Zte z7 max o zopo zp999
    Dec 2014
    SALVE RAGAZZI VI SCRIVO PERCHE' VORREI UN CONSIGLIO SUL TELEFONO DA COMPRARE SONO INDECISO TRA ZOPO ZP 999 E ZTE Z7 MAX.
    PREMETTO CHE AVENDO UNA SCHEDA TRE DA INSERIRE NELLO SLOT UMTS E UNA SECONDA SCHEDA TIM DA INSERIRE NEL 2 SLOT, I MIEI DUBBI SONO LEGATI ALLA COMPATIBILITA' DELLE RETI TRE, SICCOME MI CAPITA CHE LA TRE NN PRENDE E SI APPOGGIA A TIM E VISTO CHE NELLE NOTE TECNICHE DEI DUE TELEFONI ( ZOPO DICE 3G WCDMA 900/1900/2100 Mhz MENTRE ZTE WCDMA 850/1900/2100 Mhz).
    DA PROFANO HO PENSATO CHE MAGARI LO ZTE NON E' PIENAMENTE COMPATIBILE CON TRE PER L'UMTS. QUALCUNO CHE HA GIA' IL TELEFONO ZTE MI PUO' ILLUMINARE O E' SOLO UNA MIA FISSAZIONE.
    E' CHIARO CHE LO ZOPO DAL PUNTO DI VISTA DEL 4G SIA PIU COPERTO ( TDD-LTE 1900/2300/2600 FDD-LTE 800/1800/2600) MENTRE ZTE ( FDD-LTE 1800/2100/2600 Mhz).VORREI SAPER ANCHE DELLA FOTOCAMERA E DEL RENDIMENTO ENERGETICO VISTO LA DIFFERENZA DI PROCESSORE E DI BATTERIA (SNAPDRAGON VS MEDIATEK E 2700 MAH VS 3100MAH)?
    VI RINGAZIO ANTICIPATAMENTE
