Droid Mall D8
Droid Mall D8
Salve a tutti da qualche giorno ho tra le mani un telefono cinese ho eseguito la procedura di root con successo ora mi domandavo quale recovery posso montarci sopra?Qualcuno ha mai avuto a che fare con qualche modello simile??
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=MocorDroid2.3.5
ro.build.display.id=S08-HWD-A10_2SIM_USER_201309181428
ro.build.version.incremental=S08-HWD-A10_2SIM_USER_201309181428
ro.build.version.sdk=10
ro.build.version.codename=REL
ro.build.version.release=4.0
ro.build.date=Wed Sep 18 14:35:12 CST 2013
ro.build.date.utc=1379486112
ro.build.type=user
ro.build.user=xiongyu
ro.build.host=server-pc
ro.build.tags=test-keys
ro.product.model=A10
ro.product.brand=sprd
ro.product.name=sprdroid_base
ro.product.device=hsdroid
ro.product.board=s08-hwd-a10
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=sprd
ro.wifi.channels=
ro.board.platform=sprdbp
# ro.build.product is obsolete; use ro.product.device
ro.build.product=hsdroid
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=sprdroid_base-user 4.0 MocorDroid2.3.5 S08-HWD-A10_2SIM_USER_201309181428 test-keys
ro.build.fingerprint=sprd/sprdroid_base/hsdroid:4.0/MocorDroid2.3.5/S08-HWD-A10_2SIM_USER_201309181428:user/test-keys
ro.product.carrier=
ro.msms.phone_count=2sim
# end build properties
# system.prop for hsdroid
#rild.libpath=/system/lib/libsp_ril.so
#wifi.interface = tiwlan0
# Time between scans in seconds. Keep it high to minimize battery drain.
# This only affects the case in which there are remembered access points,
# but none are in range.
wifi.supplicant_scan_interval = 48
android.keylayout.sprd-keypad = /system/usr/keylayout/sprd-keypad.kl
android.keychar.sprd-keypad = /system/usr/keychars/sprd-keypad.kcm
ro.hardware =sphs
# Default network type
# 2 => AUTO Preferred.
ro.telephony.default_network = 2
# 1 => add volume control in in-call screen
ro.sprd.volume_control_icon = 1
ro.sf.lcd_density = 160
#ro.sf.hwrotation = 180
ro.sf.lcd_width = 45
ro.sf.lcd_height = 75
dalvik.vm.heapsize=32m
ro.device.support.gps=false
ro.device.support.msensor=false
ro.opengles.version=131072
ro.wallpaper.name=wallpaper_a10
ro.notelockscreen.background=hwd_a10_lockscreen_bg
ro.lockscreen.style=note
ro.incomingcall.acceptType=up
ro.animation.style=moto
ro.animation.secretCode=*35*7979#
# ADDITIONAL_BUILD_PROPERTIES
ro.config.notification_sound=OnTheHunt.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
ro.product.locale.language=pt
ro.product.locale.region=BR
ro.config.ringtone0=TwirlAway.ogg
ro.config.ringtone1=TwirlAway.ogg
ro.config.ringtone=TwirlAway.ogg
persist.sys.timezone=America/Sao_Paulo
ro.com.android.dateformat=dd-MM-yyyy
ro.com.android.dataroaming=true
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
- Non puoi inserire discussioni
- Non puoi inserire risposte
- Non puoi inserire allegati
- Non puoi modificare i tuoi messaggi
Regole del Forum
