[KERNEL][ido][AOSP-CAF]KudKernel [29-03-2017]
KudKernel for Ido
Caratteristiche:
- Based on CAF LA.BR.1.2.9_rb1.14 (msm8916_64) kernel source with patches and updates from LineageOS
- Linux kernel base updated to 3.10.105
- Prima driver updated to LA.BR.1.2.9_rb1.12
- Compiled using Linaro GCC 6.3.1
- Compiled with -O2 flag and some optimizations
- Unnecessary and debugging stuffs disabled
- CPU boost removed (any benefits?)
- ARM-v8a and Cortex-A53 optimizations
- Using modified AnyKernel2 to ensure compatibility across LineageOS 14.1 based ROMs
- Thermal Limit increased from 45°C to 60°C
- CPU minimum frequency reduced to 400MHz on both clusters
- CPU maximum frequency unlocked to 1497MHz (performance/big) and 1209MHz (powersave/LITTLE)
- CPU maximum frequency defaults are set to 960MHz (performance/big) and 800MHz (powersave/LITTLE)
- Software CRC check disabled (could be enabled at anytime)
- Add Random and I/O stats disabled by default
- RQ Affinity default to 2 (Aggressive)
- Power efficient workqueues for power saving
- KCAL post-processing control
- MSM Core Control for CPU hotplug
- Adreno Idler for msm-adreno-tz overhead workaround
- Ultra Kernel Samepage Merging 0.1.2.3 (ported for usage on Linux 3.10.105 by me)
- Power Suspend v1.5
- Fsync
- exFAT and SDcardFS support
- F2FS driver updated to v4.11-rc1
- Random driver backported from Linux 4.2
- CPU governors: performance, interactive, ondemand, conservative, zzmoove, nebula, smartmax
- GPU governors: msm-adreno-tz (default), simple_ondemand, cpufreq
- I/O schedulers: bfq (default), noop, deadline, fiops (during boot), zen
- TCP congestion controls: westwood (default), cubic, vegas, reno, cdg
- NetFilter TTL target support enabled (I'm hearing you, Russians! xD)
- Other standard features from stock LineageOS kernel
- And more patches and improvements to ensure you're given the best out of the kernel
Download QUI
Installazione:
N.B E' necessaria la TWRP ufficiale, non la versione chinese;
Inoltre, se avete un kernel diverso è richiesto il ripristino del del boot.img originale, quindi potete prenderlo dallo zip della vostra rom e flasharlo da twrp(flash image).
- Download KudKernel zip.
- Reboot to recovery.
- Flash KudKernel zip.
- Optional: Enable zip signature verification to verify the package before flashing.
- Profit. Enjoy the release.
Bug noti:
- LineageOS kernel specific issues... (Hai!)
- The kernel might be unstable on some ROMs. Proceed with this extra notice.
- Some Russian users from 4PDA reported network signal is worsening during voice call. On my end, it kicks me to WCDMA temporarily until voice call ended. (not my issue actually)
- KCAL's color changer doesn't work. (changes are discarded after turning off the screen)
- Bluetooth is disabled after restart.
Fonte e Ringraziamenti:
XDA
e krasCGQ.
