Utente del giorno: robnovi con ben 1 Thanks ricevuti nelle ultime 24 ore
Pagina 35 di 130 primaprima ... 2533343536374585 ... ultimoultimo
Visualizzazione dei risultati da 341 a 350 su 1298
[ROM LOLLIPOP Android 5 Mod By BB72 & Cuoco92] ZTE Nubia Z7 Max |COMBO ROM|
  1. #341
    [quote name="Kokireg" post=6815477]hi,
    Mi piacerebbe sapere come restituire la versione 1.64 BB72 versione 3.08 perché questo è molto buona, ma molto mal gestisce dual sim ed è molto importante per me.
    grazie[/QUOTE]
    Devi usare nuovamente il tool nubia ed usare la rom 1.64 com'è indicato nella guida al post 1.
    Così avrai la rom stock 1.64 poi installi la twrp e la 1.64 BB72
    Inviato dal mio LG-D858HK usando Androidiani App
    Oct 2014
    Ringraziato 16 volte in 12 Posts
    Hi,
    Where will we get xposed Lollipop for Nubia Z7 Max
  4. #343
    Quote Originariamente inviato da niza2000in Visualizza il messaggio
    Hi,
    Do not think you can find some working release on nubia UI lollipop
  5. #344
    May 2015
    Madrid, Spain
    Nubia z7 max
    Ringraziato 21 volte in 16 Posts
    Hi people.
    Two days ago I had a serious brick after upgrading to 3.09. I followed BB72 advice and reinstalled stock 3.09 after having upgraded to beta1 in order to reformat internal partitions. Those partitions are still at 2.13 since 3.08beta1 do not touch them.
    However something was WRONG and I completely bricked my z7 max. No bootloader, no recovery, no download mode. After some heavy investigation, I managed to recover from scratch my phone. Those are steps after many trial and run:
    1- Forget about Windows 8. Use Windows 7
    2- battery fully loaded.
    3- Nubia USB cable.
    4- remove sims and TF card.
    Synthoms:
    No download mode. No recovery. No boot.
    Windows recognizes a QHUSB_BULK device or an "unidentified USB device". Nothing else.
    procedure:
    - Download nubia updater V2(first post)
    - Download stock rom 3.09/3.08/2.13/1.64. I used 3.09
    - Download Qualcomm 2012 drivers (search google)
    - I assume zTE drivers were already loaded (from autorun.exe first time you plug your phone)
    0- turn on your phone (black screen) by pressing for 20 seconds vol up+vol down + power or until USB is recognized.
    1- install Qualcomm drivers for your QHUSB_BULK device. You will have to override certified driver warning.
    2- your port will become USB Diagnostic port COM6
    3- press vol up + vol down + power for About 20 seconds until your windows recognises COM6 port. It's possible it will also detect a lot of partitions. Wait for all to be detected.
    4- open nubia updater and proceed with rom install.
    5- if fails, unplug, plug, press three buttons and try again flashing. Do as many times until process finish. Remember use Windows 7 + Nubia USB cable + battery loaded.
    5.5 - if process passes recovery but don't finish (fails on system.img flashing) you could eventually boot into download mode (vol down + power) and install TWRP and recover form backup. When using Raygloble tool press CTRL+C to skip ADB phase. This is optional only if you want to restore from backup.
    6- eventually ROM will be loaded again and your phone will be fully recovered.
    7- restore IMEI/Blutooth/wifi settings from Nubia updater as show in BB72 notes.
    8- reinstall recovery TWRP
    Remember: do no enter panic. It is almost impossible to fully brick your phone.
    P.D: I think this will work for z7 mini also.
  6. Il seguente Utente ha ringraziato inigoml per il post:
    Cuoco92 (03-05-15)
  7. #345
    Senior Droid L'avatar di mrgiaco
    Vicenza
    LeEco Le2 max
    Ringraziato 321 volte in 191 Posts
    Buongiorno e buona domenica.
    Vorrei chiedere se qualcuno ha idea se è possibile ordinare e aggiungere altri toggles oltre a quelli predefiniti dal sistema. Nella versione della rom KK era una opzione prevista ma in Lollipop non riesco a trovarla.
    Ecco una schermata di quello di cui sto parlando:
    Ultima modifica di mrgiaco; 03-05-15 alle 12:18
  8. #346
    May 2015
    Madrid, Spain
    Nubia z7 max
    Quote Originariamente inviato da mrgiaco Visualizza il messaggio
    Vorrei chiedere se qualcuno ha idea se è possibile ordinare e aggiungere altri toggles oltre a quelli predefiniti dal sistema. Nella vesione della rom KK era una opzione prevista ma in Lollipop non riesco a trovarla.
    Xposed Framework. :-)
  9. #347
    Ringraziato 282 volte in 242 Posts
    magari nella nubia UI l'hanno messa ... ma pensa che in LL AOSP l'hanno pure tolta.
    Ci sono 6 toggle in croce, più in paio che compaiono solo se li attivi una volta.
    Non penso che xposed funzioni. :/
  10. #348
    No purtroppo i toggles ad oggi sono quelli. ...noi siamo riusciti ad aggiungere solo il blocco schermo (che non c'era) per gli altri nulla da fare. ...non ci sono proprio gli smali. ....Welcome to lollipop. ..; 0)....
    Inviato dal mio SM-P605 usando Androidiani App
  11. Il seguente Utente ha ringraziato BB72 per il post:
    mrgiaco (03-05-15)
  12. #349
    Quote Originariamente inviato da inigoml Visualizza il messaggio
    Hi people.
    3- Nubia USB cable.
    Synthoms:
    procedure:
    Nice experience. ....; 0).....Thanks for explaining it....for sure very useful. ....
  13. #350
    Senior Droid L'avatar di nipponiko
    Ringraziato 120 volte in 95 Posts
    scusate ma ...quella bella funzione di riavviare in recovery oppure in bootloader che era presente prima c'è anche adesso e sono io a non riuscire a trovarla oppure non c'è proprio? Grazie
