu, Catala, Cestina,
    Dansk, Deutsch, Espanol, Filipino, French, Hrvatski, IsiZulu, Italiano,
    Kiswahili, Latviesu, Lietuviu, Magyar, Nederlands, Norsk bokmal,
    Polski, Portuguese, Romana, Rumantsch, Slovencina, Slovenscina,
    Suomi, Svenska, Vietnamese, Turkish, Greek, Bulgarian, Russian,
    Serbian, Ukrainian, Arabic, Urdu, Persian, Hindi, Bengali, Thai,
    Khmer, Korean, Japanese, Simplified/Traditional Chinese
    Phonebook	 500
    Message	 SMS/MMS
    Input	 Handwrite/Keypad
    TV	 No
    GPS	 Yes, built in, also support A-GPS
    With EPO assistance to speed up postioning
    JAVA	 No
    WIFI	 Yes, 802.11 b/g/n
    Bluetooth	 Bluetooth 2.0
    Gravity Sensor	 Yes
    Multi-Touch	 Yes, 5 point touch
    Dimensions	 155 x 80 x 8mm/6.10 x 3.15 x 0.31 inch
    Net Weight(with battery)	 168g
    Standby Time	 About 2~3 days
    Other Feature	 3G, WiFi, GPS, FM, OTG, Bluetooth, Ebook, Email, Gesture Sensing,
    Flash alert, Messaging, Wallpapers, Calendar, Calculator, Clock, Camera,
    Play Store, Tethering & portable hotspot, etc
    Package Size	 185 x 110 x 61mm/7.3 x 4.3 x 2.4 inch
    Weight	 433g
    Package
    1 x N3+ phone
    2 x 3200mAh Batteries(one free)
    1 x leather case
    1 x touch pen
     1 x Earphone
    1 x USB Cable
    1 x Charger
    1 x User Manual
    Oct 2013
    perugia
    LeEco x820
    ho lo stesso identico problema .... il telefono e originale e tutto d'un tratto non va più per niente il tuch ???!!??!?!?? come risolvere ????
    Mar 2014
    Quote Originariamente inviato da MATTIONI82 Visualizza il messaggio
    non puoi risolvere . lo devi mandare dove lo hai comprato .
    puoi provare rom originale ma non credo che farai fortuna
    N3+_20140225_e2709_v92_zlh_hd-[???]?????|????-????-??????
    Oct 2013
    perugia
    LeEco x820
    ora provo, ma la rom è già originale, nessuno l ha toccata....
    quindi per te non si risolve ?????? rimandalo in cina è da piangere.... sempre che mi ritorni !
    Aug 2014
    Se volete su needrom c'é la stock rom kitkat che io uso come stock per peovare e flasharne altre adesso sto provando la 4.4.2 con kernel lollipop e devo dire che dura tutto il giorno non si impalla piu e il sistema usa un totale di 300mb su 2 gb di ram!! Appena vi serve madatemi un pm vi scrivo esattamente quale! Io ho uno star n3+ octacore mtk 6592
  7. Il seguente Utente ha ringraziato geggio1984 per il post:
    pirata70 (15-03-16)
  8. #6
    Aug 2014
    Voila come detto ecco la stock rom migliore ne ho provate 100: http://www.needrom.com/download/star...ock-mod-4-4-2/ invece la roma migliore é questa http://www.needrom.com/download/n3_m...ge-2/#comments
