Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 18
[Thread Ufficiale] UleFone Power 3S
    Moderatore SENIOR L'avatar di ghost45
    Troppi.. Mtk in generale.
    Ringraziato 1,247 volte in 782 Posts
    UleFone Power 3S
    [Thread Ufficiale]
    Ulefone Power 3S
    4G Phablet
    Android 7.1
    6.0 inch
    Corning Gorilla Glass 4
    MTK6763 Octa Core 2.0GHz
    4GB RAM 64GB ROM
    Quad Cameras
    Screen Face ID
    Type-C
    Link al sito ufficiale :
    Aggiornamento Android Oreo 8.0 previsto nei prossimi mesi.
    Ultima modifica di ghost45; 03-02-18 alle 09:36
    Usate il tasto "thanks" se vi sono stato d'aiuto non usate posts per ringraziare....contribuiamo a mantenere puliti i threads!!
    Differenze tra la serie Power
    Description:
    Ulefone Power 3S as a phablet features 6.0 inch Corning Gorilla Glass 4 IPS screen afford you a vivid and different visual experience. 16.0MP + 5.0MP dual back cameras and 13.0MP + 5.0MP dual front cameras, you can enjoy vivid images. It comes with most of the features we've come to expect from a phablet, including 4GB RAM and 64GB ROM storage equipped with Android 7.1 OS and 6350mAh battery that you can play games faster.
    Main Features:
    Ulefone Power 3S 4G Phablet Android 7.1 6.0 inch MTK6763 Octa Core 2.0GHz 4GB RAM 64GB ROM Quad Cameras Type-C Corning Gorilla Glass 4 Screen Face ID
    Display: 6.0 inch 2160 x 1080 pixels IPS Corning Gorilla Glass 4 screen
    CPU: MTK6763 Octa Core 2.0GHz
    System: Android 7.1
    Storage: 4GB RAM + 64GB ROM
    Cameras: 16.0MP + 5.0MP dual back cameras and 13.0MP + 5.0MP dual front cameras
    Sensors: Gyroscope, Gravity Sensor, Ambient Light Sensor, Proximity Sensor, E-compass, Fingerprint Sensor
    Features: GPS, GLONASS
    Bluetooth: 4.1 + HS
    SIM Card: dual SIM dual standby, 2 x Nano SIM card and a TF card can be inserted at the same time
    Network:
    2G: GSM B2/B3/B5/B8
    3G: WCDMA 900/2100MHz
    4G: FDD-LTE 800/900/1800/2100/2600MHz
    Qui un articolo interessante sulle bande,frequenze radio:
    Ultima modifica di ghost45; 03-02-18 alle 09:10
  4. Il seguente Utente ha ringraziato ghost45 per il post:
    tarivor (06-03-18)
  5. #3
    Reserved 2
  6. #4
    Nella Sezione Modding ho fatto alcune procedure ...root ed aggiornamento firmware..
  7. #5
    Ringraziato 89 volte in 79 Posts
    Interessante questo smartphone. Ne ho appena ordinato uno per la mia compagna su Amazon così ho un mese di tempo per valutarlo personalmente.
    Come va l'audio in capsula? C'è la possiiblità di alzare il volume massimo dai soliti menù di engineering degli Mtk?
    Se ti sono stato d'aiuto clicca sul tasto Thanks
  8. #6
    Quote Originariamente inviato da tarivor Visualizza il messaggio
    Ma certamente dal solito menu mtk.. Ma da quanto ho visto non serve alzare alcun volume poiché è ben settato.
    Inviato dal mio P5000 usando Androidiani App
  9. #7
    Arrivato. Rimasto sorpreso oltre che dal telefono anche da cavi, cavetti e adattatori presenti nel contenitore. Addirittura ho trovato pure una cover di protezione trasparente e protezione schermo.
  10. #8
    Si ottimo cofanetto.
    Io ho riscontrato che il device è un po' 'lento " a confronto con altri simili e con 4gb di ram.. Poi carica veloce quasi inesistente!
    Inviato dal mio Power 3S usando Androidiani App
    Ultima modifica di ghost45; 12-03-18 alle 12:27
  11. #9
    CAGLIARI
    Jiayu S3A-Umidigi F1
    Ringraziato 32 volte in 22 Posts
    ciao a tutti, ho appena acquistato questo smartphone e sono in attesa di riceverlo, in cima nelle caratteristiche trovo questa dicitura "dual SIM dual standby, 2 x Nano SIM card and a TF card can be inserted at the same time" vuol dire che è possibike inserire 2 sim e una microSD contemporaneamente ? dalla traduzione di google sembrerebbe cosi. grazie della risposta.
    Jiayu S3 Adv RRemix V25 7.1.2
  12. #10
    No giopoli... Una sim ed una sd card oppure 2 sim.
    Il carrello delle sim è il solito per quasi tutti i device.
