Pagina 3 di 13 primaprima 12345 ... ultimoultimo
Visualizzazione dei risultati da 21 a 30 su 123
IMEI generico 004999010640000
  1. #21
    Sempre dalla cartella efs fai "cat nv.log", e controlla che l'imei debba stare in /data/radio anche nel tuo telefono.
    In quel caso risolvi ricopiando i file nv_data in /data/radio, visto che nella partizione efs ci sono ancora. Assumendo che tu non abbia busybox, fai cosi:
    su
    cd /efs
    cat nv_data.bin >> /data/radio/nv_data.bin
    cat nv_data.bin.md5 >> /data/radio/nv_data.bin.md5
    sync
    reboot
    Al riavvio controlla se funziona.
    C:\ADB>adb shell
    * daemon not running. starting it now on port 5037 *
    * daemon started successfully *
    shell@android:/ $ su
    su
    shell@android:/ # cd /efs
    cd /efs
    shell@android:/efs # cat nv.log
    cat nv.log
    : MD5 status = (OFF)
    Mon Mar 11 16:46:26 2013: truncate 10261 -> 5141 bytes
    Mon Mar 11 16:46:26 2013: MD5 status = (OFF)
    Mon Mar 11 16:46:27 2013: MD5 status = (OFF)
    Mon Mar 11 16:46:45 2013: check on (temp case)
    Mon Mar 11 16:46:46 2013: 2nd NV built
    Mon Mar 11 16:46:47 2013: NV data back-uped
    Mon Mar 11 17:02:23 2013: check on (temp case)
    Mon Mar 11 17:02:23 2013: 2nd NV built
    Mon Mar 11 17:02:24 2013: NV data back-uped
  4. #23
    Mon Mar 11 17:15:59 2013: check on (temp case)
    Mon Mar 11 17:16:00 2013: 2nd NV built
    Mon Mar 11 17:16:01 2013: NV data back-uped
    Mon Mar 11 19:00:40 2013: check on (temp case)
    Mon Mar 11 19:00:40 2013: 2nd NV built
    Mon Mar 11 19:00:42 2013: NV data back-uped
    Mon Mar 11 19:01:36 2013: check off
    Mon Mar 11 19:01:36 2013: MD5 status = (OFF)
    Mon Mar 11 19:02:21 2013: MD5 status = (OFF)
    Mon Mar 11 19:02:22 2013: MD5 status = (OFF)
    Mon Mar 11 19:02:23 2013: MD5 status = (OFF)
    Mon Mar 11 19:03:24 2013: check on (temp case)
    Mon Mar 11 19:03:24 2013: 2nd NV built
    Mon Mar 11 19:03:25 2013: NV data back-uped
    Mon Mar 11 22:29:03 2013: check on (temp case)
    Mon Mar 11 22:29:04 2013: 2nd NV built
    Mon Mar 11 22:29:04 2013: NV data back-uped
    Tue Mar 12 00:51:08 2013: check on (temp case)
    Tue Mar 12 00:51:09 2013: 2nd NV built
    Tue Mar 12 00:51:10 2013: NV data back-uped
    Tue Mar 12 08:03:50 2013: check on (temp case)
    Tue Mar 12 08:03:51 2013: 2nd NV built
    Tue Mar 12 08:03:51 2013: NV data back-uped
    Tue Mar 12 08:42:06 2013: check on (temp case)
    Tue Mar 12 08:42:07 2013: 2nd NV built
    Tue Mar 12 08:42:08 2013: NV data back-uped
    Tue Mar 12 09:36:42 2013: check on (temp case)
    Tue Mar 12 09:36:43 2013: 2nd NV built
    Tue Mar 12 09:36:43 2013: NV data back-uped
    Tue Mar 12 15:30:48 2013: check on (temp case)
    Tue Mar 12 15:30:49 2013: 2nd NV built
    Tue Mar 12 15:30:51 2013: NV data back-uped
    Tue Mar 12 17:15:57 2013: check on (temp case)
    Tue Mar 12 17:15:57 2013: 2nd NV built
    Tue Mar 12 17:15:58 2013: NV data back-uped
    Sat Jan 1 01:00:18 2000: check on (temp case)
    Sat Jan 1 01:00:18 2000: 2nd NV built
    Sat Jan 1 01:00:19 2000: NV data back-uped
    Sat Jan 1 01:02:04 2000: check on (temp case)
  5. #24
    Sat Jan 1 01:02:04 2000: 2nd NV built
    Sat Jan 1 01:02:05 2000: NV data back-uped
    Thu Mar 14 14:54:41 2013: check on (temp case)
    Thu Mar 14 14:54:42 2013: 2nd NV built
    Thu Mar 14 14:54:43 2013: NV data back-uped
    Thu Mar 14 15:00:43 2013: check on (temp case)
    Thu Mar 14 15:00:43 2013: 2nd NV built
    Thu Mar 14 15:00:44 2013: NV data back-uped
    Thu Mar 14 16:53:14 2013: check on (temp case)
    Thu Mar 14 16:53:15 2013: 2nd NV built
    Thu Mar 14 16:53:16 2013: NV data back-uped
    Thu Mar 14 23:27:39 2013: check on (temp case)
    Thu Mar 14 23:27:39 2013: 2nd NV built
    Thu Mar 14 23:27:40 2013: NV data back-uped
    Thu Mar 14 23:29:54 2013: check on (temp case)
    Thu Mar 14 23:29:54 2013: 2nd NV built
    Thu Mar 14 23:29:55 2013: NV data back-uped
    Thu Mar 14 23:36:07 2013: check on (temp case)
    Thu Mar 14 23:36:07 2013: 2nd NV built
    Thu Mar 14 23:36:08 2013: NV data back-uped
    Thu Mar 14 23:39:48 2013: check on (temp case)
    Thu Mar 14 23:39:48 2013: 2nd NV built
    Thu Mar 14 23:39:49 2013: NV data back-uped
    Fri Mar 15 14:24:48 2013: check on (temp case)
    Fri Mar 15 14:24:48 2013: 2nd NV built.
    Fri Mar 15 14:24:50 2013: NV data back-uped
    Fri Mar 15 14:40:58 2013: check on (temp case)
    Fri Mar 15 14:40:58 2013: 2nd NV built.
    Fri Mar 15 14:40:58 2013: NV data back-uped
    Sat Mar 16 00:01:25 2013: check on (temp case)
    Sat Mar 16 00:01:26 2013: 2nd NV built.
    Sat Mar 16 00:01:26 2013: NV data back-uped
    Sat Mar 16 00:05:32 2013: check on (temp case)
    Sat Mar 16 00:05:33 2013: 2nd NV built.
    Sat Mar 16 00:05:34 2013: NV data back-uped
    Sat Mar 16 00:09:19 2013: check on (temp case)
    Sat Mar 16 00:09:20 2013: 2nd NV built.
    Sat Mar 16 00:09:21 2013: NV data back-uped
    Sat Mar 16 00:22:46 2013: check on (temp case)
    Sat Mar 16 00:22:47 2013: 2nd NV built.
    Sat Mar 16 00:25:04 2013: check on (temp case)
    Sat Mar 16 00:25:04 2013: 2nd NV built.
    Sat Mar 16 00:25:05 2013: NV data back-uped
    Sat Mar 16 00:25:05 2013: truncate 10276 -> 5156 bytes
    Sat Mar 16 00:36:05 2013: check on (temp case)
    Sat Mar 16 00:36:05 2013: 2nd NV built.
    Sat Mar 16 00:36:06 2013: NV data back-uped
    Sat Mar 16 00:41:38 2013: check on (temp case)
    Sat Mar 16 00:41:38 2013: 2nd NV built.
    Sat Mar 16 00:41:39 2013: NV data back-uped
    Sat Mar 16 00:43:38 2013: check on (temp case)
    Sat Mar 16 00:43:38 2013: 2nd NV built.
    Sat Mar 16 00:43:39 2013: NV data back-uped
    Sat Mar 16 14:18:30 2013: check on (temp case)
    Sat Mar 16 14:18:30 2013: 2nd NV built.
  6. #25
    Sat Mar 16 14:18:32 2013: NV data back-uped
    Sun Mar 17 10:11:11 2013: check on (temp case)
    Sun Mar 17 10:11:11 2013: 2nd NV built.
    Sun Mar 17 10:11:13 2013: NV data back-uped
    shell@android:/efs # cat nv_data.bin >> /data/nv_data.bin
    shell@android:/efs # cat nv_data.bin.md5 >> /data/radio/nv_data.bin.md5
    sh: cannot create /data/radio/nv_data.bin.md5: No such file or directory
    1|shell@android:/efs # sync
    sync
    shell@android:/efs # reboot
    reboot
    L'imei mi rimane sempre generico. Comunque mi ha dato un errore che è quello evidenziato in rosso. Cosa posso fare?
  7. #26
    Poco si fa, il log é troncato e non si capisce dove sta il file nv_data nella partizione userdata. Il primo te lo ha fatto scrivere perche hai sbagliato il percorso. Se ci guardi vedrai che manca la cartella radio in /data ..
    Devi cercare di capire dove stanno quei file, e rimetterceli. Una alternativa, visto che la efs sembra buona, sarebbe quella di wipare tutto e riflashare una rom stock. In genere vengono ri-creati.
  8. #27
    Quote Originariamente inviato da VanniX Visualizza il messaggio
    Fatto, ma mi rimane sempre l'imei generico.
  9. #28
    Quote Originariamente inviato da pagaleno Visualizza il messaggio
    Allora prova a fare un'altra cosa.. Prova a usare i file di backup della partizione EFS al posto degli originali, poi rifai un wipe completo e vedi cosa succede.
    Rinomini i 2 file nv_data in nv_data.bin.old e nv_data.bin.md5.old, poi prendi .nv_data.bak e lo rinomini in .bin, fai lo stesso per l'md5.
    Se anche cosi non funziona non so che dirti, probabilmente è stato corrotto uno dei file nv_data..
  10. #29
    Senior Droid L'avatar di gas88
    Galaxy nexus I9250
    Ringraziato 33 volte in 32 Posts
    Quote Originariamente inviato da DIDAC Visualizza il messaggio
    Il backup della cartella EFS?
    Comunque meglio se continuiamo nel 3d che hai postato
    eccoci qui...non ho un backup EFS
  11. #30
    Androidiano L'avatar di DIDAC
    HONOR 8
    Ringraziato 29 volte in 17 Posts
    Senza back up la vedo dura.
    Qualcuno risolse tempo fa riflashando la rom originale samsung con cui il cell uscì, anche se è strano dato che l'imei non risiede nella ROM.
    Potresti provare, altrimenti piu che farti ripristinare la cartella EFS non saprei come fare, non mi sono ai posto il problema che tra l'altro potrebbe essere ritenuto illegale eseguire.
