Pagina 2 di 5 primaprima 1234 ... ultimoultimo
Visualizzazione dei risultati da 11 a 20 su 45
[ROM] [Z5S] [Android 7.1.1] LineageOS 14.1 unofficial
  1. #11
    Nov 2016
    Thank you very much ...
  2. Il seguente Utente ha ringraziato Konrad96 per il post:
    Maegorn (29-11-16)
    Nov 2016
    Quote Originariamente inviato da Vyserios Visualizza il messaggio
    Mate i have to thank you, i investigated on gps and i found that there was some hacks to do to make it fast on nougat, now gps is 100x faster on cm-14.1, tomorrow , maybe, i will upload the new rom
    Thank you very much!!! GPS works !!!
  5. #13
    Androidiano L'avatar di Maegorn
    Mar 2016
    Lecce
    Nubia z5s
    Ringraziato 39 volte in 32 Posts
    Quote Originariamente inviato da Konrad96 Visualizza il messaggio
    You're welcome if you notice some other issues pls tell me and i'll try to fix 'em
  6. #14
    Nov 2016
    ZTE Z5 Mini
    I mate i am having a few errors making the 14.1 for my device nx402, when i apply the patch 0005 of https://github.com/BambooIV/android_...03a/tree/patch to make my kernel boot, this are the errors:
    /media/otto/Android/android/system/kernel/zte/nx402/scripts/Makefile.build:307: fallo en las instrucciones para el objetivo 'security/selinux/avc.o'
    make[3]: *** [security/selinux/avc.o] Error 1
    make[3]: *** Se espera a que terminen otras tareas....
    /media/otto/Android/android/system/kernel/zte/nx402/security/selinux/hooks.c: In function 'ioctl_has_perm':
    /media/otto/Android/android/system/kernel/zte/nx402/security/selinux/hooks.c:3060:27: error: storage size of 'ioctl' isn't known
    struct lsm_ioctlop_audit ioctl;
    In file included from /media/otto/Android/android/system/kernel/zte/nx402/security/selinux/include/avc.h:16:0,
    from /media/otto/Android/android/system/kernel/zte/nx402/security/selinux/hooks.c:86:
    /media/otto/Android/android/system/kernel/zte/nx402/include/linux/lsm_audit.h:99:16: error: 'LSM_AUDIT_DATA_IOCTL_OP' undeclared (first use in this function)
    (_d)->type = LSM_AUDIT_DATA_##_t; }
    /media/otto/Android/android/system/kernel/zte/nx402/security/selinux/hooks.c:3067:2: note: in expansion of macro 'COMMON_AUDIT_DATA_INIT'
    COMMON_AUDIT_DATA_INIT(&ad, IOCTL_OP);
    /media/otto/Android/android/system/kernel/zte/nx402/include/linux/lsm_audit.h:99:16: note: each undeclared identifier is reported only once for each function it appears in
    /media/otto/Android/android/system/kernel/zte/nx402/security/selinux/hooks.c:3068:6: error: 'union <anonymous>' has no member named 'op'
    ad.u.op = &ioctl;
    /media/otto/Android/android/system/kernel/zte/nx402/security/selinux/hooks.c:3069:6: error: 'union <anonymous>' has no member named 'op'
    ad.u.op->cmd = cmd;
    /media/otto/Android/android/system/kernel/zte/nx402/security/selinux/hooks.c:3071:6: error: 'union <anonymous>' has no member named 'op'
    ad.u.op->path = file->f_path;
    /media/otto/Android/android/system/kernel/zte/nx402/security/selinux/hooks.c:3060:27: warning: unused variable 'ioctl' [-Wunused-variable]
    error, forbidden warning: hooks.c:3060
    /media/otto/Android/android/system/kernel/zte/nx402/scripts/Makefile.build:307: fallo en las instrucciones para el objetivo 'security/selinux/hooks.o'
    make[3]: *** [security/selinux/hooks.o] Error 1
    /media/otto/Android/android/system/kernel/zte/nx402/scripts/Makefile.build:443: fallo en las instrucciones para el objetivo 'security/selinux'
    make[2]: *** [security/selinux] Error 2
    /media/otto/Android/android/system/kernel/zte/nx402/Makefile:951: fallo en las instrucciones para el objetivo 'security'
    What can it be and how to fix it, thanks mate
  7. #15
    May 2016
    Russia
    Nubia Z5S 32 gb
    How to get root on beta6? I go the way - Settings -> Developer Settings -> Tap on “Root Access” and its 2 choise - off, - only ADB.
  8. #16
    Mar 2016
    Lecce
    Nubia z5s
    Quote Originariamente inviato da SergMakarov Visualizza il messaggio
    Yes sorry, in beta6 there isnt root, lineages os choice, flash this zip for temp solution supersu.
    I will release beta7 next week, with integrated su privileges.
    Ultima modifica di Maegorn; 29-01-17 alle 22:59
  9. #17
    Mar 2016
    Lecce
    Nubia z5s
    Released the new TWRP 3.0.3 (Download in #1 post)
    Changelog:
    • Now you can backup every partition (persist, modem, efs, ecc ecc)
  10. #18
    Apr 2017
    Hi
    I was trying to found a updated version for my Nubia and I found this forum. Thank You for that.
    My question is: I'm using Mokee 6.0 version on it, but I have the problem of lack of space (due to not using the total memory available).
    I see that this version needs the partitions merged. Is this mandatory? Can't the ROM make only one partition for everything?
    Thank You
    Grazzie
  11. #19
    Mar 2016
    Lecce
    Nubia z5s
    Quote Originariamente inviato da rop12770 Visualizza il messaggio
    Hi
    Thank You
    Grazzie
    Yes, it is mandatory, you have to merge the partition to use my rom, btw you can undo this process using nubia tool studio
  12. #20
    Apr 2017
    Hi
    Thanks for the answer.
    But, there is no ROM that can use the full amount of space??
