[SNIPPET] ObservableFragment
    Androidiani Power User L'avatar di cesco
    Sep 2010
    Bg
    TYTN2,desire,desireHD, oneX
    Ringraziato 1,346 volte in 724 Posts
    Ho creato questa classe che estende android.app.Fragment per avere dei callback quando la transizione da un fragment all'altro è completa.
    Perchè funzioni è necessario impostare un'animazione custom per la transizione tra fragments
    https://gist.github.com/cesco89/9ddb738eef1cead8fea7
    import android.animation.Animator;
    import android.animation.AnimatorInflater;
    import android.app.Fragment;
    * Created by francesco on 14/10/14.
    public class ObservableFragment extends Fragment {
    private TransitionListener mListener;
    @Override
    public Animator onCreateAnimator(int transit, boolean enter, int nextAnim) {
    if(nextAnim != 0x0) {
    Animator animator = AnimatorInflater.loadAnimator(getActivity(), nextAnim);
    if (mListener != null) {
    animator.addListener(new Animator.AnimatorListener() {
    @Override
    public void onAnimationStart(Animator animation) {
    mListener.onTransitionStarted();
    @Override
    public void onAnimationEnd(Animator animation) {
    mListener.onTransitionEnded();
    @Override
    public void onAnimationCancel(Animator animation) {
    mListener.onTransitionCancel();
    @Override
    public void onAnimationRepeat(Animator animation) {
    mListener.onTransitionRepeated();
    return animator;
    return null;
    public void setTransitionListener(TransitionListener listener) {
    this.mListener = listener;
    public interface TransitionListener {
    public void onTransitionStarted();
    public void onTransitionCancel();
    public void onTransitionEnded();
    public void onTransitionRepeated();
    ObservableFragment f = new MyFragment();
    f.setTransitionListener(new ObservableFragment.TransitionListener() {
    @Override
    public void onTransitionStarted() {
    @Override
    public void onTransitionCancel(){
    @Override
    public void onTransitionEnded(){
    @Override
    public void onTransitionRepeated(){
    view raw sample.java hosted with ❤ by GitHub
    Follow me on:
    <!-- Place this tag where you want the widget to render. -->
    <div class="g-person" data-width="180" data-href="//plus.google.com/113012341277613226011" data-theme="dark" data-rel="author"></div>
    <!-- Place this tag after the last widget tag. -->
    <script type="text/javascript">
    window.___gcfg = {lang: 'it'};
    (function() {
    var po = document.createElement('script'); po.type = 'text/javascript'; po.async = true;
    po.src = 'https://apis.google.com/js/plusone.js';
    var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(po, s);
    </script>
    <br>
    <a class="twitter-timeline" href="https://twitter.com/xcesco89" data-widget-id="398762031488040960">Tweets di @xcesco89</a>
    <script>!function(d,s,id){var js,fjs=d.getElementsByTagName(s)[0],p=/^http:/.test(d.location)?'http':'https';if(!d.getElementB yId(id)){js=d.createElement(s);js.id=id;js.src=p+" ://platform.twitter.com/widgets.js";fjs.parentNode.insertBefore(js,fjs);}} (document,"script","twitter-wjs");</script>
    Androidiani app
    Estensione Androidiani per Google Chrome
  2. Il seguente Utente ha ringraziato cesco per il post:
    Crotan (29-10-14)
