Pagina 4 di 5 primaprima ... 2345 ultimoultimo
Visualizzazione dei risultati da 31 a 40 su 45
[ROM] [Z5S] [Android 7.1.1] LineageOS 14.1 unofficial
  1. #31
    Jun 2017
    still, good to know that we can install it
    Androidiano L'avatar di Maegorn
    Mar 2016
    Lecce
    Nubia z5s
    Ringraziato 39 volte in 32 Posts
    Released 3.1.1-0 TWRP (Download Link in post #1)
    Changelog:
    - Added otg mouse support
  4. #33
    Jul 2017
    I'm a z5s user from China.
    1.I wonder why u still using this phone?it so old that just few people are using.There is no new 7.0 rom for z5s in China.I spent a lot of time to find the suitable rom and i find the one you made,thank u.
    2.Why there is no FM anymore,because of API?I love hardware FM but there is only FM radio online app.Is there any hardware FM?
    Thanks for reading my poor english.
    Ultima modifica di Dachtire; 09-07-17 alle 16:14
  5. #34
    Mar 2016
    Lecce
    Nubia z5s
    Quote Originariamente inviato da Dachtire Visualizza il messaggio
    Hi mate I'm still using this phone cause i love it and i dont need a new one and i love to made custom roms The problem with FM is in the API, Our FM is Bradcom and not Qualcomm and there isnt open source software/framework to use and make it works
  6. #35
    Jul 2017
    Hi Maegorn,
    Thank you for your continued support for this device, thanks to you it still has life!
    I have a strange bug though, the volume buttons on the phone don't work. There's nothing wrong with them physically as they still work in recovery etc. Am I the only one facing this?
  7. #36
    Mar 2016
    Lecce
    Nubia z5s
    Quote Originariamente inviato da mikeysteele Visualizza il messaggio
    Hi Maegorn,
    My volume buttons work well (i'm testing the new release, maybe tomorrow i will upload it), did you try a clean flash?
  8. Il seguente Utente ha ringraziato Maegorn per il post:
    mikeysteele (20-07-17)
  9. #37
    Mar 2016
    Lecce
    Nubia z5s
    Released Beta 11
  10. Il seguente Utente ha ringraziato Maegorn per il post:
  11. #38
    Jul 2017
    Quote Originariamente inviato da Maegorn Visualizza il messaggio
    Cheers for the reply. Yep I've tried a clean flash. I also flashed CM13 and they didn't work there either so something is definitely amiss. I'm pretty sure they used to work in CM13 but I can't remember as I don't really use the z5s much these days. Maybe it has something to do with the modem firmware? I guess I could try and flash it back to stock and start again.
  12. #39
    Mar 2016
    Lecce
    Nubia z5s
    Yes, try that way, if you won't resolve your issues i will help you to fix it
  13. #40
    May 2017
    Will the Android 8 match?
