Star B6000
    Star B6000
    Ragazzi , ho trovato questo dispositivo su pandawill che sembra avere caratteristiche veramente interessanti:
    Band 2G: GSM 850/900/1800/1900MHz
    3G: WCDMA 850/2100MHz
    Sim Card Dual SIM Card Dual Standby
    Service Provide Unlocked
    Style Bar
    Color White
    Shell Material Plastic
    System
    OS Android 4.2.1
    CPU MTK6589T, Cortex A7 quad core, 1.5GHz;
    GPU: PowerVR SGX 544
    ROM 8GB
    RAM 1GB
    Screen
    Display Size 5.7 Inch
    Type IPS, capacitive touch screen
    Resolution 1080 x 720 pixels
    Screen Color 16000K Colors
    Support Format
    Ringtones Type Polyphonic/MP3
    Audio File Format MP3/WAV/AMR/AWB
    Video File Format 3GP/MPEG4
    Image File Format JPEG/BMP/GIF/PNG/GIF
    E-book Format TXT/CHM/DOC/HTML
    FM Radio Yes, earphone needed
    Earphone Port 3.5mm
    Card Extend Support TF card up to 16GB extended
    Data Transfer & Connectivity
    Data transfer USB/Bluetooth
    Mobile internet WAP/WIFI
    General
    Camera/Picture Resolution Dual Cameras, front camera 5.0MP, back camera 12.0MP
    with flashlight and auto focus, support full screen capturing
    Language English, Afrikanns, Bahasa Indoneisa, Bahasa Melayu, Catala,
    Cestina, Dansk, Deutsch, Espanol, Filipino, Latviesu, Lietuviu,
    French, Hrvatski, Zulu, Italiano, Kiswahili, Magyar, Nederlands,
    Norsk, Polish, Portuguese, Romana, Rumantsch, Slovencina,
    Suomi, Svenska, Vietnamese, Turkish, Greek, Bulgarian,
    Russian, Serbian, Ukrainian, Hebrew, Arabic, Persian, Hindi,
    Thai, Korean, Japanese, Simplified/Traditional Chinese
    Phonebook 500
    Message SMS/MMS
    Input Handwrite/Keypad
    TV No
    GPS Yes, built in, also support A-GPS
    With EPO assistance to speed up postioning
    JAVA No
    WIFI Yes, 802.11 b/g/n
    Bluetooth Bluetooth 2.0
    Gravity Sensor Yes
    Multi-Touch Yes, 5 point touch
    Dimensions 160 x 83 x 9mm/6.3 x 3.26 x 0.35 inch
    Net Weight(Including battery) 222g
    Standby Time About 2~3 days
    Other Feature 3G, WIFI, GPS, FM, Play Store, Bluetooth, Ebook, Email,
    Messaging, wallpapers, calendar, calculator, clock,
    camera, etc
    Package
    Size 190 x 120 x 60mm/7.48 x 4.72 x 2.36 inch
    Weight 554g
    Accessories 2 x 2800mAh Battery
    1 x 3.5mm Earphone
    1 x USB Cable
    1 x Charger
    1 x Screen Protector
    1 x User Manual(English-Russian-Spanish-German)
    Qualcuno che sappia qualcosa di più ???
    Ringraziato 114 volte in 78 Posts
    Se le caratteristiche riportate sono reali il telefono è piu che ottimo... il processore è l'ultimo nato in casa mtk e la lettera finale "t" sta ad indicare "turbo", cioè, hanno aumentato la frequenza da 1.2ghz a 1.5ghz. Display bello ampio e in HD... un bel terminale senza dubbio
    Il sapere umano appartiene al mondo
    Se ti sono stato d'aiuto... lascia un "Thanks"
    sposto in sezione star
    Nubia Z7MAX
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    lo puoi rimanere anche qua, in fondo è mtk e non sappiamo se sia veramente star (marca che non esiste tra l'altro)
    non sarà una marca ma qui sul forum esiste una sezione star...se poi si rivelerà non essere uno star si può sempre rispostare
    Nubia Z7MAX
    Quote Originariamente inviato da gaspatech Visualizza il messaggio
    L'avevo notato con lo stesso nome su *******.
    Cambiano però queste caratteristiche:
    [Risoluzione] 1280x720 (che suppongo sia esatta)
    [Peso] 172g (non so se sia inteso senza batteria)
    [Dimensioni] 151x80.2x9.6mm
    [Fotocamera Anteriore] 2.0MP
    [Fotocamera Posteriore] 8.0MP
    In giro esiste anche un altro smartphone denominato però: HDC Galaxy Note 2 B6000
    (Rinnovo ancora una volta i miei complimenti all' abilità innata dei cinesi nel fare casino.)
    Aggiungo:
    - non so se i dati relativi alla fotocamera siano reali od interpolati
    - anche i benchmarks con Antutu sono un terno al lotto perchè per lo stesso telefono nei vari siti viaggiano dai 12.000 e qualcosa agli oltre 15.000 secondo criteri a me sconosciuti.
  9. #8
    Acquistato e lo sto provando da un paio di giorni.
    Nessun problema particolare, anche il GPS e' ok.
    Antutu mi segna 14761
  10. #9
    Aug 2013
    una domanda per Weboole, quanto l'hai pagato???
    Come ti sembra ? ne consigli l'acquisto??
